I have an Alpha CB28 combination boiler and it is not working at all. The bottom neon indicator light is flashing every second and the helpline suggests it is a temperature sensor fault. I have had it replaced and it still does not work. It did work for a short time last night when the new part was fitted but today it has not worked. The boiler appears to fire up for a few seconds and then it clicks off again, so the light is only staying on for a short time.
  • Anonymous Jan 17, 2009
    , i have the same problem, as chris412
    Problem Solver:
  • 5 Answers
Try tapping the 3 relays on the pcb,"thats the circuit board under the front cover...
it sounds like a dodgy relay thats starts up the pressure fan in next to the flue....
maybe a dry solder joint,maybe a new relay needed....
its a common fault on this model..
Posted on Aug 02, 2009
Boiler ries to fire on heating or hot water but then shuts down after 10 seconds to F1 with the flashing red light, any ideas. clearly same principle as any boiler but I'm looking for someone who has...
that would indicate that the boiler is not firing up
If oil fired, been there done that
it is out of oil
the oil filter is clogged
the nozzle could be clogged/burned
the igniter wires need adj/replacement
if gas fired - similar issues but no experience
Dec 08, 2014 | Water Water Heaters
Worcester Boiler Greenstar 15Ri - The blue neon light is flashing - what does this mean?
http://www.worcester-bosch.co.uk/homeowner/literature/gas-boiler-literature/greenstar-15ri-literature. Hope this helps :)
Sep 19, 2014 | Water Heaters
Alpha 280e boiler
check out ur pump sounds like its scized up check it out give the pump a good hard wack if this sortis it u will feel and hear pump running if its scized up bad u will need to replace it
Sep 11, 2013 | Water Heaters
Alpha boiler cb24
Google Alpha boiler you should be able to down load a online manual with a ff chart in it . which should have codes in there for flashing lights .
Jul 29, 2017 | Water Heaters
Alpha boiler - wireless programmer failing
it sounds like the problem may be in the boiler and not the controller itself. Do you kno which is are the two wores that are the r-w for the thermostat take and purt them together and see if the boiler stays on or shuts off like it does with the thermostat. If it does then replace the reciever. If it doesn't then you have another problem. Good Luck
Jan 05, 2009 | Water Heaters
Fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Nov 30, 2008 | Bosch Water Heaters
Alpha H CB33 boiler A and B lights flashing won't start what do i do?
if the pressure gauge is showing below the green mark you need to top up the pressure by connecting the small flexi pipe underneath the boiler then turn the 2 blue taps located either end (slowly though) this will re pressurise the system and it should fire up straight away, hope this helps. KEEP AN EYE ON THE GAUGE THOUGH dont let it go to far above the green bar.
Oct 25, 2008 | Heating & Cooling
Heating & Cooling Logo
1,502 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
