Question about Belkin Computers & Internet
How close do I have to be to the router for the wireless signal to be picked up? The Led light flashes but we cannot pick up the signal/.
    Scholar:
  • 136 Answers
The manual tells you the range of your router, but keep in mind that electronic devices and walls can severely reduce it. If your walls are made of stone, even if you are in the next room, it will be a very weak signal.
Posted on Oct 15, 2008
    Master:
  • 538 Answers
Usually those have a 25 to 40 meter range....if there is nothing in the way of the signal..i use 20 meters as a rule of thumb..
My laptop randomly stops picking up my wifi
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel. 2. Analogue video senders used to send audio and video to other TVs in the home. 3. Microwave ovens emit interference in the 2.4GHz band. 4. Wireless speakers and console controllers can cause interference with the wireless router. 5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem. 6. Power cables located near the wireless router can cause dropouts and speed reduction. 7. Fish tanks will cause massive Wi-Fi shadow on the other side of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflect wireless signal away your computer. 9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
Aug 14, 2012 | Computers & Internet
I need to unlock my router
Do laptops pick up the wireless signal and connect to your router? If not maybe you don't have the router configured for wireless.
If other devices such as laptops pick up the wireless router signal then there is no need to go into the router changing things because if you do, the things that work now, might not work.
Can your ipad see the wireless router (SSID) as one of the networks within range? If so, maybe you put the password in wrong. The password is case sensitive (caps and small letters must be exact or it will never connect).
Jun 02, 2012 | Linksys Wireless-G WRT54G Router
I have an 802.11g belkin card and it will not pick up a signal even if I am sitting right next to a router when I click on the program it tells me that I have encountered an error the green light on the...
check the drivers?
check to see if your "wireless zero config" is started? Goto Start/Run type in box "services.msc" scroll down to the bottom to where it says "Wireless Zero Configuration" make sure its Started, if not double click on it and click "start". Close when done.....
check for new wireless connections.
-mk3ride
Dec 30, 2010 | Belkin (F5D7011) 802.11g/b Wireless...
I dont know if my router is sending out signal but i cant pick it up with my laptop, xbox 360, or my cell phone. the wireless LED is steady on
Then it is probably hiding its SSID. log onto the router and unhide the SSID, you will then be able to see it
Sep 14, 2010 | Linksys WRT160N Wireless Router
No wireless signal from the router, overheating
its not desirable that the router should get Hot. Only suggestion is you can go in for a replacement
May 31, 2010 | Linksys WRT160N Wireless Router
I can not seem to get onto the internet with my Wireless connector for the xbox live it is trying to get a signal but is not connecting can you help. The connecter is flashing at Green but just does not...
make sure that you run the dvd it came with, that is the most important, then go into your setting on the xbox and pick your router out of the list, the green light should stop flashing when it picks up your router, especially if you have a password on your router, you will need to enter that in the settings screen
Feb 28, 2010 | Microsoft Xbox 360 Wireless Controller
Can no longer pick up router signal
Does the wireless light still lit on the router? You can try changing the channel on the router (1 6 or 11) ans moving the antenna. If those things did not work upgrade the firmware of the router and reset to factory default. Do not forget to save the configuration file before you reset to factory default.
Jun 30, 2009 | NetGear WGR614 Wireless Router
Panaonic BL-C20A Wireless network camera. All of a sudden I cannot get a green light meaning my computer cannot see it and it won't turn on? It worked fine for sometime. Now I get a series of Orange lights...
There are probably too many routers on the same channel in your area; very common problem. Too many routers on the same channel in close proximity causes interference and will cause wireless devices to intermittently disconnect from the wifi. To figure out if you have this problem, download wifi analyzer from the app store. Run it and you will see how many router signals are in your area and how many router signals are on the same channel. Xfinity uses channels 1, 6, and 11 for the 2.4ghz and these hotspots are everywhere! To fix this, log into your router and pick a channel that no one is using. I always set mine to channel 8 or 3.
Dec 09, 2017 | Panasonic Computers & Internet
Cant get wirless lap top pick up router
I know it sounds stupid but a lot of people just forget to turn on the wireless switch.
You may want to check first if the router is being picked up by other computers just to eliminate the possibility of a busted router. If no other computers can pick up your Router's signal then it's the router that you need to replace. If other computers can pick up your router's signal, then it's the computer's wireless card that's busted.
Sep 19, 2008 | Belkin Computers & Internet
Computers & Internet Logo
42 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
