I have a 13" TV/VCR combo and when playing back the tape there is a lot of snow. We have cleaned the player with the cleaning tape on the market, but this does not improve it. Thought it would be cehaper to buy one then to try and get it fixed, but stores no longer sell this type of TV. Thanks
  • 4,234 Answers
THe video heads are clogged. The cleaning tapes are useless. This unit needs to be cleaned by a professional. You need direct access to the heads which means that the set must be dis-assembled. There is high voltage inside the set even when off and unplugged. Figure on $50 or so for a cleaning.
Dan
Posted on Oct 15, 2008
Panasonic 13" TV VCR Combo Unit White PV-C1332W put tape in and plays sound but just static shows on all movies?
You need to clean the video head. With these types of sets it's best to use a tape cleaning cassette. I should get a Scotch Head Cleaner Plus tape currently on sale on Amazon for around 4 pounds.
Nov 22, 2012 | Panasonic PV-C1332W 13 in. TV/VCR Combo
Vcr gets sound but no video. dvd works fine
it sounds like the video head is dirty and needs cleaning, buy a vcr cleaning tape and follow directions on how to clean the heads... Radio Shack should have the cleaning tape....hope this helps.
Dec 29, 2009 | Philips Magnavox DVD/VCR Dual Player
Symphonic sc 1304 combo vcr records double images
I would try to clean the heads. Before I do anything else. You can buy a good head cleaner at Wal-Mart! Good luck with this.
Mar 12, 2009 | Symphonic SC313D 13 in. TV/VCR Combo
Go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
Nov 30, 2008 | GoVideo VR4940 DVD Player/VCR
VCR plays tape with only sound and some channels seem deleted.
Needs the vcr heads cleaned, and get a universal remote with a menu button to change the tuner setup.
Jan 25, 2008 | Toshiba MV13P2 13 in. TV/VCR Combo
Symphonic sc1304, vcr problem
Pulley belt stretched, replace. Remove the back cover to tv, slide the chassis out, remove speaker connector, and other ones to allow the chassis to be out away from cabinet to take the metal cover off surrouding the vcr unit. Usually a couple of screws that hold the whole vcr unit in, remove these, lift the unit from the chassis carefully and check the belt as it is stretched and not making tight grip on the white pulleys that perform the mechanical functions of the VCR. When putting back together, and replaced the belt be sure to lift the vcr door inward before sliding the chassis back into cabinet so the door latch will open and close properly, otherwise you put a tape in and the door won't open back up.
Jun 04, 2007 | Symphonic SC3813 13 in. TV/VCR Combo
Small TV/VCR Combo
Have you tried using a VCR VHS cleaning tape? Looks like a movie tape but its actually a head cleaner. You might have to try that several times.
Apr 27, 2007 | Kenmore 22642 Top Load Washer
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
