Question about Motorola Talkabout T5800 (22 Channels) 2-Way Radio
Talk about frequency change
How do i get the frequencies to to correspond ? date on the units -15 oct, 1998. sn:165ayvbe51 mdl:P14SPA03P2AA
  • eradiostore
    eradiostore May 11, 2010
    I see by the category you chose you are referencing the T5800 model. I do not believe this model was around in 1998. So it is possible you have a different model. Please confirm, and it will assist us in helping you.
  • eradiostore
    Are both of your TalkAbout radios the same model? If so, it is possible we could locate an owners manual online to walk you through programming. If the radio has a simple name other than TalkAbout on the exterior of the unit, provide it also.
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Posted on Oct 18, 2011
  • Motorola Master
  • 1,654 Answers
I believe from your brief description you have the TalkAbout 250, 289 or Plus model. Here is a brief description of programming the frequency (channel):
1 With the radio ON, press the MENU button once. CHAN appears and the current channel (large number) will flash.
2. Use the SCROLL buttons to select a new channel.
3. Press the PTT button to set your new channel selection.
To set the interference eliminator CODE:
1 With the radio ON, press the MENU button twice. Current CODE will appear in the upper corner (small number) and will flash.
2. Use the SCROLL buttons to select a new CODE.
Your CHAN and CODE must match one another for your radios to communicate.
Posted on Oct 17, 2008
  • gherson May 14, 2011
    There is no MENU button or (LCD or LED) display on my mdl:P14SPA TalkAbout, only PTT, Monitor, on/off, and volume controls.
How do I change S022 frequency
They come set to a frequency the sticker on the helicopter and hand remote must correspond eg 27mHz both have to be same so if you wanted to change it you would need a new PCB circuit board and hand controller on the same frequency.
Kind regards, Julian
rccontrolfreak.co.uk
Mar 13, 2013 | SYMA Toys industrial Syma S022 Big Chinook...
I have old motorola talkabouts..and don't remember to change the channel. can you help? They are Yellow and have no screen on them...I can't find any model number on them. the date is Dec 1998 it...
Hold the push to talk(PTT) button while turning the unit on, it will talk to you. press PTT to change channel, push monitor to switch to codes, press PTT to change codes. When you have the correct settings press monitor and it will confirm settings.
Jun 13, 2011 | Motorola Talkabout FRS 250 (14 Channels)...
How do I change and select channels and frequencies w my motorola axv5100 two-way radio? Can it communicate with a motorola talk about?
This radio comes with programmed channels and tone codes programmed into it. Should it still be stock the the diagram below is what you will use. The tones programed into are there to prevent someone on the same frequency from interfering with your conversation. It's a way of isolating the frequency. These are adjusted by the A,B,C,D You will know what frequency it is by the channel indicated. As for weather or not it will communicate with a Motorola talk about the answer is no. This radio is a VHF frequency and the talk about is MURS.
Regards, Tony
Channel - Pre-Loaded VHF Frequency (MHz) - Code (Hz)
1 151.6250 67.0 2 151.6250 77.0 3 151.6250 88.5 4 151.6250 179.9 5 151.6250 None 6 151.9550 67.0 7 151.9550 82.5 8 151.9550 94.8 9 151.9550 179.9 10 151.9550 None
Apr 17, 2011 | Motorola AXV5100 2-Way Radio
My channels range from 76.0 to 90.0 on fm it will not go higher #. dealer said to replace
The frequency range on the unit indicate that it is a japanese model and those are the frequencies used in Japan. i do not know in which country you are in but in some countries you can find an inexpensive frequency converter that should not cost more than 15 to 25 $. this device allows the head unit to tune into all the frequencies but it will still show only the range that it has on the unit. I will agree with the dealer that told you to change the unit. But it all depends on your budget and most important is the availability of the conversion device in your country.
Feb 04, 2011 | Car Audio & Video
Will the MU21CV radio's work with the talk about radios?
Short answer, maybe. It depends on whether you have a 14 channel or a 30 channel Talk-About. The Motorola Talk-Abouts operate on the FRS frequencies (14 channel) or FRS & GMRS frequencies (30 channel). The MU21CV does cover a few of the GMRS frequencies. (see bold numbers)
GMRS Frequencies
462.500, 462.575, 462.600, 462.625, 462.650, 462.675, 462.700, 462.725, 467.550, 467.575, 467.600, 467.625, 467.650, 467.675, 467.700 & 467.725
FRS Frequencies
462.5625, 462.5875, 462.6125, 462.6375, 462.6625, 462.6875, 462.7125, 467.5625, 467.5875, 467.6125, 467.6375, 467.6625, 467.6875, 467.7125
MU21CV Frequencies
464.500, 464.550, 467.7625, 467.8125, 467.850, 467.875, 467.900, 467.925, 462.575, 462.625, 462.675, 464.325, 464.825, 469.2625, 469.500, 469.550, 462.7625, 462.7875, 462.8125, 462.8375, 462.8625, 462.8875, 462.9125, 464.4875
Nov 01, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
I need to know the Frequency used by the Motorola Walkie Talkie 2-Way Radio: SN: RA 3DWKKOBP3; Mdl: FV300
Here's a link to the instruction sheet for the FV300. It lists the frequencies for all 22 channels.
http://www.banoggle.com/products/motorola/manuals/FV300-manual.pdf
Oct 28, 2010 | Motorola Radio Communications
800 MHz frequency Mode problem
You have to program it TRUNKING mode when you enter the control channel frequencies. It is decoding okay as the MO shows motorola control channel and +DG means digital decoded and an OPEN group. You need to press the 'trunk' button everytime a talkgroup comes up that you want it to remember for future 'closed' group (-DG) talk groups. I suggest you go to 'RadioReference DOT com" and there are many forums there for your radio, as well as one or two YAHOO GROUPS specifically for your scanner. 73's
Jul 03, 2010 | Radio Shack Pro-2096 Base Scanner
Tv remote issue. I want to operate two identical devices but of course if the remote for one is used , it operates both devices. How can I alter one of the devices and it's corresponding remote so that it...
Unfortunately I doubt it very much, because even if you could change the frequency on one device, it would then not match the remote frequency and therefore not be operated by it. sorry to the bearer of bad news!
Dec 07, 2009 | Televison & Video
How to change channel
Spirit GT: Programming a Frequency to a
Selected Channel:
1. Press and hold down the Push-To-Talk
button while turning the radio on, wait for
approximately 5 seconds then release the
Push-To-Talk button.
2. Use Scroll button to select one of the 8
frequencies.
3. On a Spirit GT+, press the Monitor button.
4. The current channel will flash, press scroll
button to change channel.
5. After the second channel is selected, press Monitor button again, current
frequency for second channel will flash. Figure 16.
6. Use Scroll button to select new frequency.
Exit Programming Mode - 3 Ways
1. Press Push-To-Talk to exit completely.
2. Allow the Menu time to expire (10 seconds).
3. Press Menu button to go to code programming.
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/Spirit_GT_User_Manual_E.pdf
Jul 17, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
Can't get Hopkinville police radio on my scanner
I know that most frequencys did change, I had the same problem when all the police went to digital, I had to put in new frequencys.
Mar 31, 2009 | Radio Shack Pro-83 Scanner
Motorola Talkabout T5800 (22 Channels) 2-Way Radio Logo
1,204 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
