Yes, I want to connect my mp3 player to my kenwood z919 car stereo , problem being there is no AUX input to plug it into. I tried one of those transmitters and wasn't happy with it, to much static. Any suggestions? there was no option for kenwood z919 so I just put the KDC-Mp228
SOURCE: turn aux on on kenwood kdc-mp205
In order to access the AUX option the stereo needs to be in Standby mode. To do this just hit the SRC or source button until you reach the Standby option. Now hit the menu button and scroll up or down until you reach the AUX on/off option and just turn it on. Hope you find this helpful.
SOURCE: javyo
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
SOURCE: I need wiring diagram for Kenwood kdc-mp228 radio
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/
Just input your model number in the third search field, download the user manual, then look on page 25 for wiring connections. Hope this helps.
SOURCE: kenwood kdc-mp228 can't unlock, need master bypass codes
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
I would like to do the same thing. I'm gonna try to do rig something up today. I'll repost if I'm successful..
[email protected]
