Question about Hotpoint VBXR1090B Top Load Washer
Please help me with my washer
My hotpoint top loader washing machine won't spin water out. Model VBXR1O6OVOWW?
  • 750 Answers
Hello browneyez070
Welcome,
You said, your Hotpoint top loader washing machine won't spin water out. Model VBXR1O6OVOWW?
Common causes before considering repairs.
Water won’t drain
Drain hose is kinked or
Improperly connected on it.
Solutions
• Top of drain outlet should be less than 8 ft. above floor.
• Straighten drain hose and make sure washer is not sitting
Let me know if these measures help.
Huuum
Posted on Oct 15, 2008
  • Neil Golan
    Neil Golan Oct 15, 2008
    Try unplugging the washer for 5 minutes and see if it resets the system.
  • 1,543 Answers
If your washer fill, agitates, pumps out, but won't spin, then try this: Remove the front panel by using a putty knife to push in the clips at the top of the front panel at the seam with the washer top, about two inches in from the left and right sides. Pull the front panel forward and lift off from the bottom pegs. Now locate the clear tube at the left side of the tub. Pull it off, cut off an inch and a half, and put the hose back on. Test spin. What commonly happens is that gunk builds up in the end of that tube. The washer thinks it is still full of water because the air does not escape past the gunk, so the washer does not spin. Don't do this fix more than once or twice, as the hose will get too short. You can try to clean out the hose. This gunk build up is seen most often in machines which rarely see bleach. To help prevent this condition from reoccurring, every few months you can fill the washer to the smallest water level with hot water and add a few cup fulls of bleach. Run the cycle including the rinse before resuming your regular laundry.
Whirlpool top loader washer will not spin
Could be one of several different things depending on the age and model. If its less than 10 years old and is a top load washer its probably a motor coupling (connects the motor to the transmission kinda like a belt) or lid switch. If the water is draining out but the washer is not spinning its probably the motor coupling. If it still has water in it and won't spin, its probably the lid switch. If your washer is a front loader there could be several things going on. Hope that helps.
Aug 29, 2011 | Whirlpool Washing Machines
Whirlpool top loader model LSQ9010pw6 won't spin but does drain.
Sounds like you need to replace the Clutch Assembly- Complete clutch assembly for direct drive washing machines. Comes with brake cam driver. Includes blue spring for large capacity washers and black for compact washers.
this video should help
http://www.youtube.com/watch?v=tVc6SZ2DD4U
Aug 13, 2011 | Washing Machines
My fisher an paykel washing machine wont spin what shud i do its a top loader
check the machine pump that s brings out water maybe is block or u flush with enough water
Jul 06, 2011 | Hotpoint Aquarius WD63 Front Load...
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
My ge front end loader washer won`t spin water or pump water out
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
Hotpoint aquarius banging about when spinning
hi take the top of the machine and check the brick at top or bottom of the machine they sometimes come lose .
Sep 30, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Does not spin
the machine will agitate and pumpout the water but it will not spin
Aug 05, 2007 | Kenmore 23822 Top Load Washer
Hotpoint VBXR1090B Top Load Washer Logo
300 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
