I have hp photosmart 1315 printer but the lead i have got does not attach to the laptop, any suggestions? also when i plug my sony memory card into the side it says card access error so i cant even print from the memory card? please help
  • hvth123 Oct 15, 2008
    That information was brilliant, thank you very much. Still no joy with the memory card though, i tried to format it but still no good but the link that you supplied said it may not support more than a 2gb memory card and mine is 2gb. As for the cable i dont know what a usb1 or 2 is. i presume 2 is the normal one in which i would use most things with ie camera, phone. is a usb 1 port look like something you would describe as a house shape? i am a bit clueless as you may be able to tell! if yuo understand what i am saying can i buy this cable as i dont have one? the only cable i have is simular to a scart lead with two screws either side (this is the cable that i have no port for on my laptop) Thank you again you have been brill
  • 111 Answers
I assume you mean that the connectors of the cable you are using aren't fitting either into the the laptop. I went to and looked up the printer's specifications. It seems like a USB 1.1 (but not a USB 2.0) cable should work. Here's the reference:
Product Specifications
Since you say the cable doesn't attach to your laptop, make sure the USB connector is correct side up before trying to insert it (I apologize if this seems too obvious, but I've spent plenty of time wondering why a USB cable wouldn't fit into this port or that only to realize that I was holding the connector upside down).
As far as the memory card error, there are a number of different causes, mostly based on the card manufacturer. You say it's a Sony card, so that narrows it down some. I found a web page that addresses general memory card error issues:
Resolving a Card Access Error
I'm going to post links to the several other web pages I found that are related to card access errors, just to make sure you have as much information as I can provide:
Card Access Error when using Lexar CompactFlash
Compact Flash Card Not Recognized by Printer
Card Not Recognized Error Displays on Control Panel
Memory Stick Memory Card Error
Most of these don't have to do with your Sony card, but it couldn't hurt to go over them if the suggestions in the initial link don't work out. Sorry to bombard you with so much information, but you never know what piece of data might hold the key to resolving this issue.
Good luck and post back your results.
Posted on Oct 15, 2008
  • tripwire45 Oct 15, 2008
    Unless your laptop was made during the dark ages (technologically speaking), it should have at least one USB port. The difference between USB 1.1 and 2.0 isn't really the cable but the specifications for transfer speed and such. Wikipedia has that info:
    Here's a picture of a generic USB cable. The "flat" end of the cable is what would attach to your laptop. There should be a "boxy-shaped" end that fits into the printer. The cable should have come with the printer as they're all pretty much the same:
    Picture of USB cable
    I also did a Google image search for USB cables to give you different views of what they look like:
    USB cable image results
    I found a little question and answer web page that tells you how to discover which version of the USB standard your laptop supports:
    How to tell if your computer supports USB 1.1 or 2.0
    In the vast majority of cases, it shouldn't really matter. The beauty of USB is that you plug it in and the vast majority of times, it just works (except for now, apparently).
    If the cable you're using didn't come with the printer or you suspect it's the wrong cable, you can go down to your local Office supply store with the name and model number of your printer and the name and model number of your laptop and they should be able to supply you with the appropriate cable. You might want to phone them first to make sure you are able to supply the information they'll need. Once they understand what you are looking for, you can travel to the store and purchase the cable.
    Sorry about the memory card. If the printer won't support it, your only option is to buy a card with less than 2MG of memory and try it out (keep the receipt in case it doesn't work for some reason).
    Sorry you're having so much trouble getting this sorted. Good luck.
Hp photosmart 3210 all in one memory card error no memory card is inserted but this error message persists
Try the same memory card in a pc to check if it works ... if it does then check the slot where the card gets plugged in... try a different card that also does not work means printer memory card slot is bad
Apr 29, 2010 | HP Photosmart 3210 Printer
When putting the memory card into the slot, the screen reads 'memory card error'. Also, will not read the camera when plugged into USB socket. Please Help!
The camera port only supports USB-equipped digital cameras that support Pict-Bridge. If you attach a USB device that is not compactible digital camera (or Bluetooth adaptor) to the camera port, an error message appears on the color graphics display. If you have an older HP-brand digital camera, try using the USB that came with the camera. PLug it into the USB port on the back of the HP-all-in-one and not into the camera port near the memory card slots, This works with HP digital cameras only.
By default, Windows XP will format a memory card of 8 MB or less and 64 MB more with the FAT32 format, Digital cameras and other devices use the FAT (FAT 16 or FAT 12) format and cannot operate with a FAT32 formatted card. Either format your memory card in your camera or select FAT format to format your memory card in a Windows XP PC.
Hope this helps.
Have a good day.
Nov 30, 2009 | HP Photosmart 2610 All-In-One InkJet...
I lost my software to instal in hp 1315 printer , now i want to download the hp software in order to use my printer
Go to this link and select your operating system and download the software.
hope u like the solution
plz vote if u like it...
With warm regards
Oct 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP Photosmart 2575 All-In-One, "memory card error", can not scan, only print. Please help!!
Hello, please try the "HP image zone" software that you can install form the CD included in the printers box, in order to scan. About the memory card, have you plugged a memory card to the printer?
Jul 29, 2009 | HP PhotoSmart 7550 InkJet Printer
The printer can not read my memory card
I think the maximum capacity of memory your printer will accept is 2gb
Jan 14, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error reading SDHC flash card in a HP Photosmart 8250 printer.
Purchase a SDHC to USB media converter (e.g. SanDisk
M/N SDDR-113-A10M), which allows you to plug that SDHC
memory card into the printer via the USB port.
Jan 03, 2009 | HP Photosmart 8250 InkJet Printer
Memory card error
Memory cards larger than 2 GB are not supported with Photosmart printers
Jan 01, 2009 | HP Photosmart D7160 InkJet Printer
Sony memory stick duo
Your memmory is not the correct for your camara.
May 13, 2008 | HP PhotoSmart 100 InkJet Printer
237 people viewed this question
