Question about Samsung CLX 3160fn All-In-One Printer
SSMMgr.exe For the last week whenever I turn off my computer, a window comes up that says it is shutting down SSMMGR.exe another message appears and says this program is not responding. Now I cannot get any thing to print. There seems to be a new file created: ssmmgr.exe-064Do47E prefetch I can't survive without a printer, I need HELP
  • supremecomma Nov 17, 2008
    Thank you, That made more sense!
  • 161 Answers
You need to completely delete and reinstall your drivers and Smart Panel software. Delete the printer from the [Printers & Faxes] menu in [Control Panel]. After that, go again into [Control Panel], then into [Add Remove Programs] and search (in alphabetical order) for the Samsung Status Monitor. Thenclick on [Remove].
After you are finished, reinstall from the original CD keeping in mind not to connect the unit untill the installation procedure tells you to do so.
Be blessed.
Posted on Oct 16, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
I don't know how long it takes for a solution to appear here. I posted one, then had to login, so not sure it got posted.
Anyway, the problem is the Windows firewall program, or any firewall program running on your local computer. The samsung monitor has two-way communication with the computer, and the firewall will stop the communication, which is why it appears to be non-responsive, when in fact it is disallowed from responding.
Turn off the Windows firewall and use a hardware router to isolate your LAN from the WAN. I posted a more complete answer, if it appears, then I won't need to elaborate further.
Posted on Nov 17, 2008
  • Jeff Towle
    Jeff Towle Nov 17, 2008
    Here is more info
    On the router, select an internal address other than the default, which is usually 192.168.1.1
    Use one of the approved PRIVATE address blocks from this list
    0.0.0.0 - 10.255.255.255
    172.16.0.0 - 172.31.255.255
    192.168.0.0 - 192.168.255.255
    Also, choose one that ends with .1, for example 192.168.10.1 and use a netmask of 255.255.255.0 so the LAN has 255 local addresses (Class C subnet).
    Then hand out addresses from 192.168.10.150 and hand out 50 addresses, enough for most SOHO (Small Office Home Office) networks.
    This is more secure, in my opinion, than running Windows Firewall, or any firewall on the computer itself, especially when your LAN has active devices on it (like the samsung printer, or a network attached storage device) that need to communicate to and from your computer. The Windows Firewall interferes with this, and caused me the same problem you are describing.
    Reinstalling the software may help, but I doubt it. Just remove the WIndows Firewall.
    If you are tired of seeing the Windows popup about how your machine is at risk, go to the control panel, run the Security Center application, turn off the firewall and under the Resources area on the left, "change the way Security Center alerts me" and remove the checkmark from the firewall, or the other items if you wish.
    If that doesn't fix the problem, go ahead and turn on the firewall and try to solve the problem another way. I ended up with McAfee personal firewall, and it does NOT interfere with my LAN access, and the firewall sort of comes automatically with the virus protection built into McAfee.
    Whatever you do, get a router between your LAN and the public WAN, that's a minimum requirement for safe use of the internet.
Rvhost.exe,windows can find this file...etc.that sentences always appear when i turn the laptop on.how can i solved the problem?
Follow these steps to restore your system files-
1. Shut down the computer.
2. Turn the computer on and immediately press F8 repeatedly until you get the "Advanced Boot Options" menu.
3. use the down arrow to select "Safe Mode" and press enter.
4. Window is should start with a "Help" window.
5. In the help window there is an underlined "What is System Restore?"
Click on that and "Click to open System Restore"
6. click on that and a new window comes up recommending restoring to a previous state.
7. Click ok and the operating system should restore your computer successfully and reboot into normal mode.
//javaftper
Aug 04, 2010 | Computers & Internet
Last night I turned my printer off by pressing the on button. The sreen said, " Shutting Down". I pressed the on button this morning expecting it to start but it didn"t. How do I start my printer? Thanks...
Try this:
1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off...
