Question about Miele Touchtronic W1213 Front Load Washer
Miele W1213 Front Load - Cycle does not complete and main wash light blinks
The main wash light was blinking. I called customer service at Miele and the lady had me hold down the start/stop button, then turn on the power. once a DOT lit up on the screen, i push the start/stop button 3 times and hold down on the 3rd time until the green light starting blinking. After that the screen showed F and the 1.  Has anyone else run into this issue?  I looked in the manual for this error code, but there's nothing there.  Help.
  • dhe111 Jan 06, 2009
    I get F10 actually. It tries to drain but can't> Maybe water in the pan?
4 Suggested Answers
SOURCE: How to fix a Miele
check drain pump is not blocked if so clean out
Posted on Mar 15, 2008
  • 177 Answers
SOURCE: No Power lights, anything, on a Miele W1213
make sure the door is closed properly and push it hard as this completes the light circuit on the display and then allows the unit to work.
Posted on Aug 18, 2010
SOURCE: w1213, pre-wash and main wash
You are in the service mode now. The buzzer LED displays a flashing rhythm of 2 flashes while the ROM ID is show in the display(this is what you are seeing), press the buzz button to advance to the fault register level. Here is the manual to the tech manual http://laundry.manualsonline.com/mdownloads/89c212d9-4843-4409-b17c-b3439c9b0d05.pdf
Posted on Feb 21, 2011
Miele W1213 intake, drain and 3 - - - faults
Have had this since 2007 or 2008. Pain in the backside.
Fixed it by:
Cleaning drain.
Unplugging from power.
Tilting forward to drain water for 1-2 mins.
Made sure that the clear plastic light ***** in the rubber opening which located at the top was tight as it tends to get loose if you have an off-balance load.
Plugged power back in.
Boom, she started up.
This is a great washer/dryer, but it's expensive to fix if you need a repairman and it's a bit of voodoo if you need to do the above.
HTH
Nov 10, 2011 | Miele Touchtronic W1213 Front Load Washer
Front loaders door wont open
Unplug the power to the machine for 5 minutes, if that doesn't work time to call a repair service.
Mar 04, 2011 | Miele Touchtronic W1213 Front Load Washer
W1213, pre-wash and main wash lights flash with the 3 lines --- fault code. I tried entering the service mode as I read online I should push and hold start, then turn on the machine, wait for the dot and...
Dec 31, 2010 | Miele Touchtronic W1213 Front Load Washer
Used too much soap...miele flooded the floor....drain fault buzzer blinking what do I do?
by using too much detergent the float for water leaks inside the unit would have lifted and triggered the light to light. to clear the fault have some towels around the front of the unit on the floor and gently tip the unit forward and allow the water to escape. the float will drop down and you will be able to use the machine again.
any remaining water in the unit will just dry up. no damage would be done it happens all the time.
May 02, 2010 | Miele Touchtronic W1213 Front Load Washer
How to fix a Miele W1213 Touchtronics washer when the intake and drain light is blinking? power for drain motor is only 20V drain motor not working,but I am tested with 220V end is o.k.
Unfortunately you need a Service Rep out there to check the electronics - how old is the machine? - Warranty? the drain pump should be 220 or 120 depending on the model.
Jul 06, 2008 | Miele Novotronic Premier 500 Front Load...
Miele 2104 Washing Machine
If your model is displaying the same symptoms as the W1930 that I repaired, then the cure is to replace or check the brushes on the main drive motor ($17) and check or replace the bearings ($12). This is much easier on the pocket book. I was able to confirm the presence of drive voltage (25VDC) to the motor terminals prior to the removal.
May 25, 2008 | Miele Touchtronic W1213 Front Load Washer
Wash light is blinking
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or blown heating element caused possibly by a blocked pressure chamber.
Jan 08, 2008 | Miele Novotronic W1918A Front Load Washer
Miele Touchtronic W1213 Front Load Washer Logo
296 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
