Question about Dishwashers
Mtsui mf145 faulty door catch. the door is not shutting and i think catch is broken
2 Suggested Answers
SOURCE: Ariston dish washer door will not shut properly.
Check that something has not got wedged behind the top basket stopping it closing fully.If that is ok what can happen is that if there is something causing the door not closing fully ,when you try to close door to do a wash instead of the little hook actuator in the door switch fully engaging with the clasp on the body of unit,it closes down before it engages.It is like a finger hooking over say the top of your trousers.If you turn power off and get 2 small screwdrivers and carefully put them either side of the hook on door then try to bring it back to its open position.
Hope this helps.
Posted on May 17, 2010
Drivers door wont catch and can shut or lock car.. all others are fine. Any ideas?
Car Door Won't Close or Stay Shut - JamesMaurer.com
https://www.jamesmaurer.com/car-door-wont-close-or-stay-shut.asp
If your car door won't close or stay shut then this quick free fix is just for you! ... It's a great day when you can prove to your child your not as old as they think you are :) .....It's pouring outside and my rear passenger door latch messed up. .... two doors and I couldn't shut them.. was worried I would have to catch the bus until we ...
Repairing a stuck latch on a car door - YouTube
? 4:24
https://www.youtube.com/watch?v=tQYWOK1q_iQ
Dec 22, 2012 - Uploaded by backyardmech
Fixing a stuck latch on a car door. Video shows that the door won't close, how to release the latch, the ...
Ford recalling 390,000 cars over door latch woes - Autoblog
Jan 16, 2016 | Cars & Trucks
Why door will not stay closed
Many of the latches have a tooth shaped catch. If the tooth part is broken off the latch won't catch.
Aug 10, 2014 | Samsung 1.8 Cu. Ft. Over-the-Range...
Micro wave comes on at times when the timer is not set and door shut, no problem if doo is left open
I think you will find it is either faulty door switches or a misaligned door catch.
Hope that helps.
Feb 27, 2011 | Magic Chef CMV1100 Microwave Oven
Door catch broken - door will not close. no sign of a broken piece. There was a bang and the catch just doesn't hold at all. door swings open
Door catches.
One of the latches has broken off and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Door switches
If one of the door interlock switches is not switching properly, that can cause the turntable/light to come on even though the "Starts" button has not been depressed due to the wiring of the switches.
Check for faulty door switches and/or contaminated actuators.
I hope that helps.
Jan 12, 2011 | Panasonic NNA554 Convection/Microwave Oven
I have a Kenmore 500 that shuts off if the load touches the door from the inside or wont start unless I press the door in again after its shut. I'm assuming there is a safety switch the door touches to let...
sounds like the door catch is loose,this is what holds the door shut,when the clothes are spinning they hit the door opening it enough to reset the door switch,there's a metal or plastic tab that goes into the catch,easy to install and part is cheap money
Oct 13, 2010 | Kenmore 500 6952 Dryer
Rear trunk door on '03 Audi A4 Avant does not properly secure.
the struts would have no effect on the catch at all. chances are the floor catch has moved inwards a little, re adjust to fit correctly/watertight.
Jul 11, 2010 | 2003 Audi A4 Cabriolet
I have a 2000 windstar...the left sliding door
The door is not catching to lock the door shut. Find where it is not catching and see if theres a blockage or if something is broken.
Oct 17, 2009 | 2000 Ford Windstar
Hotpoint aquarius 1000wm 20 I have to bash front door to start
I do not think it is the door lock that is faulty, more likely to be a weak or broken door spring or broken door catch.
I would replace these first,and then if it is still the same, then replace the door lock.
To replace the spring and or handle catch, undo all the screws that secure the 2 halves of the door, and prize apart the 2 halves,
Replace the spring and catch, reassemble the door.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Door won't shut
Is there sufficient spring reaction? Spring weak or broken? Has latch or catch moved? Is there adjustment on either? Is there debris stopping mechanism from working? Has door dropped?
May 11, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Washing machine door sensor
I must differ with you. This machine does have a computer control card located within the timer base assy. Thee 5 beeps are a response from the computer that informs of a faulty signal between the computer and the door sensor
Nov 09, 2006 | Roper RAS8445KQ Top Load Washer
Dishwashers Logo
Top Dishwashers Experts
