Question about Panasonic KX-T7731 Corded Phone
New to system, need to set up 3 voicmail exts.
I am new to this phone system and have been assigned to create three new voicemail boxes/exts. for the company. I dont know where to begin.
  • Anonymous Mar 28, 2014
    how to set number of rings before going to voicmail
  • Panasonic Master
  • 2,460 Answers
Begin with what do you have for a voice mail? If it's a Panasonic brand, you log in as administrator (mailbox 999) and create the mailboxes. It is usually done at installation, unless your installer closed them down to prevent fraud. It's option 6 1 1 and you enter the mailbox you want to create. If it exists, it will tell you so, if not, it will create one. Then follow the prompts to assign an extension to the mailbox, and give it a name.
The extension user then dials the voice mail access code and creates greetings and a name and sets the password.
Posted on Oct 15, 2008
Why isn't the message indicator on when new voicemail messages are in box?
the easiest suggestion is to move the answering machine (which is the base antenna) to a mid location between units to aviod static and/or any unit near a TV, move it across the room of just a few more feet away.
Jan 22, 2015 | Samsung Falcon iDCS 18D Display Phone with...
Voicemail is usually ext 200 or 300 if it's not assigned on a speed dial button. If your ext has a mailbox assigned the voicemail will greet you or ask for your code. If you don't know the code your voicemail administrator will have to reset the password or mailbox. If your ext doesn't have a mailbox assigned, then it will just give you the main greeting that outside callers get.
Jul 07, 2014 | NEC Lands Phones
Employee forgot his password and need to change the voicemail for new employee. Is there a way to reset the phone. Phone model is a Superset 4025. My phone number to the phone is (563) 690-3230 or email...
Each mailbox password is held in the system programming of the voicemail system. You need the system admin password for voicemail. Dial the access code for voicemail, if from a phone with voicemail then press * to get to the main greeting. At the main greeting dial * then the system admin mailbox number which is 99 for 2 digit ext numbers or 999 for 3 digit ext numbers or 9999 for 4 digit ext numbers then you will be prompted for the system admin passcode(default 1234). Press 2 for add/edit/delete (Never press 1 for new installation or you could delete all current voicemail programming and messages). Press 2 to edit mailbox, you will be prompted for the mailbox to edit, enter the mailbox number. Press # to skip to the passcode reset, enter the new passcode or press * to reset to default(999) then press # for each of the remaining parameters until you are returned to the mailbox menu which prompts for press 1 to add mailbox, 2 to edit mailbox, and 3 to delete mailbox, then hangup.
Dec 07, 2010 | Mitel Superset 4025 Corded Phone...
How do you set your voicmail on the lgneon
To set up voicemail, push and hold the number 1 key until it dials into your voicemail box, then listen and follow the prompts to create a password and leave a standard or custom greeting. If this doesn't work, contact your carrier to reset the voicemail on your account. Hope this helps!
Jun 20, 2010 | LG Neon GT365 Cell Phone
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#206"
the display should say Group Call Distrib Group:
Press 7 It will then ask for a line number
enter in 05
the display will say 1 assigned
press 3 VMS Line Cover
Do the same procedure (from #206 on) for line 6
Then enter #208
The display will say Line Coverage Ext Line:
Enter 05 The display will then say Data --
Enter in the extension you want the voice mail to pick up the lines on
Lastly if its not done allready, enter #301
The display will say Automatic VMS Cover Extension:
Enter in the extension number of the phone thats getting the voice mails
The display should say 1 Assigned
press feature "00" to logout
Oct 06, 2009 | Lands Phones
Nortel 7310 voicemail will not reset
You dont have the EXT of mailbox 222 assigned to ext 222. Go under F983 press mbox press chg press 222 press ok press next it was say EXT: see what ext is assigned to put in 222 press change enter 222.
If it tell you that 222 is already assigned you have to find the mail box it is assigned to. Usually involves checking every Mbox starting with 221
Hope this helps.
Apr 14, 2009 | Nortel Norstar 16-Line PBX Speakerphone
I want to disable a call from going to voicemail
Changing programming on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
enter in "#206"
the display should say group call distrib and Group:
enter 7.
the dislay will then say group call distrib 7 line:
enter the line number you wish to program in 2 digit format i.e. line 1 is 01 and so forth
the display should say group call distrib 7 L01 and 1 assigned
enter 2 on the dialpad (not assigned)
enter feature "00" when finished
hope that helps
Feb 12, 2009 | AT&T Lucent MLS-12D Phone
Add a personal greeting to voicmail
Dial into voicemail system and enter the section for greetings and set up a personalized greeting.
Dec 29, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Need to set up user voicemail box (new employee)
Go back to your vendor and get the password for mailbox 999 and the instructions to log into it.
The mailbox exists or it wouldn't ask for a password (they're assigned by default), so you need to go to mailbox 999 and chose option 6 1 3 which is mailbox administration reset password. That will clear the password and you can log into the voice mail automatically from the extension by dialing the voice mail access code.
Post back if you have any problems.
Sep 18, 2008 | Panasonic KX-T7731 Corded Phone
Samsung DCS Basic 12B phone voicemail
I assume you forgot the passcode to a voicemail box , not the pass code to the voice mail system. The easiest way to fix your problem is to enter voice mail programming(from a telephone) and delete the box and then create the same box again. That way the mailbox when created will come up with the system default pass code
Sep 10, 2008 | Samsung DCS 12 Corded Phone
Panasonic KX-T7731 Corded Phone Logo
336 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
