Question about Refrigerators
True TDD-1 beer kegerator condensor fan not running
I recently had a series of power outages at my house and after power came on my True TDD-1 kegerator condensor fan quit working and my beer is warm, cleaned condensor and checked connections, fan inside is running but no condensor fan
  • 120 Answers
Cenck for volatge at wire harness and if you get the right volatge then repl condenser motor you can use a small portable fan just face it at compressor while you look for part and tha will kepp compressor from over heating and tripping the relay on it ok
Posted on Oct 15, 2008
I have a true TDD-2 and there is no air going up the tubes for the beer taps any suggestions
Look for something effecting air flow or the fan not running. First place to start.
Oct 20, 2017 | True Refrigerators
What is wrong in my tdd2 double beer dispenser, my beer lines are frozen ?
Yes it does sound like the thermostat is defective. Thanks John Tripp Appliance 911
Contact me Here
Nov 04, 2014 | True TDD-2
Kegerator not cooling
which fan , inside or out.. if outside condensor fan is running then it has a bad 175 capacitor or if the compressor is running then it is low on refrigerant. if the cond fan is not running then check thermostat.. you can do this by connecting the two wires together.. another way to check the compressor, cond fan is to reach under and unplug the wires going to comptessor and plug into a 12ga extention cord.
Nov 17, 2013 | True Direct Draw Systems: Kegerator...
Replacing true kegerator parts
no use a Ranco p# A12-700 make sure the capillary is in the coilto sense the temp and set it to 1.5 on the knob. any colder and it could get too cold . you may be able to set it at 2 but be careful. it is a constant cut in at 37 degrees coil temp. the box temp will drop to usually to 28 or 29 at cut out.
Dec 31, 2012 | True Direct Draw Systems: Kegerator...
Do true kegerator parts have to be replaced with true parts
Depends on what part you are looking for. I use condenser motors, evaporator motors, thermostats, and even compressors and capillary tubes that I sometimes get at local suppliers. If you're looking for gaskets, hinges, panels, tap heads or something like that it may be easier to get from True.
Dec 31, 2012 | True Direct Draw Systems: Kegerator TDD-3
TDD 2 Kegerator clicking and not cooling?
It's extremely rare that the compressor will be any good. Usually replacing the start relay does nothing on these small units. If you know how to use a multi-meter and are any good at wiring the cheapest way to go is to get what is called a 3-in-1 start kit at a HVAC wholesaler. You need to know the model of the compressor and/or the horsepower to get the right one. I would recommend getting a service tech to look it over though. Most likely the compressor is locked up.
Nov 16, 2012 | True Direct Draw Systems: Kegerator TDD-2
My kegerator recently stopped cooling. When I plug it in the fan starts up and then compressor starts for a second and there is a clicking noise and it turns off. I replaced the relay and start/run...
The overload relay is the likely problem. See if it is burnt looking or if it rattles when you shake it. Or just replace it. It's not expensive. If that's not the problem then it's the compressor.
Sep 22, 2010 | True TDD-2CT Beverage Cooler
True TDD1 freezes the beer?
yep can ya turn it off by the thermostat? its likely the thermostat can find one @ appliance parts give them model serial # or caseparts.com. good luck be careful. Tom
Jun 21, 2009 | True TDD-1 Commercial Beverage Dispenser
Refrigerators Logo
642 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
