Although I bought a new printer cable to use with my Canon MP160, the printer only scans, it won't print. I tried turn off,rest, then on again; reset, start (both black and color buttons) and cannot get the printer to print.
  • 6 more comments
  • maryslarson Oct 16, 2008
    Is it possible to do this without the printer driver CD? In some household chaos, I cannot find my printer CD.
  • maryslarson Oct 21, 2008
    I went to your recommended site to downloadnew driver. It uninstalled the old and it looked like it was installing the new driver. However, now my computer thinks there is NO printer. I downloaded again, and again it says that the PIXMA MP 160 is not My Printer. I cannot get to anything else by going to start then Help and Support. At that site, it asks me to choose Canon, then on the right side it has no choice for the MP 160. The closest is the 150, which, when I selected it simply froze my computer. I had to hit CTRL>ALT>DELETE to log off.
    So I still have no use of my printer.
    I went to that site, went thru the download.
    Tried to print. Message says No Printer Installed. . .etc. go to Help and Support.
    This is the same experience I had with last week's attempt to download. (and going to Help and Support, . . .etc/., just froze up my computer.
    From my email, it looked like there were two solutions offered, tho I could only locate one.
    When I click on My Printer on my desktop, it says, The Printer that supports My Printer cannot be found.
  • maryslarson Oct 27, 2008
    Given that I have not heard from you for more than 48 hours, do I assume that the printer is dead? The warranty ran out in July, so I wouldn't be surprised.
  • maryslarson Oct 28, 2008
    In working thru an earlier suggestion, the one that said don't be too impatient, well I waited andthe closest to the Canon 160 was a Canon 190, so I selected that.Now I have a MP 190 installed,which of course doesn't work.
    Otherwise, I think the last Canon link offered might have worked.
    So, how do I uninstall the Canon 190?
  • maryslarson Nov 01, 2008
    Thanks much! Saved me time and money to avoid replacing the printer!
  • 1,879 Answers
First, stop using Windows Help and Support for any error that shows up, it mess up things completely.
MP160 driver from Canon's website
Click on the above link AND make sure you select the correct Windows version that you have. Then the driver link will show up (and it displays Drivers on top of it).
Keep in mind that driver availability is dependent on the Windows version that the printer can support.
Posted on Oct 27, 2008
  • 19,396 Answers
If the printer can scan, then it is not a driver problem, however drivers should be installed in any case, just to exclude possible software malfunctions.
Check also in installed printer settings, in control panel, that the printer is set up as default printer. Try printing a test page from control panel printer properties.
If printer does not even print the test page, and you reinstalled drivers, then it is an hardware problem.
Probably the printer head has dried out ink, or the cartridge is faulty.
Try first replacing the cartridges.
If that does not work perform head clean procedure a couple of times.
If it still does not work, then the printer head must be removed and replaced, or soaked in cleaning solution to clean it.
  • Ginko
    Ginko Oct 27, 2008
    Note 1: after downloading the driver file, you have to run the downloaded file, this will start an installer, and you will have to click next a couple of times.
    Note 2 : You need to unplug printer usb before running the printer software, the software setup wizard will tell you when to plug back the printer.
    Genius:
  • 1,142 Answers
Please try the following link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368
Posted on Oct 21, 2008
  • 6,487 Answers
The best thing that you can do here is to uninstall and reinstall your rpinter software from your computer to make sure all settings are correct and printer software are properly installed on your computer....
Posted on Oct 15, 2008
I'm getting a message from my Canon MP160 printer that says, "The ink absorber is full. Contact the service center." What can I do? Thanks
It's called E8 error.
Turn on your MP160.
After that press: Menu - Scan - Copy - Scan.
It will enter in Service Mode.
SERVICE MENU
NVRAM ACCESS
SET ABS-M LEVEL TO 0
OK
Then turn it OFF and again ON and there it is, as good as new.
Do you refill your cartridge by yourself?
Try "ROADINK" inkjet refill kit. No drill or sharp needle are needed.
It
Apr 20, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Hi I just bought ink for my printer and I PUT IN
First of all reste your printer: Turn off the printer, press and hold the red button 10-15 sec, if is not gonna work take a look at your cable it can be a little unpluged or somnt, if is not buy another cable. Good Luck
Oct 04, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Can't install my printer to my new pc...
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ppobmi9
Jul 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixma won't print documents
hardware problem...contact canon website
Dec 27, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon printer mp160 error msg 16 (e16) after replace catridge
try this PRESS STOP BUTTON FOR 5 SEC CAN FIX THIS PROBLEM
after that will adicated light alarm blinking them you can print if can't try turn off printer and turn on again.
Apr 17, 2008 | Canon PIXMA MP160 All-In-One InkJet...
I can't get the scanner to work on my mp160. The printer and copier work fine.
hi,
prirweto-i-13
Feb 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Scanner connection to the PC
i solved mine by replacing the usb cable with one that is 2.00 high speed and inti noise shelded benton-r
Nov 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
k24674
jasbo
jasbo
