Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Lens error making pictures en suddenly lens error reset camera what can I do to fix it. Switc battery and / or card didn,t work greetings Annique
  • 489 Answers
Hi
What you are seeing is a generic message that means there is some sort of problem with the lens, it could happen in many different ways such as sand or dirt in the lens gears.
A couple solutions would be to either buy a defective camera online and make one good camera from the two if you can do that sort of thing yourself, or secondly have it repaired by somebody.
Don't bother trying to send the camera to Canon if it is out or warranty (though you can call them and verify what I'm about to say) because they will want $150+ to do the repair for you. Parts are not cheap to buy from them.
I know of one very affordable digital camera repair business... because I own it. The name is Darntoothysam, feel free to check us out, we are on that big auction website also (I don't plug their name for free), our seller ID is 'darntoothysam'. If you Google "darntoothysam" you will find us.
We have your repair listed as a package in our store for about $70. This covers a new lens, and return shipping of your camera! We even give a 45 day warranty on parts and labor. If you think you can use us then please check us out, even if you need to ask more questions then please feel free to contact me.
Hope this helps,
Thomas
Darntoothysam com
Posted on Oct 16, 2008
My Canon Powershot SD 980 IS has suddenly given me a lens error camera restart message. I have changed batteries, called Canon, used compressed air, try restarting with a/v cable etc. Whassup with that. It...
Hello and Welcome to FixYa!
Sir/Ma'am Lens error is because of several reasons and there are several solutions to fix up the Lens ErrorYou have tried One of the most common solution which Fix up the lens error like lens error is solved by removing the batteries and replacing it with a new set of fully charge ones, or Lens error may also solved by compressed air canister to blow around the lens area. This will result in the sand or dust particles to be blown out of the area between the lens and the barrel. Or Lens error also mostly solves by Insert the cameras Audio/Video (AV) cable, and turn the camera on.
You have tried all these but but problem is still there so problem is quite complicated, well i am suggesting you some more solution which may fix up the Lens Error:-
First of all if your camera allows you to work for minute then try finding and selecting the "factory reset" option to set your camera back to its original factory condition. On some Canon cameras, this requires holding the menu button down with the camera powered on for up to 10 seconds. However note that a lens error might sometimes override the reset option, and thus the option might not appear. So if you find the option then by resetting your camera to Factory Setting may fix the problem
If problem is still there then Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time, This may also solve the problem
Mostly Lens Error is also happens when Lens Barrel is out of position so Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots and it may fix the problem
If problem is still there then there are some other solution too which remove the lens error but all of then are technical and if you try to follow them you enter into the realm of potentially damaging your camera. There is definitely some risk in them, So i recommend that if your camera is still under warranty, before trying any of these, please please first contact your camera's maker or service provider. It will solve your problem quite easily.
I hope this solution helps you and you have clear picture in your mind.
Let me know if you have any confusion in your mind or if your camera is out of warranty and you can try some risky solutions.
Sir/Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Dec 02, 2011 | Canon PowerShot A460 Digital Camera
Camera will not take pictures. Message on screen says: System Error Zoom I have not had any problems with zoom. How do I fix or clear this message. Thanks, Marsha
Please follow the steps:
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine.
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec... in not done the press both Menu & self time key for 2 - 4 sec.
After all of this if you not success then its a lens error.The lens stuck from the inside becasue the lens guide pin is damaged or out of guide line. In this case you have to replace or repair the camera lens.
Hope helps; keep us updated and remember to rate this answer.
Jun 16, 2011 | Cameras
Error 2 in my coolpix 8800. I bought a new battery in the store they said to do that, didn't help an I changed the memory card as well, didn't help
hi your camera has system error, usually the lens unit doesn't reset after taking picture. it cause error message. you should contact to nikon service center and ask them repair cost. usually they will tell on the phone. thanks and best regard!
May 23, 2011 | Nikon Coolpix 8800 Digital Camera
Lens error :0x04110000 keeps coming on my camer when i am rying to take a picture
HI there lens error happens because of few reasons. If the lens guide pin damaged then you need to replace the lens. But before that try this & let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 02, 2011 | Pentax Optio E60 Digital Camera
Lens error, lens do not open
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jul 14, 2010 | Canon PowerShot A1100 IS Digital Camera
I have a Nikon s220 coolpix and everytime I turn on the camera the lens opens, makes a strange noise and closes - it does this 3 times and then I get a lens error message on the screen. Do you know what is...
Jul 02, 2010 | Cameras
Just says lens error and wont stop making grinding noise
Jun 16, 2010 | GE A730 Digital Camera
Lens error; restart camera
Jun 15, 2010 | Canon PowerShot SD600 Digital Camera
Lens error :0x01110000 That's what it says when
Jun 12, 2010 | Pentax Optio 60 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
134 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
