Question about Dryers
Diehl Timer 4 pin wiring
Can you please advise the correct wiring connections for a Diehl T85 Type 601 Timer. The 4 pins have location numbers 1,3,4,5 - 2 & 6 not used. When the timer is activated pins 1 & 3 and pins 4 & 5 become open based on multi-meter buzzer. This type of timer is generally used in dryers
  • Loafer2 Oct 15, 2008
    Thanks. It is not going into a Dryer. I just want to time control another piece of equip. I am assuming the active would enter and pass through one set of open pins and the neutral would return by the other set of pins. Which set is active and in which order - eg in 1 out 3 or vise versa - or doesn't it matter.
  • Dryers Master
  • 19,396 Answers
The documentation for this timer is not available for download, you can enquiry about this device here :
Posted on Oct 15, 2008
    Master:
  • 538 Answers
Well..the timer is used in a variety of dryers. which model is this one going to be installed in?
Connection diagram for diehl t85 typ 600
1) Copy following links.
http://waterheatertimer.org/images/Deihl-T85-600-wired-for-208-230-Volt.jpg
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#T85
2) 3-pin 5 amp service has 2 hot legs (wires) located across from each other on outlet.
Interrupt one hot wire and circuit turns OFF.
However live power potential still exists on remaining hot leg.
3) To turn off both Hot legs, use DPDT spring-wound timer such as Intermatic 60 minute FF460M or FD460M
http://waterheatertimer.org/pdf/039_FF-series-sell-sheet-with-wiring.pdf
Jan 05, 2013 | Diehl Hardware & Accessories
Wiring Diagram For Usb flashdrive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually ((red white green black)) make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
or
PRODUCT NAME
FRONTX USB Type A Internal
PRODUCT CODE
CPX101-2
BAY USAGE
Half of large bay
CONNECTORS
USB type A female
1x5 header connector female
CABLE
USB cable (UL 2725)
Length - 2.5 feet (762 mm)
WIRE ASSIGNMENTS
Red: + 5V / Voltage + / VCC
White: D - / Data - / USB -
Green: D + / Data + / USB +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current / Shielding
The S-GND wire is fatter and can be easily recognized. The connection of S-GND wire to the header pin is optional.
HEADER CONNECTION GUIDES
Diagram 1: On most motherboards, the USB header/pin-out consists of 9 pins arranged in 2 rows, which allows for 2 USB connections (i.e. USB1 and USB2). Normally, the pins for USB1 and USB2 are in seperate rows.
Diagram 2: Simply plug the connector onto the 5-pins row, and make sure that the pin assignments and wire assignments are matched correctly.
Diagram 3: Alternatively, you can plug the connector onto the 4-pins row, and leave the S-GND wire unconnected.
You might have to rearrange the wires to match with the pin assignments, or change the header connector if necessary, depending on the layout of the USB header.
On some motherboards, there is a NC pin in the USB header. You can connect the S-GND wire onto this pin. NC simply means "no connection" and NC pin is an "empty" pin.
2X5 PINS HEADER
Refer to the diagram below, for 2x5 pins header, simply plug the connector onto one row of the pins, and always make sure that pin assignments and wire assignments are matched correctly. You might have to rearrange the wires if necessary.
2X4 PINS HEADER
Refer to the diagram below, for 2x4 pins header, simply plug the connector onto one row of the pins. Please note that there is no S-GND pin in this header. You can leave the S-GND wire unconnected. You might have to rearrange the wires if necessary, in such that the wire assignments and pins assignments are matched correctly.
ACTIVE PINS NOT IN THE SAME ROW
On some motherboards, the 4 active pins are not located in the same row, as shown in the example below:
To connect to this type of USB header, you need to change the header connector to 2x5. Simply rearrange the wires within the 2x5 connector to match with the pin assignments. If the green wire is connected to the USB2+ pin, the white wire must be connected to the USB2- pin. The red wire can be connected to any +5V pin, and the black (GND) wire to any GND pin. If there is no S-GND pin provided, you can leave the S-GND wire unconnected.
hope it helps
Sep 23, 2012 | Lexar Media Echo ZX 32 GB Flash Drive
How do i wire diehl t85 type 600
1) Copy following links for wiring Deihl T85 600 timer.
http://waterheatertimer.org/images/Deihl-Type-600-T85-timer.jpg
2) This timer will turn off Hot wire in 120Volt circuit.
3) For 208-230 Volt applications, the timer will operate by turning off 1 hot leg. However other hot leg will still have live power. To turn off both Hot legs, use DPDT spring-wound timer such as Intermatic 60 minute FF460M or FD460M
Feb 28, 2012 | Diehl Hardware & Accessories
I LIKE TO KNOW HOW TO KNOW WHETHER THE PRODUCT IS STILL FUNCTIONING OR NOT? PLEASE ADVISE. SHOW ME HOW TO DO THE CONNECTION OF THE IDE CABLE TO THE HARD DISC AND THE POWER CABLE? HOPEFULLY THESE ARE NOT...
No product support question is stupid, Peter.
1) An IDE cable should be plugged in with the Number 1 socket hole in the IDE cable's connector, going on the Number 1 pin on the harddrive.
Number 1 pin on an IDE optical drive, or harddrive, is next to the 4-pin power connection.
http://en.wikipedia.org/wiki/File:Hard_drive-en.svg
Illustration which shows the back of an IDE (PATA) harddrive.
See the area marked as IDE Connector?
Two rows of pins.
Next over are the Jumper pins in the Jumper Block.
