Question about Microsoft Office Professional 2007 Full Version for PC
Conditional Formatting doesn't work until I select the item
OK, So I've got a report where each row contains a date. I want to be able to format the report so that if the status field is 'B' then it has red background, if its 'A' then has a green background, otherwise leave it as it is.
I've selected the conditional formatting option, and added the rules.
When I run the report, all the rows come out without the formatting *UNTIL* I click on the textbox with my data in, when the formatting appears.
Any ideas on how to get it to display the formatting all the time?
Access 2007 SP1
    New Friend:
  • 109 Answers
The mouser is equip with shortcut of any of program by using right click pointing to item.
Posted on Oct 18, 2008
How do I set up excel to change the background of a cell as the information within the call changes?
Conditional formating should be able to this. But how is your data organized? (Column headers, Row headers etc.)
Oct 20, 2014 | Microsoft Excel for PC
IS THERE A FORMULA IN EXCEL THAT WILL HIGHLIGHT CELLS THAT MATCH A NUMERICAL INVENTORY LIST?
One way would be to create a colunn C and use the formula: =COUNTIF(B$2:B$200,A2) in cell C2. Then copy the formula down to C200. (assuming you have 200 entries in B...). This will put a "1" next to every number in Column A that has a match in column B. Then you could put a conditional formula in column A that will highlight the cell if the value in column C is equal to 1. Alternatively you could also simply filter for 1's in column C and then manually highlight the cells that show up in A!
Sep 16, 2014 | Microsoft Excel for PC
Excel Conditional Formatting: how do I make one cell highlight based on whether or not another cell is blank?
option: formula is
formula: =(datecell="")
select formatting of choice
Highlight the order cells, go to >format>conditional formatting, choose "formula is" instead of "cell is". When you refer to the datecell, use the first date cell in the column only, and do not use $ signs.
Jan 09, 2013 | Microsoft Excel Computers & Internet
Excel 2007: Conditional formatting
did you put the sheet name in your reference? ex =Sheet2!A1 or you can name the cell ranges on the other sheets and use the cell names in your conditional formatting formla.
May 08, 2009 | Microsoft Excel for PC
Conditional formating to highlight problems.
in Excel 2007 and if you have a cell (say C2) with the value of elapsed time (for example set = A2 which contains start time plus B2 which contains end time - or current time) - click in the cell (C2) then on the Home tab click on Styles >> Conditional formatting choose Highlight Cells Rules>>Greater Than... set your value in the dialog to your respective value and choose your highlight. This is a start - you can then add new rules.
to then apply this same conditional formatting to every cell in that column Ctrl-C to copy the cell you just formatted - then click on the column header to highlght the entire column - Right-click and choose Paste Special - then choose Formatting for what to paste.
It's slightly different in Excel 2003 so let us know what version you are using.
Cheers.
Feb 27, 2009 | Microsoft Office Standard for PC
I have a year planner in excel in which first row consist of month jan,feb.... and in the second row days are there like 1, 2,3..... and on the very first column name of employees is there so my task is to...
There is always multiple solutions, but here is one...
Add a row (that can be hidden later if you want) where you have the full date (01/01/09). For this example it will be row "C." Then use Conditional Formatting with the function:
=weekday(C$2,2)>5.
See if this helps.
Jan 03, 2009 | Microsoft Excel for PC
Need Formula
TEXT CASE
Convert to UPPER, Proper or lower
Auto Convert to UPPER, Proper or lower
Stop VBA Being Case Sensitive
SELECT CASE VBA
Select Case Statement. Great alternative to Else If Statements
CONVERSION
VBA: CBool(),CByt(),CCur(),CDate(),CDbl()Double,CDec(),CInt(),CLng(),CSng(),CStr(),CVar().
Example
dDate=cDate("25-Jan-07")
Convert Numbers to Words
Convert Numbers to Dollar Amount in Words
Spreadsheet Converter. Versions: HTML/JavaScript,Excel ASP.Net and Excel Java/JSP. $
SQL Database Migration $
Converters. Database Converters, Spreadsheet Converters, Text Converters, E-mail Conversion, Document Conversion, PDF Conversion and more! $
CSV Converter $
IMPORTING
Import SQL Into Excel-SQL Tester $
Import Excel Into Access $
CONDITIONAL FORMATTING
More Than 3 Conditional Formats
Conditional Format Fonts for greater than 3
CUSTOM FORMATS
Custom Formats
Excel see a cells format as having four Sections. These are, from left to right: Positives;Negatives;Zeros;Text.
To hide zeros cell-by-cell use a Custom Number Format like 0.00;-0.00; where 0.00 is desired format for non zeros. Note the use of -0.00 for negatives.
To hide zeros on the Workbook level go to Tools>Options>View - Zero Values.
Dec 15, 2008 | Microsoft Windows XP Home Edition
http://chandoo.org/wp/2008/03/13/want-to-be-an-excel-conditional-formatting-rock-star-read-this/
Go down to the section about highlighting where there's an error. That's the basics of what you want to do. Now you need the code:
This will set a value of "True" if the string is -not- found inside. So if you want to flag it for finding the word NOT, you want the conditional formatting to kick in if the value of this is FALSE.
=iserr(find("NOT",A1))
Dec 06, 2008 | Computers & Internet
Deleting rows with odd row numbers in one go
I have found ASAP-Utilities to be excellent for this.
http://www.asap-utilities.com
After you download (free) and install, then in the ASAP menu, go to Columns/Rows, and select the first item ("Conditional Row and Column, select, hide or delete"). The options are clear.
Thanks
Proton
Sep 13, 2008 | Microsoft Computers & Internet
Microsoft Office Professional 2007 Full Version for PC Logo
64 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
