Washer commences cycle, but does not progress after filling with water. I've tried moving the dial round but it always goes back to start position.
  • ceeteei Oct 16, 2008
    indisit wib111 program starts then goes to emptying the washer and continues on that cycle for ever!
    thanks for elp Tee.
  • jjpc67 Oct 16, 2008
    Hi. It's an Indesit WD12X. Thanks.
  • 750 Answers
Hello jjpc67
Please send the model of your washer! So I may help you.
And ho wold is it?
Huuum
Posted on Oct 15, 2008
  • Neil Golan
    Neil Golan Oct 16, 2008
    Hello jjpc67
    How old is your washer?
    What is the error code???
    Check the pressure switch -the system that determines correct water
    level in the drum. Its a round item about 3 inches across with several
    wires connected, it sits under the top cover. Its an air operated
    switch which tells the machine water has reached the correct level.
    Disconnect the thin rubber pipe from the switch and blow down through
    it to clear any blockage. Switch itself may be faulty but its more
    likely the pipe is blocked.
    Also check the filter - generally located behind a panel at the foot of
    the machine.Some are obvious like little square hatches and some are
    hidden behind the trim panel at the foot of the machine. Once panel is
    removed the filter should be visible. Its generally a circular plastic
    fitting which unscrews in an anticlockwise direction. Some Hotpoint, Indesit and Ariston filters are located in the big black sump hose (the
    one that leaves the bottom of the outer drum and connects to the pump).
    Remove the back cover, locate hose, remove the tensioner clip by
    squeezing the tabs together, remove the hose, take out filter and clean.
    Review
    After 18 months
    my WD12X Indesit washing machine gave up the ghost, a repairman came,
    took one look at it, and said, it's an Indesit, they're always going
    wrong, it's not worth repairing. Searching on the web rapidly confirmed
    that indeed Indesit washing machines are always going wrong. To add
    insult to injury, my Indesit cooker (also 18 months old) went wrong the
    same week, which cost £60 to repair, and my Indesit
    diswasher is giving me cause for concern too. Indesit offered the usual
    fob off excuses you would expect, and in short showed no concern for
    the fact their machines break down so shortly after the guarantee
    expires. My advice, avoid Indesit like the bubonic plague, their
    machines are a waste of money.
Washer starts and then shuts off without washing clothes
If it starts and fills then tumbles, and time has moved off the display then a couple of things if water remains in tub something has lodged in pump/or it has stripped, and or if no water and not spin cloths soaking wet then the door switch....
Apr 16, 2014 | Whirlpool Duet GHW9150P Front Load Washer
WFL 2260 Fills hot, fills cold, no wash action, move control to drain, empties, move control to spin, no spin but goes thro. cycle ends program door unlatches, any suggestions?
Motor brushes, worse case scenario motor complete. Run the following motor test.
1. Put main dial to off
2. Press and hold start button whilst turning dial one click to left (easycare 30).
3. When display show 8.88 or two of the progress light come on, release the start button
4. Turn dial anticlockwise to 60 cotton (take the long way, NOT thru OFF or you'll have to start over)
5. Press start
6. Motor should rotate in both directions, pump runs, motor kicks up to full spin.
7. No motor action and two lights flashing on progress lights (separated by a light that's not on) indicates a motor fault.
As suggested brushes or complete motor.
Hope this helps
Mar 27, 2013 | Bosch WFL 2063 Front Load Washer
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
Wash cycle
What is the model number of the unit?
Dec 02, 2012 | Washing Machines
CI am having a problem getting our Miele G575 dishwasher to run through a wash cycle. It definitely has power, the water is on and there is no water in the bottom of the dishwasher. When you turn the...
You said it does not progress...meaning the dial does not eventually move? it may be waiting on a water level sensor to be tripped. The dishwasher is just not filling. The water valve solenoid may be stuck or defective. or a wire may have come off the valve solenoid.
Mar 08, 2011 | Dishwashers
I have a 15 yr old Whirlpool washer that has run great. During a cycle, it stopped full of water. I moved the dial around to different areas pushing it in and out and got a cyle to run long enough to pump...
Not always a Timer issue. could be stopping at the cold fill part of the cycle which is the 8 o clock position on the dial. This would be fault with the cold fill vavle.
Sep 15, 2010 | Whirlpool LXR6432JQ Top Load Washer
The machine continually goes through the cycle and then starts from the begining again by filling with water
The controller (big round button in the middle) is stuck. If you can't force it to end the cycle (tap on it, move it thru different positions and start the machine for each), then it must be replaced.
Nov 12, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washer does not progress through cycle
it might be the pressure switch which in part controls the cycles eg when water enters drum air pressure builds up through a tube connected to pressure switch which has electrical contacts.it is round in shape and if is the fault, it has to be replaced. regards
Jul 29, 2009 | Maytag Washing Machines
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Washing Machines Logo
    204 people viewed this question
    Top Washing Machines Experts