This message is caused by the hpcmpmgr.exe , program installed on most computers to support HP products, such as the HP Photosmart, Deskjet, and All-In-One printers. The error message is generated when the program becomes corrupt or conflicts with other system components. In order to resolve this issue, follow the steps below to install an updated version of hpcmpmgr.exe that will resolve this error (click the link).
Downloading and Installing the Update
  1. Click the "Download now" to begin downloading the update.
  2. When the File Download window appears, click Open to start installing the update.
  3. The Install Shield Wizard will appear and display information about the update. When the update has been successfully installed, a
    Thank you. You have successfully downloaded and installed the fix. Please restart your computer
    message will appear. Close all programs and click OK to restart the computer.
NOTE: In the event of an unsuccessful installation of the hpcmpmgr.exe update, the following message will appear:
Recommended update to resolve hpcmpmgr.exe and hpdarc.exe errors. There was an error while running the fix. Please try again.
If the product software is uninstalled and reinstalled at a future date, the patch will need to be installed again. HP Software Update will automatically offer the update for future downloading.
Let me know for the results. Hope helped with this.
Nov 19, 2009 | HP Office Equipment & Supplies
Eepc 900HA : Screen froze, then whent black. Activity and power lights still on. Removed battery/ reinserted and turned on. Got black screen with message " We apologize ... Four choices for restart...
good day.
with that problem may be your unit cannot shut down properly so as early as possible you must done with a proper shut downing of your unit.
so if that message will appear select on the "Last Known Good Configuration" and press enter, if this message will appear again you need to format your windows.
thanks...
Sep 10, 2009 | ASUS Eee PC 900 Notebook
Acer Aspire 8930 windows premium loses network/win exe
No, it is not a hardware error, it is purely software, i would recommend, trying to turn off your network\wireless adapter by switch, and then turning it on after a min or so.
Good luck
Jun 19, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Program not responding
A quick search of google told me that SSMMgr.exe is a program used by Samsung for monitoring the health status of your printer. It shouldn't be hanging your system though!
The first step would be uninstall and reinstall of the printer software and drivers, checking the samsung support site for the latest driver version if there is one and reinstall of the printers supporting software should fix it. Failing that you should be able to re-install the printer drivers without this SSMMgr.exe software monitoring program - more than likely just a simple bug in the software that came too light after a recent Microsoft Update or some other software Install or possibly an irregular printer event has disrupted its ability to monitor itself properly. Most printers have a flashing light or similar indicator when they're low on ink or out of paper or other, anyway the program SSMMgr.exe is the cause not RAM install, though it is possible that vital info for the program was stored on your previous RAM chip that could have been lost during your recent RAM removal and install, or was it install extra RAM only. No reseat or removal of any previous RAM chips occurred, did it?
Nov 07, 2008 | Dell Microsoft Windows XP Home Edition
My computer starts but before booting it shuts down.
You may have lost part of your windows program. If you have a system restore disk, you can run a system restore and probably fix your problem.
Some of your windows files have gotten deleted. When windows gets to this point all windows knows to do is restart. A virus can cause this problem.
Stargazer
Mar 16, 2008 | Gateway 310S (2900621) PC Desktop
Outlook problem!!
uninstall office completely, restart your system and reinstall office completely...
Mar 15, 2008 | Microsoft Office Outlook 2003 for PC
Audio driver problem
you have processor over heating...i already encounter that problem.
remedy
remove the cover of your pc..you need proper ventilation...
until now i dont have cover in my pc and its working fine for 3 years...
Feb 17, 2008 | Computers & Internet
Hard Disk Problem
bad power supply from on and off so much change that out
are u on labtop tho then u may have to redo it may gotten bug run trendmicro.com see scan for bugs do windows upidate
Jan 26, 2008 | Microsoft Windows XP Media Center Edition...
Software hangs
Tell Plustec this seems a common problem- perhaps there is a patch
Jun 22, 2007 | Plustek OpticFilm 7200i Film Scanner
Samsung CLX 3160fn All-In-One Printer Logo
2,091 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
