Question about Zebra LP 2844 Thermal Printer
LP2844-Z - LPT Printing Problem
I have been using this printer with a wireless print server attached to the Centronics port and then configuring the machines to a local IP port for printing. However, now I'm switching to an application that requires a cabled connection to the Centronics port. I cannot get the printer to play along. When I set up the print driver, I try to send a test print and it just feeds labels to infinity. I have to turn it off to make it stop.
I tried to update the device to Zebra's latest firmware revision 45_11_7Z, but the device tries to print it instead... and of course just feeds labels. I've done this from both a command prompt and from Zebra's firmware downloader app with the same result.
I've tried to reset to factory defaults by pressing and holding the feed button until it flashes, but it never flashes... only feeds labels. This device has a manufactured date of 04/21/05 and has no USB connection, only Centronics and serial DB9. Any ideas on what's going on here? I've tried multiple IEEE 1294 cables on 3 different PCs running XP SP2, all with the same result.
Thanks for any ideas.
Duke
SOURCE: Zebra LP2844 on com1 long time before starts printing
you need to increase the baud rate of the serial port on the printer and pc, the default baud rate of the serial port is 9600kbp which is heaps slower then the LPT port which can rate atleast 100 times faster.
the reason why it is taking 45sec before printing is because the pc is sending a lot of graphics data to the printer, this can be cause by two main things
1) you could be printing a lot of logos or graphics .
or
2) you are printing using a nonhardware font so the driver has to convert all of the text into graphics. you can fix this by selecting a hardware font (has a printer logo next to it's name in word). also outputting EPL (the printers native command language) would be extreamly quick.
you could also download ZebraDesigner which includes drivers.
i would also recommend not updating the firmware as it can do more harm then good, and if you make a mistake you kill the printer and it voids the warranty
best of luck
Posted on Dec 07, 2007
itdude4321
  • 13 Answers
SOURCE: NEED THE DRIVERS FOR MODEL NO LP2844 ZEBRA
I have found that some times the zebra driver don't work well with Xp or Vista. Try these drivers :
http://www.seagullscientific.com/aspx/thermal_95.aspx
They have never let me down.
Posted on Feb 03, 2008
SOURCE: Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Posted on Mar 11, 2009
  • 32 Answers
SOURCE: LP2844 Printing light
You should first make sure the printhead is clean. If the printhead is dirty and you crank up the darkness, you will blow the printhead elements. Open the printer and from the bottom, you will see the printhead, which has a glass like appearance. There is a green strip from one side of the printhead to the other. Take a que tip with some rubbing alcohol and wipe it clean. I would make sure the printer is turned off before doing so. Just to be safe.
Posted on Oct 27, 2009
  • 185 Answers
SOURCE: My Zebra LP2844 will print fine from Zebra
If you are printing through a driver the raw output will be converted and printed. Please make sure you have the correct driver installed.
To send a single command can be sent via the Driver, right click the driver and select properties. Go to the Printer Tab and select Advanced and then "Tools". Click the Tools button and there is a dialogue box available to send commands directly to the printer.
Posted on Oct 29, 2009
My printer is not printing
Standard checks: If you are using Windows system up to Vista: Check all these:
Power cable, USB or LPT serial cable, the port to where you are printing in the printer properties configuration, (right click the printer icon) - (computers with multiple USB ports: unplug and plug into a different USB port and watch the printer icon change to ready in the computer/system/printers window- very subtle). Sometimes stored print commands from several days ago will begin printing.
Check cartridges, error light indications you can research on Google.
Jun 09, 2016 | Office Equipment & Supplies
Tip
INSTALLING A NETWORK PRINTER These instructions generally apply to all network...
These instructions generally apply to all network printers with built-in network cards (print servers) such as HP Laserjet printers, IBM Infoprint laser printers etc.
This example is for a network HP Laserjet printer.
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network).
Then set the Subnet Mask IP address to 255.255.255.0
If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer’s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
Do a test print page to check the printer.
You can now print from any computer on your network.
on Dec 06, 2009 | Computers & Internet
HPlaserjet 2600n without IP
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
Apr 16, 2013 | HP Color LaserJet 2600n Printer
Set up wirelessprinter hp
Jan 28, 2013 | Office Equipment & Supplies
Wireless printer configura
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc.This example is for a network HP LaserJet printer.To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.*** then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IPaddress range that the router issues to the computers on your network andconfigure the static IP address in the printer's network configurationaccordingly.
2. Install the HP printer driver onyour computer/s using the LPT printer port.
3. Connect the printer with a LAN cableto the network hub/router.
4. Click on Printers and Faxes - rightclick on the HP printer and click on Properties.
5. Click on Ports and click on AddPort.
6. In available ports - click onStandard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IPaddress of the HP's printer IP address.
8. Click OK and tick Enablebi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printerprints correctly.
Install the HP printer driver on every computer on your network and configurethe printer's TCP/IP port as previously detailed.Do a test print page to check the printer.
Jul 31, 2012 | HP Office Equipment & Supplies
Can we use MF6550 for wireless network?
If you use a wireless USB print server like this . Keep in mind that you may not get all functions such as scanning to work but it will allow for printing for sure. If the scanning works consider it a bonus.
Jun 11, 2011 | Canon imageCLASS MF6550 All-In-One Laser...
I have a retail store with 7 x Win 7 Workstations. i have 1 x Epson Tm-T88iii thermal receipt printer connected and installed on lpt1 port on my 1 workstation. We use a Dos application for our sales. The...
Hi, details below for creating a ersistent connection from LPT1: to you \\computer\\printername printer. Do the following on the other workstation that is not printing.
Use the net.exe command to establish a persistent connection.
To do this, use the following syntax at a command prompt:
net use lpt1 \\printserver\sharename /persistent:yes
where printserver is the print server that is sharing the printer, and where sharename is the name of the printer share.
For example, to map LPT1 to a printer shared as Laser1 on a print server that is named Pserver, follow these steps:
1. Click Start, and then click Run.
2. In the Open box, type cmd, and then click OK.
3. Type net use lpt1 \\pserver\laser1 /persistent:yes, and then press ENTER.
4. To quit the command prompt, type exit, and then press ENTER.
Note In Windows XP, non-administrative users cannot map an LPT port to a network printer path when the LPT port exists on the computer as a physical parallel port.
Apr 12, 2011 | Epson TM-T88III Thermal Printer
Netgear FWG114P Print Sever not functioning on upper level of LAN
if you set your dynalink's dhcp list up to a certain number (example: .1-.99). connect cat5 cable from dynalink lan port, into print server lan port. make sure print server can be setup as access point. if so, turn access point setting to on. make print server static ip address the next number outside of dhcp range (example: .100).
.100 ip address is the port number you should then be printing to, using a tcp/ip port.
if print server can be set up this way, then it now becomes wireless access point for all wireless devices. i am assuming, since you didn't mention it, that the dynalink is NOT wireless. if it is, the the print server just becomes another device on your existig network, taking the place of the network adapter the printer doesn't have. just set it up the same way you would set up another workstation on the network. except, make it static.
Apr 02, 2009 | NetGear FWG114P Router (FWG114PAU)
Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Mar 24, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
283 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
