Question about Whirlpool Washing Machines
Hello, I own a washer AWO/D 43136. It doesn't dry the water. The error that I receive on self-diagnostic is F03. Yesterday I did profilactics and I got error F25.
TAGTEL
  • 16 Answers
SOURCE: wd640 hotpoint washer dryer - error code F03
This indicates that the wash thermistor is "Open Circuit" and I think it is situated on the heater assy at the back of the machine.
Check the wiring and contacts between the thermistor and the PCB. If you still get the fault it could be the Thermistor ( which means replacing the heater ) or a faulty board.
If it is under 5 years old - Call Hotpoint as you have a 5 years Parts Guarantee mind you the call out is £89.98 but thats cheap if it happens to be the board!
Posted on Mar 16, 2008
huuum
  • 750 Answers
SOURCE: F25 error code
Hello twelsh2
Welcome,
You said, you started my washer and after a few minutes I'm getting this F25 code. Water starts to go in but it never starts washing. Any thoughts?
This is what F25 is telling you.
Condition
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down. If a failure occurs during high-speed spin, the door unlocks after 3 minutes.
Check and Repair
1. Verify the shipping system including shipping bolts, spacers and cables are removed.
2. Unplug washer or disconnect power for 5 minutes (Rests the system)
3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations
If you can not find the fault , Please call service.
We have service sponsors available in your area here in our web site if you need one!
Let me know what you find!
Huuum
Please remember to leave a rating!
Posted on Oct 13, 2008
  • 63 Answers
SOURCE: Kenmore f03 error message
check motor if noisy or hard to turn its motor, also check concetions to&from ccu board and mcu board . "less soap plz"
Posted on Nov 15, 2008
SOURCE: Whirlpool Duet Washer Trouble Code F25
TOP SOLUTION
The thing is most people have never used a washing machine before, its alright. If you like calling Whirlpool they will track your phone number and in the future they know you like to buy repair parts. The front load washer for the home is a new concept especially with steam etc. use patience and common sense. no washer can really wash 15 pairs of jeans and spin 150 miles an hour several times a week in this you must see the problem . so use common sense when filling the drum and do not use the highest spin cycle unless you are washing very light items. to fix f25 (happened to me after 1 month and I purchased a floor model) the fix is easy and does not involve a circuit board even though there are many buttons that light up. A repair man would love to order you any part you want plus markup, suggest the balancing mechanism and you will have made a new friend. give it up if you know you had to push on the door , maybe take a running jump to get it to close.you cannot wash a months worth of clothes all at once 1. unplug unit 2. remove 2 to 3 screws from bottom of front panel 3. next gently check connections, some may need tightening but again be patient and use appropriate pliers but mainly use gentle pressure 4.many will discover how simple it would be to work on the washer especially if you opted for the pedestals (worth every penny) 5. notice the drain trap cleaning access white and circular and turns, with a towel underneath open and clean trap at least once a year ...before replacing panel do a test rinse and spin. you will notice that once the f25 code appears there is no resistance to turning the drum this only helps to protect certain parts, once the appropriate wire is no longer loose this resistance is no longer...test but still be patient wait while the machine goes through the motions. don't start pushing every button. drum starts turning properly then replace panel. there is taped to the panel a manual with a breakdown of all the error codes. remember this is a very expensive piece of merchandise and will do for you what dry cleaners would have done for you (yes it has a wash by hand button and the machine will not spin to remove water in clothes on this selection, it will only turn to agitate , just remove clothes, hand wring out into the drum then hang or place in a plastic bag and refrigerate for a day or so until you can hang items)** I was able to my surprise wash a 110 year old linen tablecloth using this feature (soak items that require special stain removers and rinse before putting them in this machine. this machine is fantastic BUT be patient, and do not overload and do not spin everything on the highest setting. In being patient I was able to wash a king size comforter and the slip covers of a 90" sofa (not together) the machine can do this, not every day, but choose the correct setting such as bulky or heavy duty and select appropriate settings. I know for the money one should not have to take off the front panel but remember the machine weighs 200 pounds and coming from whatever factory one can only imagine what happens to machines that are abused in transportation. The key is to be patient and use common sense, if waiting on the machine to finish or the door to unlock ( the reason for the multiple locking steps is to allow those who have decided to get into the machine the opportunity to get out) then I will use the dreaded word of multitask otherwise enjoy the experience. I know I love mine!!!
