Question about Dell Inspiron 1501 Notebook
Hooking up a laptop to a hdtv
I am having trouble hooking up my laptop to my hdtv. i'm using a vga port on my laptop
  • Dell Master
  • 4,338 Answers
If your TV does not have a VGA connector, then you need an adapter.
Here is a link for a VGA to DVI adapter. Then probably at the same link you can get a DVI cable long enough for what you want to do.
http://www.globalcomputer.com/applications/searchtools/item-details.asp?EdpNo=244973&csid=_21
If you want to do it wirelesly you can get a PC2TV Wireless adapter for $199.99 at
http://www.cyberguys.com/templates/SearchAll.asp?search=component+adapters&sort=desc
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 17, 2008
How do i hook lap top up
Most Laptops have a VGA output port. You would just hook this to the VGA input of the TV for video (picture).
You would then need to hook an audio cable from the laptops headphone jack to the TV's VGA's Audio Input jack.
Newer laptops have a HDMI output so that is easier and can hook directly to the TV's HDMI input for both video and audio.
Nov 13, 2013 | Zenith R57W46 57" Rear Projection...
How do you hook up laptop to tv
Great day Barry!
You need a 15-pin VGA connector to hookup your laptop to your RCA L32HD31 through the VGA ports.Please see attached image.11_19_2011_6_49_41_am.jpg
Nov 19, 2011 | RCA L32HD31 32 in. LCD HDTV
How to connect a Samsung R700 PC to Sony LCD TV KDL-46S2010
hi my name is Rui i would like to help you with your problem...
its just easy to connect a PC to a sony lcd tv...^_^ here are 5 ways to do it...
1. S-Video - This is probably the most common method out there currently because an S-Video Cable is cheap as heck and just about every TV under the sun has a S-Video port. You'll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC's are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA Cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won't find a VGA port on regular TV's though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with "digital" being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI - Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Coverter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
just try hooking up 1 of this tips i give you.well if you ask me i prefer HDMI & VGA. ^_^
but it will still depend on your preference..
hope this will help you... Good luck... ^_^
Jul 17, 2011 | Samsung Computers & Internet
What do I need and how do I connect my Toshiba L305 model PSLB8 050302f to my hdtv to view online tv?
I dont believe that laptop has an HDMI port on it. If you have an LCD TV then your TV may have a VGA or DVI input on it. You can connect your laptop to the TV by using a VGA to VGA or VGA to DVI cable. If you your TV doesn't have one of these input ports, then you're not going to get your laptop connected to your TV.
Mar 03, 2011 | Toshiba Satellite Pro L300 Notebook
How to hook my ns230e to my hdtv
Looking at the spec for that model - you only have a VGA output On you HDTV do you have a VGA input for PC connection, often HD TV do - if not then we will need the make and model of the TV and type of connections available - also need to check the grahics driver on the laptop to see if it supports TV out via VGA if its to be connected to a different input on the TV anyway LETS ASSUME YOU HAVE A VGA input on the TV TV:- probably has a PC input - which is a VGA connector looks like this http://upload.wikimedia.org/wikipedia/commons/9/92/SVGA_port.jpg and then you select PC input on the TV to display whats connected to that port Laptop: - Now on the laptop, you will need to select the VGA output to work - there will be a picture of a screen on one of the F keys at the top of the keyboard, F4, F5 normally on laptops, My Sony uses F7 ---- (assuming F7) use the FN key and the F7 key together it will then toggle between the following <laptop only><laptop and VGA output><VGA output only>
Mar 21, 2010 | Sony VAIO VGN-NS230E/W Notebook
How do i connect my acer aspire 5810T to my tv, thanks
I am assuming that you want to display your laptop on your TV. Since you did not post what TV you have, I am listing multiple ways to connect your laptop to your TV. Just pick the right type connection that works for both your laptop and TV, connect OUT of laptop to an INPUT on your TV. Set your TV to that input (mode) and if you see nothing on the TV, look at your laptop keyboard at the F keys (function keys) for the one with a double display image on it, pree the function button and the F key to set the laptop to external display.
1. S-Video – This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won’t find a VGA port on regular TV’s though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with “digital” being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI – Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box – This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
If by chance you are attempting to hook up the TV to the laptop to capture video from the TV, you need to hook up your wire to the OUTPUT of the TV and you will need a capture card or hardware and software to do this. I hope this helps and good luck. Please vote appropriately and leave a comment.
Oct 29, 2009 | Acer Aspire AS5530-5824 Laptop
I just hooked up my HP Pavilion 9000 Laptop to my Vizio TV and put the TV on correct setting. It is not working on the TV, any ideas? I went on Display setup and kept trying to connect but it says the...
If your laptop has a VGA port, your Vizio needs to have a VGA port too so you can use a standard VGA monitor cable.
If your laptop has a DVI port, you hook it up to the Vizio using a DVI-to-HDMI cable.
And if your laptop has an HDMI port, you hook it up using a standard HDMI cable.
Hope this helps.
Oct 16, 2009 | HP Pavilion dv9000z Notebook
How do i hook up my hp dv6500 LT to my hdtv?
for connectin it to TV u need a cable for it. like say HDMI cable. It comes very costly. and u should be havin a LCD tv..
Sep 03, 2009 | HP Pavilion DV6500T 15.4" NOTEBOOK LAPTOP...
Screen went blank after hooking computer to it
Let's cover the obvious.
The TV works fine with other inputs (cable TV), right?
The laptop is plugged into the VGA port on the TV and the input setting is set to "VGA", right? (or does toy computer have an HDMI port that you are using?)
Is it a laptop or a PC?
If it's a laptop and the TV is connected correctly and functioning otherwise, you need to turn on the remote display port of your laptop. It's a key sequence that toggles from laptop -> external -> both.
If it's a PC, it might be a signal incompatibility. Try different resolutions or refresh rates.
Good luck.
Aug 09, 2009 | Insignia 37" LCD Flat-Panel HDTV
Lenovo T60 interfacing with Vizio HDTV using RGB cable
The X1400 supports Full-HD resolution. Full-HD/True-hd (1920x1080)
The best output would be via DVI but you are limited with the VGA port.
I would purchase a Grand Hi-Wire PC to HDTV converter from www.globalcomputer.com. Item # G126-1036 @ $139.99
Thanks, Joe
Nov 04, 2008 | Computers & Internet
Dell Inspiron 1501 Notebook Logo
81 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
