Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
D Link DSL-G624T router
How to filter the unwanted websites from the D Link DSL-G624T router?
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    well..websites are filtered at the broswer level..unless this one has a really good firewall..
  • 132 Answers
SOURCE: Cannot install D-Link router
You may try typing admin on the username field. Just leave the password field empty.
Once you're in the setup page, click on WIRELESS tab which on the left side of the page. On the Wireless page, you will see the wireless settings set in the router. You may also enable the wireless security on that page if there is not security enabled yet.
Please check this for your reference http://support.dlink.com/Emulators/di524/h_wireless.html
Hope this helps!
Posted on Nov 13, 2008
  • 57 Answers
1. check your wireless adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 just check the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
Hope this will help
Posted on Nov 27, 2008
  • 67 Answers
SOURCE: Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
Posted on Dec 10, 2008
Samyfam
  • 379 Answers
SOURCE: need drivers for DSL-G624t wireless router
If you're connecting to the router by ethernet cable or wirelessly, you dont need drivers unless you mean the drivers for the ethernet adapter and/or wireless adpater in your PC.
If this is what you're after, your PC's manufacturer's website is the best place to look if you dont have them on CD/DVD.
If you're connecting to the router by USB port, then the D-Link webiste should have the drivers for downloading.
Posted on Sep 13, 2009
elix0411
  • 3530 Answers
SOURCE: I have a d link
Welcome to Fixya
Try to turn off/on the dlink router first. Reisntall the driver of your ethernet adapter. check your computer's IP address by going to command prompt and type in ipconfig. This is to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router. If you have 169.x.x IP address, Reboot your computer, router (if present) and broadband modem together, then re-test your connection. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
Thank you for using Fixya!
Posted on Dec 26, 2010
Problems with DLink DSL-2730U URL Filter
You might want to put the IP address of the sites you want blocked.
Mar 15, 2014 | D-Link Computers & Internet
D-LINK G624T after saving parameters doen't answer anymore. Reset don't change anything. Wireshark doen't see anything from the router... Any advice ?
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Oct 01, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Pleasssssssssse help : on router G624T
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Jan 11, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Need drivers for DSL-G624t wireless router
Sep 13, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Need connect HP Officejet 7210 printer into wifi domestic network
Check your drivers at Driver Detective
If your computer does not recognize the printer, try going into your printers in the control panel and go to add printer and see if it finds it.
May 20, 2009 | HP Officejet 7210 All-In-One InkJet...
Hope this will help
Nov 24, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Hope this helps!
Nov 12, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
How do i connect a d-link dsl-g624t to sky broadband
you can connect a d-link dsl-g624t to sky broadband by connecting the wire in to the appropriate slot or you can connect your d-link into the PCI slot on your motherboard
Nov 01, 2008 | Computers & Internet
I have just got a d-link dsl-g624t router the company i got it from told me unplug my orange moden plug this router in to phone line run disk away you go have done all this try to log in says unable to...
unable to establish the WAN connection to your PDA? or via the ethernet cable to your desktop pc?
It would depend on the security settings you chose, whether or not you need to enter a wifi key, add the mac address etc. Your ISP should be able to troubleshot you through it aswell.
Mar 09, 2008 | RIM BlackBerry Pearl 8100
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
218 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