Posted on Jul 20, 2009
  • 50 Answers
SOURCE: front load frigidaire washer w/ error code
The F03 code is a problem with your water system. your inlet valves may have failed.
Open up the bottom panel and you will find a tech sheet that explain the codes and gives trouble shooting techniques. here is the service manual, good luck, hope this helps......
http://frigidaireservicetips.com/pdf...icControls.pdf
Posted on Jan 06, 2010
After 3 days of snowing, my awo/d 6042 doesn't work. water and elect' supplies are good. there isn't water noise entering the machine
Pipe, tap or hose frozen up. Water inlet valve frozen or damaged. Make sure washer is turned off & unplugged, pour hot water on all water inlet components, allow to dry, re check.
Dec 18, 2013 | Washing Machines
Our Kenmore HE 2Plus Front Load washer model # 110.475*4753 is haveing an F03 Error and we can not get it cleared. Any ideas? We have hit stop twice, and cleaned the hoses, nothing clogging them..help
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 13, 2010 | Kenmore Elite 45986 Front Load Washer
Error code F03 flashing and beeping
hello,
what this error F03 code mean is an indication of over flow of water from the sensor reader temperature which might cost a chance of loose wire connection on the water temperature.
what you are to do to fix up the problem is to open (unscrew) the washer and then fix up the wire that have loose it position then clean up all liquid around the wire and the panel and (screen).then couple it pack make sure all power supply are OFF before doing this .
thank you.
Jun 12, 2010 | Bosch WFMC 3200 Front Load Washer
Describe your Kenmore 3.8 cu. ft. HE3 King Size Capacity Plus Front Load Washer Problem: F03 error message. Not clogged - anything else we can do?
Mar 14, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Front load frigidaire washer w/ error code F03....doesnt want to drain. Tried spin/drain, delicates, and normal and all end up with F03!! Please help!!! Thanks Royce
Jan 06, 2010 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool 6th sense washing machine doesn't go into high spin
sounds like you have a blocked hose/pump vent hole.......if its holding water in the bottom of the tub it wont spin it will try but the pcb wont let it do the spin .due to pressure switch telling its got water left... pull pipe off pressure switch check holes not blocked check all hoses......
Dec 30, 2009 | Washing Machines
My front load Kenmore washer has a f03 code on the screen. It is not draining the water and it is not doing a max spin. What do you think I need to do?
F03 error code means that there is either fill problem, a drain problem or a water level pressure switch failure .
First ensure the machine is filling.
When the drain system is causing the F03 error do the following.
Ensure that the drain hose is not kinked or clogged.
If the drain hose is OK check the drain pump.
Start unplugging washer from main and remove the service panel at the bottom.
Follow the instructions on manual to remove panel.
Access the water pump and remove the hoses, clear any blockage in there.
Use a container to collect the water, be prepared. If machine has lot of water inside, remove some water with a sponge before undoing the pump.
Sep 27, 2009 | Kenmore 46462 Front Load Washer
My Sears Kenmore washinging is getting an F03 code and will not drain - HELP
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly. The fabric softener dispenser works on a siphoning principle. Make sure that the siphon hole in the dispenser is clear and not restricted or plugged. You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it. Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer. You can use the diagnostic test described below to test the fabric softener dispenser. If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining. You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer. You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum. To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump as shown in the second image below. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Jul 29, 2009 | Kenmore Washing Machines
Hi have an electric Kenmore oven - did self cleaning and it started beeping with an F3 code
Jun 26, 2009 | Kenmore 30169 Electric Single Oven
Washing machine has a F03 code when it starts to rinse
Hi I would advise you to check the filters in the water valves and check them for being open circuit
Jul 18, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal De