Finally, next to the Jumper Block is the 4-pin power connection.
To make sure the IDE flat ribbon cable, is inserted into the harddrive in the correct position, a Locating Lug is usually on the IDE flat ribbon cable's connector.
A small rectangle, or two bumps side by side, on the top edge of the connector.
http://en.wikipedia.org/wiki/File:ATA_Plug.svg
This Locating Lug lines up with a cutout, in the circuit board of the harddrive.
A Locating Notch.
Sometimes there isn't a Locating Lug.
In this case look at the side edge of the IDE cable for the faint Red stripe.
This red stripe is on the same side as Number 1 pin.
http://en.wikipedia.org/wiki/File:Nappe.svg
So when you go to plug the IDE cable in, make sure the Red stripe is facing the 4-pin power connection.
Goes for an optical drive (CD/DVD drive), or a Harddrive.
(On the motherboard there are usually two IDE headers. {Connectors}
One for the Primary IDE device, a Harddrive, and one for the Secondary IDE device.
Usually an optical drive.
Next to the Primary IDE connector on the motherboard may be PRI, or Pri, or Primary, or IDE 1.
{ In TINY letter/numbers }
Next to the Secondary IDE connector on the motherboard, may be SEC, or Sec, or Secondary, or IDE 2.
Sometimes only the Secondary connector is marked. This tells you the other connector is the Primary connector.
Number 1 pin is towards the marking. Primary, or Secondary.
The Red stripe goes towards the marking on the motherboard )
Also;
There are two rows of pins on the back of the Harddrive for the IDE cable.
With a cursory glance it may look as though there are two rows of 20 pins.
There is not.
One pin has been removed. One row only has 19 pins.
Generally, but NOT always, the matching socket hole in the IDE cable's connector, is blocked off with a plug.
An IDE cable only uses 39 socket holes even if there are 40 shown.
Also; NOT a good idea to put a Harddrive, and an Optical Drive, on the same IDE cable.
BIOS looks to see which drive has the Master Boot Record.
Windows master boot record.
This is on the Harddrive.
BIOS will look at both, the Harddrive, and the Optical Drive.
This slows the computer down, for one.
For two, BIOS may not find which drive has the master boot record, with both drives on the same IDE flat ribbon cable.
Harddrive goes to the Primary IDE cable.
Optical drive/s go to the Secondary IDE cable.
2) As for the power cable it is a 4-pin standard Peripheral power cable.
Often misnomered as a 'Molex' cable.
[Molex was the model name given by the first company to produce this connector.
It stuck.
Kind of like referring to an open-end wrench as a Crescent wrench ]
It is also a STANDARD 4-pin Peripheral power cable, because there two 4-pin Peripheral power cables.
4-pin Standard Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Note in the center photo the shape of the connector.
The top two corners are rounded.
Only plugs in, in one direction.
{The Yellow wire is a 12 Volt wire.
Red = 5 Volts
Black wires are Ground wires }
4-pin Small Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
Older computers used this power cable for a Floppy Drive.
Newer computers use it for a Card Reader.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 01, 2011 | Computers & Internet
Need wiring diagram SPST power to timer timer to light . two screws marked timer 1 nc 1no 1 com
Here are two possible solutions, since timers are made different ways:
1) Diehl timer has 5 terminals
Drawing below shows wiring for Diehl SPST:
2) Your timer might also be wired as follows:
Two screws marked 'timer' are for 120Volt Hot and Neutral that power the clock motor (in drawing above, these are terminals 1 and 2).
Another Hot wire connects to COM. (in drawing above this hot wire shown connecting to terminal 3)
Load wire connects to terminal NO (in drawing above this wire shown connecting to terminal 4)
3) NO is Normally-Open turns ON when tier turns ON
NC is Normally-closed is ON all the time, EXCEPT when timer turns ON. So NC terminal turns OFF when timer turns ON.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 31, 2010 | Diehl TA-4150 24 Hour Electromechanical...
How do i wire my diehl 880 ?
1) Here is Diehl 880 instruction manual
2) Diehl 880 is 120V timer
-1/2 HP
-1000 Watt tungsten. Tungsten means incandescent light bulbs.
3) Checklist:
a) Your load does not exceed capacity > Timer is too lightweight to control 1500 toaster oven.
b) You need 120V line coming from breaker box with black Hot wire and white Neutral
c) You need 120V line going to Load that also has black and white wire
d) Test each black wire to ground to see which black wire is HOT
4) Deihl 880 sell sheet pdf says 880 is available SPST (single pole single throw) -or- SPDT (single pole double throw).
-The difference is pole #4 on the timer.
-If you are trying to turn one circuit off just as another circuit turns on, then you need the SPDT
-If you are turning one circuit on-and off, then the following instructions are for you
5) Wire clock
-There are 5 poles > look for markings 1-thru-5
-If no marking, then poles 1&2 are probably spaced apart from other poles
-Connect Hot and Neutral wires to poles 1&2 >> this powers clock motor, they go on either pole
-Pole 4 not used
6) Wire timer
-Poles 3&5 are timer circuits
-Connect Hot line to pole 3
-Connect black wire going to Load to pole 5
-Connect white wire from Load to Neutral
Oct 01, 2010 | Diehl TIME CLOCK- 120V 24 HOUR
Need to replace a Diehl Typ 880, T85 120V 60Hz 15Amp timer what is its current model to replace?
The Type 880 is the exact replacement. Still available at most pool supply outlets.
Sep 27, 2010 | Hardware & Accessories
Dryers Logo
576 people viewed this question
Top Dryers Experts
