My GE Front Load Washer (model WPXH214FWW) remains in the 'drain' cycle between the main wash and rinse cycles. It will only move to the next cycle if we manually advance the knob (slight turn)after which it automatically enters the final rinse/spin cycle and ends (unlocks) as normal. This problem occurs in both the 'Regular' and 'Permanent Press' cycles only and not the other 2 cycles (Quick Wash & Delicate). If the problem lies in the timer mechanism can this be easily replaced by myself or should we call a professional technician?
    Sergeant:
    Champion:
  • 435 Answers
Hi, Doesnt sound like time machinism.
It should move from drain cycle to next as soon as all the water is drained out.
This will happen when the outlet valve (electronic) closes and signals the system to continue to next cycle.
I doubt that this valve might be defective.
If not, the problem should lie with electronics.
Since you say it doesnt affect the Quick wash and Delicate cycle, I doubt if the valve is wrong. Sounds to me like electronic problem.
Its always better to get an authorized person (from GE) to have a look at it.
Posted on Oct 15, 2008
  • 1,543 Answers
Before replacing the timer, check the cold water inlet. Rinses usually use cold water only. The screen inside the valve, right where the hose screws onto the machine, may be blocked. If not blocked, check the inlet valve solonoid coil to see if it is open and in need of replacement.
I have an Amana washer model NAV3330EWW purchased in November 2004. The washer will not drain during any of the cycles, It apparently went through the entire wash without draining after the wash or...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2011 | Amana Washing Machines
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Bleach remains in bleach dispenser after washing and even after extra rinse cycle
I put the bleach in with the load right on top of the whites, so I dont have bleach left in the dispenser for the next load. Seems to work okay.
Jun 02, 2009 | LG WM-2277HW Front Load Washer
Washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Mar 21, 2009 | GE Energy Star WCVH6260F Front Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Washer will not go to rinse or spin cycle
electronic problem in timer board,not being electronically moved to next stage of washing
Jan 24, 2009 | Kenmore 43142 Front Load Washer
GE WASHER WON'T GO THROUGH THE DRAIN CYCLE AFTER WASH CYCLE
ck wiring to motor be sure all conections are tight lid switch is ok since will agitate also ck control bd for connections most likely suspect all ck ok is control bd itself
May 20, 2008 | GE WBB4500EWW Top Load Washer
Washing Machines Logo
122 people viewed this question
Top Washing Machines Experts
