Question about Emerson iTone iE600BK Shelf System
My alarm clock is way too loud.
So I have the iTone and I managed to figure out how to set the alarm and everything. one problem: when it goes off in the morning, it goes off at volume 20. i like to wake up to my iPod and enjoy the music, but that loud just scares me awake.
Is it at all possible to turn down the volume on my iTone's alarm or do i just need to accept that the alarm system wasn't well figured out and won't work for me?
Thanks a bunch!
  • kjmact Jan 08, 2009
    I have the GPX docking system H12817 and the alarm goes off on 30 every morning and I can't figure out how to change it. I pretty much go into cardiac arrest every morning (well maybe not), but it scares me every morning.
SOURCE: Emerson iTone iC200 Clock... Problem
I get no sound on either the radio or CD player. I need help.
Posted on Mar 24, 2008
SOURCE: Emerson iTone iE600BK Shelf System No power
did u fix it yet? and press the power circular button on bottom left?
Posted on Jun 04, 2009
  • 814 Answers
SOURCE: need to reset dual alarm to wake up Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson web page of the smartset clock/radios. Find you model number smartset clock/radio and open the link to download a pdf copy of the owners manual.You can use the print function on your computer to make a pdf copy of the owners manual for you own use. I hope this information helps you with your problem.
Posted on Jun 12, 2009
  • 814 Answers
SOURCE: Emerson Smartset Clock Radio setting for everyday alarm
You will need to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio and remove the internal battery (CR2430). Let the Clock/Radio set without any power source for at least 2 hours. Then put the internal battery back in the Clock/Radio and plug it in to the a/c outlet. Test to see if the Clock/Radio functions have returned to normal. If the function have not returned to normal, you will need to replace the internal battery. Then let the Clock/Radio again set with out power for a period of at least 2 hours. after a 2 hour period, put the new battery in the Clock/Radio and Plug it into the a/c outlet. Test the functions to see if the microprocessor has reset to normal operation. If you are still having a problem with the Clock/Radio's operations , you will have to give the Emerson customer support a call. The Telephone number for the Customer support is 1-800-898-9020. You can call them between the hours of 7am-5pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information helps you fix the problem with the alarm in the Clock/Radio.
Posted on Jun 13, 2009
  • 814 Answers
SOURCE: alarms
[] Copy this web link and paste it into the address bar of your browser. It will take you to the Emerson customer support web page of a pdf copy of the owners manual for your Clock/Radio. You can use the print function to make a pdf copy of the manual for your own use. To increase the sound of the buzzer in the alarm you will need to exchange the internal battery for a new battery. The buzzer works on this battery power alone. The model of the battery (CR2430) and how to replace it are in the owners manual on pages 41-44. If this fix doe not solve the problem you are having with the weak buzzer. You can call the Emerson customer support at this telephone number 1-800-898-9020. Between the hours of 9am-5pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information helps you with the problem of the weak buzzer sound on the alarm of your Clock/Radio.
The alarm is set and I do not want it go off anymore and I cannot find a way to clear it
About 5,060,000 results (0.64 seconds) Search Results
    Set or cancel alarms and snooze - Android One Help > Android One Help > Apps > Clock
    GoogleSet, delete, and label alarms Set new alarm or repeating alarm Open the. ... Open theClock app Clock . Touch menu More > Settings. Under "Alarms," you can ...
    How to Cancel the Android Alarm ' > ... > Start Up Businesses
    You can cancel your alarm after it goes off to stop that occurrence ... ... going off; turning an alarm off has to be done by managing the app's settings. ... Alternatively, you can tap "Snooze" to set the alarm to go off again after the ... Tap "Clock.".
    Setting and using the alarm - Bose
    Bose CorporationLearn how to properly set and use Alarm 1 and Alarm 2 by following these ... There are two alarms indicated on the clock display as ALARM (primary) and ...
    How do I set, cancel, and delete an alarm (including settings ...
Jan 30, 2016 | Home
How to set alarm for Westclox 47550 Quartz?
Hi, A 8 year old can do this. On the back of the clock there should be 2 round turning nobs. 1 is for to set time (min...) 2sec is for to set timer for that hour...usually is a smaller hand on face of clock.
select hour to wake up at and set alarm Button. This is only basic set up.
Jan 13, 2014 | Westclox 47550 Quartz Loud Bell Analog...
Have a bluehat time space projection alarm clock and the alarm won't turn off. Always goes to a snooze mode. Need help making it turn off. Instruction Manuel offers no help.
To turn off the alarm I pressed the alarm set button. While in the alarm set mode press the up button to turn the alarm and snooze off and on. That's what worked for us. Neat clock, the instructions are just a little lacking:)
Jan 19, 2012 | Toys
My Sakar Darth Vader helmet clock radio did not come with instructions. How do you get it to talk and not just play the radio?
When you set the alarm, turn the volume button on the front counter-clockwise (volume down) until it clicks. Darth will then wake you with one of three extremely LOUD, over-modulated soundbites or the electronic "beep-beep-beep" alarm . You can select the different soundbites/alarm with the "SELE-AL" button on the back. The only problem is, you can't tell which one you've selected until the alarm goes off. Cheap design.
Oct 07, 2010 | Sakar Darth Vader Helmet Clock Radio
I have lost the service manual for my Timex clock
I had the same problem with a another sound chamber unit but figured it out. there should be a radio buttton somewhere to turn on the radio, make sure AM/FM is set, the volumn is up and the tuner is on a station, make sure there is an antenna wire if there was a place for one.
next, try to figure out setting the time, and then the alarms one at a time. the calender thing, that's a bit harder! they are great clocks, but tough to program.
Aug 03, 2009 | Timex (T307S) Clock Radio
Instructions; TIMEX Alarm Clock Radio w/CD Player & Nature Sounds
Go to, select SUPPORT, then select PRODUCT MANUALS.
Jan 25, 2009 | Audio Players & Recorders
GE 7-4894A Need instructions on how to set the alarm.
The manual is at
Jan 16, 2009 | GE 7-4894 Clock Radio
Nov 17, 2007 | Emerson iTone iC200 Clock Radio
My wife has the AudioPhase SPR1 AM/FM 2 AAA portable sports type music player. There is no pdf manual available on internet yet - I will scan and post when I get time. The paper manual says:
To set the Clock:
1. Turn unit off.
2. Press MEMORY once: the clock will start flashing.
3. Press DOWN/MIN to set the minutes, press UP/HOUR to set hour.
4. Press MEMORY again to complete time set.
5. There is always an AM/PM indicator on the LCD display to indicate DAY or NIGHTTIME or night.
To Set Alarm:
1. Turn unit off
2. Press ALARM once: the alarm will start flashing.
4. When alarm time setting is complete press MEMORY 3 times.
5. The alarm setting is completed.
6. Now alarm standby is ON. ALARM indicator will now show on the display.
--> Alarm will only make a noise throught the headphones. When it goes off cancel it by pressing ALARM.
Canceling ALARM standy by.
1. Turn unit off.
2. Press ALARM twice.
3. Now ALARM standby is off.
To Seek press UP/HOUR or DOWN/MIN to click throught the frequency or press and hold to seek.
Oct 27, 2007 | Griffin Technology SPR1 AM/FM Radio
Emerson iTone iE600BK Shelf System Logo
95 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
