Question about Canon Office Equipment & Supplies
I have a Canon ip4000. My problem is that no matter how many times I clean and/or deep clean the print head, the 3eblk cartridge is not printing. I've tried changing the ink cartridge but it hasn't helped
  • Canon Master
  • 19,396 Answers
The print head may be faulty and in need of replacement.
Posted on Oct 15, 2008
  • Ginko
    Ginko Oct 15, 2008
    If there is dirt or dry ink clogging the print head, then you will need to remove the printhead and soak it overnight in printer cleaning solution , or in isopropyl alcohol.
    Alternatively you may use a cleaning cartridge to unclog the printhead.
    If that does not work the printhead must be replaced.
  • Ginko
    Ginko Oct 15, 2008
    Regarding the cleaning procedure, you can leave the printhead in cleaning solution or isopropyl acohol overnight.
    This procedure does not always work, as the solution normally does not penetrate inside the pipes getting to the printhead.
    See this website.
    If
    you are sure the printhead is faulty, you can use a cartridge filled
    with distilled water, or better, with printer claner and use the
    cartridge to clean the printhead. See an example here: Print head cleaner,.
    If you decide to replace the printhead contact Epson for the part: Printer Accessories - By Epson - Replacement Parts or try Celtronics, Inc. Brother Parts, Citizen Parts, Epson Parts
Tip
How to unclog a clogged print head on the Canon...
Using a cotton swap dip into some plain water and then drop a few drops of water onto the outlet of the ink cartridge [you will have to remove the ink cartridge and turn it upside down].
Also while the ink cartridge is still removed, drop a few drops of water onto the inlet orifice into which the ink goes. The orifice of the ink cartridge sits right on top of the inlet to the print head when the ink cartridge is fully installed.
After putting the water drops onto the ink cartridge and onto the inlet orifice of the print head, I did the 'clean' procedure as listed in the "Canon PIXMA iP4000 Properties" of the program on my PC. Then I did the deep clean procedure. After that I printed the print pattern and found that this technique worked quite well -- since before I had tried isopropyl alcohol which didn't work to unclogged these print heads.
When I had the blue print head get clogged [on my Canon iP4000 Pixma printer] and I tried this method. It worked immediately.
I hope it works for you too.
God be with you!
engineer550.
on Jun 16, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Only prints black ink text; cartridges full and good.
Run head cleaning and deep head cleaning for few times. If it doesnt help, you can try to remove print head, and clean the nozzles with distiled water.
And after that also run few times head cleaning mode.
Jul 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
All of the ink cartridges are full, but the printing comes out very pink.
do the deep head cleaning for few times, it will drain some amount of ink but should work. After each cleaning check the printed nozzle pattern.
PS head cleaning is under printer properties-maintenance.
hope that helped
Jul 13, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
MAGENTA NOT PRINTING
The other week I had the black print head clog up, requiring daily nozzle deep cleaning [a normal 'ocassional' maintenance function]. Thought I needed a new Print head, so anything worth a try.
I loaded up an old black cartridge [I load all my own......always have] with Isopropyl Alcohol and ran deep clean on that cartridge a couple of times, then repeat printed [6 times] a page full of the number 8 in about half inch character size, to get the alcohol through the nozzles. then Deep cleaned again 3 times, to wash it through the print head.
I reloaded the normal ink filled cartridge and ran the '8' page again till I got good black output. It has now been working without problem, daily, for over a week. Clearly if it's a Magenta only problem, the cleaning as described above would be a bit different, as the magenta is one of 4 colour cartridges.
My printer does quite a lot of work, and was bought at least a couple of years ago, being used daily for alpha numeric and photo printing work. This was the first difficulty I experienced with it.
Hope the above might help.Ken
May 21, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Colours are not true, grey is brown
You are getting leakage from one color cartridge to another. Do deep cleaning and run nozzle check. You may have been using non-Cannon inks. They can corrode the ink cartridge seats due to inferrior quality ink. You may need to replace the print head. Check out Cannon web site under this printer support. Print head is in the $50 neighborhood.
Feb 10, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Print head remains clogged canon pixma iP 4000
I have successfully managed to clean the print head with isopropyl alcohol by placing a flexible plastic tube over the cartridge seat, filling the tube partially with the alcohol, then blowing very hard through the tube. The alcohol does not appear to harm anything.
Jul 12, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
old marine
old marine
