Question about Garden
Toro riding mower model 268, replace transission belt
How can I get instructions on how to put a new transmission belt on?
SOURCE: need to replace belt on deck of john deere riding mower
does the belt on a 42" scotts lawnmower go behind the tenisoner or in front of it?
Posted on Jul 25, 2009
bargainbin2
  • 123 Answers
SOURCE: replacing deck belt
Here ya go.
Posted on Aug 26, 2009
mickey813
  • 472 Answers
SOURCE: the deck belt on my ride on mower - murray
21a49d6.pngHOPE THIS HELPS YOU LET ME KNOW
Posted on Nov 19, 2009
Testimonial: "Thanks for the info. Really clear diagram and easy to follow which was great."
mickey813
  • 472 Answers
SOURCE: We have a Weatern Auto Wizard Riding Lawnmower.
19c5756.gifHOPE THIS HELPS LET ME KNOW
SOURCE: instructions for replacing deck belt for
when engaging my blades on my craftsman lt4000 12.5 hp lawn mower the pullys wont engage them
Posted on Jun 30, 2010
Toro model 20332. Have put new transmission, belt and new drive wheels on back. When I use the personal pace bar it makes a grinding noise. Doesnt make noise unless I push that down.
Sounds like either the gears on the wheels or ends of the trans shaft are bad, or the internals of the trans are bad. Are the parts actually new-new, or used and new to the machine, you didn't specify. What happens when you manually spin the pulley on the top of the trans in either direction?
Aug 14, 2016 | Toro 20332 22" Personal Pace Walk Lawn...
Not getting gas to carb. changed fuel pump, bypassed filter. hold gas line below tank and fuel comes out. but not being sucked through pump it appears. help
It has a pressure differential fuel pump, just put a little fuel in the carb. and it should start it may stall but do it 1 more time and then it will stay running as it uses the crank pressure to actuate the fuel pump
May 08, 2015 | Toro Garden
How do I replace a drive belt on a toro ride on mower model CV18S
+check with dealer, the service manager may help cheers.
Jan 12, 2015 | Toro Garden
Troubleshoot toro ridinglawn mower starts but refuses to move
If it is hydro-static check to see if the transmission is disengaged it should be located on the back of the mower.
Jul 16, 2013 | Mtd Garden
I need a manual or step by step instructions to change the belt on my Toro Personal Pace mower
The mower should be drained of gas and drain the motor oil before starting procedure.
Disconnect spark plug wire from spark plug.
Motor side of the belt:
Remove two bolts under the lawn mower body which holds the top cover over the drive belt.
Remove the belt guard that is around the pulley on the crank shaft.
Then work the belt around the blade and off the the drive pulley.
While blade is removed, sharpen or replace as necessary.
Transmission side of the belt:
Remove the "S" clip on handle for speed / traction cable
Remove the plastic "Rear Baffle" two screws on each side on frame in front of rear wheels one screw in the rear
With the baffle removed, rotate the drive shaft and transmission to gain access
to the pulley drive belt guard, it is held in place with three screws.
Once belt guard is removed, you can easily remove the drive belt
Reverse procedure to replace the belt.
Lubricate drive Axel bearings, wheel bearings, control cables, as necessary.
Replace all fluids as necessary.
Read more: http://wiki.answers.com/Q/How_do_you_change_drive_belt_on_toro_lawn_mower#ixzz1MMJlZFMZ
May 14, 2011 | Toro Personal Pace CARB Walk Power Mower
I HAVA A TORO WHEEL HORSE MODEL 71223, I PUT A NEW
The problem sounds like the tranny if the belt is correct.Thanks for asking and I hope it helps.
Jul 18, 2010 | Toro Garden
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
551 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
