Question about Roper RAX4233PQ Top Load Washer
Washer stops mid cycle
Roper RAX4233PQ Will start and fill with water but then suddenly stop. I think the problem starts as it stops filling and starts into the next cycle. I have emptyed the washer 3 times and tried again but it has done it everytime. Some times if I turn the load size nob it will start again for about 2 seconds and then stop again. I have removed the knob cover and checked the wireing but it all loooks ok. Please Help.
  • 700 Answers
Theres contact points in the timer and down below wherer the wires go into the motor. check them and if you find them to be corroded you canm clean the with emery cloth then reassemble the unit.
Posted on Jan 11, 2009
My washing machine stopped working in mid-cycle. No agitation is going on and I could not drain it but putting to spin.
Make sure the washer fills with cold water from the beginning of the cycle because most washers have a cold only rinse cycle and if your cold water valve is bad then the machine will stop mid cycle because it cannot fill the washer for the rinse cycle. Secondly, it helps to know which washer you have so please enter more info next time you ask a question. Good luck.
Jun 28, 2015 | Whirlpool Washing Machines
GE WBSE3120 Washer stops mid cycle
if it makes a grinding sound when in spin this is the tub seals or bearing and basically you'll have to replace the washer.very common with this ge washer,not one of ge's best product,also why it stops mid cycle could be anything,this washer has a computer board biult on top of the motor that also failed,if your having all these issues i think that washer sold for like 500 dollars,it would cost more just to repair it,i wouldn't put 5 cents into it,do yourself a favor and get a new washer.
Dec 04, 2017 | GE Washing Machines
Roper washer will fill up with water and wont stop. What could be wrong?
The air hose from the tub to the pressure switch (inside the control panel) is either disconnected or plugged with debris. Open the control panel by removing 2 screws in the front corners and check for disconnected hose. Otherwise disconnect the hose and blow through it to see if it is plugged.
Jan 12, 2011 | Roper RAX4233PQ Top Load Washer
I have a roper whirlpool washer that only runs the water and then it stops, how can I repair this?
This is a common problem, your lid switch is to blame, the filling of the machine is only dependent on the timer knob being pulled out at cycle start. Once the machine fills and the level actuates the level switch to de-energize the fill valve, nothing else is going to happen until the timer motor powers up AND this is done by closing the lid to operate the lid switch, however if this switch is bad, the rest of the electrical circuit gets no power, and that is why your machine doesn't advance any further in it's cycle. Lid switch is mounted under top of machine and requires the cabinet to be properly removed for access.
Hope this helps
kcomp1863
Nov 29, 2010 | Roper RAX4233PQ Top Load Washer
Sometimes washer keeps running water & doesnt fill up. i have to unplug it for a few hours so it can work again...has happened on all cycles...what causes tub not to fill with water
water is siphoning out the drain hose ,drain pipe not high enough "must be 36 inchs"from floor or hose is inserted in pipe to far creating a suction situation ~once over the edge it cant stop...., may need a anti siphon kit on drain hose .
Apr 27, 2010 | Roper RAX4233PQ Top Load Washer
Have a roper ax6245 - cold water will not shut off even with washer turned off - HELP
Hello,Sounds like a problem with either the inlet valve or the pressure switch, the way to determine which is bad... while the machine is filling pull the power plug..if the water keeps filling it's the inlet valve that is going to be bad..if it stops filling it's going to be the pressure switch. The pressure switch is located in the control panel and has a small rubber pipe attached.once you have figured which it is replace it good luck.
If you have any other questions or concerns please feel free to comment again..Mike
Oct 14, 2009 | Roper RAX4233PQ Top Load Washer
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
WASHER FILLS AND AGITATES, BUT THEN STOPS, WILL NOT DRAIN OR SPIN
It may be a bad lid switch. Cheak with your meter for continuity.And if you need more info let me know.Also how old is the washer for there are 2 differant styles of lid switch dipending on how old the washer is. hope i helped :)
May 18, 2009 | Roper RAX4233PQ Top Load Washer
Cold water wont quit runnin after machine fills up
You'll have to replace the water inlet valve. Hope this helps!
Feb 10, 2009 | Roper RAX4233PQ Top Load Washer
Washer not filling
plz dont take this wrong but you say it fills and WONT STOP?? does the unit over flow on the floor?? or you need to let me know because the last part of your question states a diffrent problem..is the hot water valve on?//plz answer my questions and we can go on.
Feb 17, 2008 | Roper RAS8445KQ Top Load Washer
Roper RAX4233PQ Top Load Washer Logo
135 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
