Back to:
Tags:
Compaq PS/2 3-Button Optical Mouse
Mandrake 7.1 on compaq presario 12XL222 Problem to...
By Grant - usenet poster
I installed the linux Mandrake 7.1 on compaq presario 12XL222 but I have
some problems to configure Xwindows.
I have a video card "Trident Cyberblade 3D"
I use XFdrak to create XF86config file and I choose as screen "LCD 800x600"
but unsuccessfully.
An Idea would be welcome.
Regards
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 28, 2006
Thanks for Trying (70)
Beresford
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Gerard, I solved a problem with my Compaq Presario 12XL300 using the same
chipset. I put an explicit "Chipset cyberblade" line in /etc/XF86Config
immediately before the "Videoram" line, and it started working. I'm using
800x600 at a 40 MHz clock, and it's doing what I want it to do at that
resolution.
HTH
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Mandrake 7.1 on compaq presario 12XL222 Problem to configure Xvindows:
I don't want to Accept this solution
Solution #2
Not Rated (0)
LiZzIe
Rating: 0%, 0 votes
Hi everybody, I've just installed linux on ASUS 7300, with a 1024*768
LCD and a Silicon Motion LynxEM video card, but I can make xwindows
work. can anybody help me? do I need particular drivers or software?
Thanks in advance.
Thank You!
Solution #3
Not Rated (0)
Lizzy
Rating: 0%, 0 votes
Mine reports an 8-bit wide lookup table, but other than that it's
word-for-word.
I didn't have that option; Windows doesn't live here.
The error I got was when the section of /etc/.XF86Config looked like this:
|# Device configured by xf86config:
|Section "Device"
| Identifier "Trident CyberBlade (generic)"
| VendorName "Unknown"
| BoardName "Unknown"
| #VideoRam 4096
| # Insert Clocks lines here if appropriate
|EndSection
The X server would give me this output:
XFree86 Version 3.3.6 / X Window System
[normal startup stuff snipped]
XF86Config: /etc/XF86Config
(**) stands for supplied, (--) stands for probed/default values
(**) XKB: disabled
(**) XKB: keymap: "xfree86(us)" (overrides other XKB settings)
(**) Mouse: type: PS/2, device: /dev/mouse, buttons: 3
(**) Mouse: 3 button emulation (timeout: 50ms)
(**) SVGA: Graphics device ID: "Trident CyberBlade (generic)"
(**) SVGA: Monitor ID: "My Monitor"
[list of deleted modes snipped]
(**) FontPath set to "[snip]"
(--) SVGA: PCI: Trident Unknown chipset (0x8520) rev 106, Memory @ 0xf5000000, 0xf4100000
(--) Trident chipset version: 0xf3 (TGUI9430DGi)
(--) SVGA: Revision 106.
(--) SVGA: chipset: tgui9420dgi
(--) SVGA: videoram: 2048k
(--) SVGA: clocks: 28.32 28.32 28.32 28.32 28.32 28.32 28.32 28.32
(**) SVGA: Using 8 bpp, Depth 8, Color weight: 666
(--) SVGA: Maximum allowed dot-clock: 80.000 MHz
(--) SVGA: There is no defined dot-clock matching mode "800x600"
Fatal server error:
No valid modes found.
[snip remainder]
but when I edited the same section to read:
|Section "Device"
| BoardName "Unknown"
| Chipset "CyberBlade"
| #VideoRam 4096
|EndSection
it ran fine at 800x600x16M.
If that didn't help then I'm afraid I've just run out of ideas. Sorry.
Thank You!
Solution #4
Not Rated (0)
Perkins
Rating: 0%, 0 votes
First, thanks for this advice.
I have just tried it but unsuccessfully.
I tried the command " SuperProbe" and the result is :
First video: Super-VGA
Chipset: Trident (chipset unknown) PCI Probed
Signature data: 85201023 (please report)
memory: 2048 Kbytes
RAMDAC: Sierra SC1148{2,3,4} 15-bit orSC1148{5,7,9}
15/16-bit Hicolor
(with 6-bit wide lookuptable (or in 6-bit mode)
Windows 98 see the chipset Trident CyberBlade i1 AGP(77)
An other idea please ?
Regards
Gerard
"Robert Grizzard" <> a ??crit dans le message news:
7yy.net...
Thank You!
Can you Help with these Keyboards and Mice problems?
Keyboards and Mice
we have to make a program in C++, but we dint know yet the...
Keyboards and Mice
I purchased my mouse from an individual and I need to get...
Keyboards and Mice
My working Icons in my computer Advance settings Under...
Keyboards and Mice
Need to know how to perform certain Mac functions (see...
Keyboards and Mice
I have a Dell Pentium 111 Computer with Sound Blaster...
Loading problems.
Repair Service
Find Keyboard and Mice Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
