Question about Frigidaire FRS26R4A Side by Side Refrigerator
Side side frigidaire glrsf266jwo freezer working refrigerator not
Pulled everything out of freezer and used hair drye to defrost the coils but they seem to be freezing up again
catriver
  • 878 Answers
SOURCE: refrigerator internal coils freezes
Shinmo, sounds like your defrost heater went south. Find out for sure. In the back there is a main board. Remove the cover, take a jumper wire with alligator clips. There will be a blue harness, 3 terminals on the board. The board will say, Line, def, comp. Jump line to def. You are now sending 120V. to the defrost heater. pull the back cover and see if the heater is coming on. If not, check for voltage at the wires connecting to the heater. If you have the 120V. replace the heater, part wr51x10055. If you don't have the voltage, it's the board. Catriver.
Posted on Aug 18, 2007
MNTECH
  • 1543 Answers
SOURCE: GE MDL:TBX25ZLB Top Freezer Refrigerator Freezes up
You need either a WR51X314 defrost heater, or more likely a WR9X413 defrost control (defrost timer) for your TBX25ZLB. Unfortunately, these part are listed as "No Longer Available". Next time you want to defrost it, find the defrost control at the back of the refrigerator section, very near the temperture set knob (the one that goes from 1-9). You will most likely have to pull the knob off and remove the cover to find the visible part of the defrost control timer. It is a round flat looking plastic part, usually black or white, smaller than a dime, with a groove in it which you can turn with a flat blade screw driver. Turn it slowly clockwise (they usually make a clicking noise as you turn them) until it makes a rather loud click. Now if the refrig was running, it will stop and turn on the defrost heater. If the heater is good, it should begin to glow red and heat until the frost melts or the timer advances back to the run position (usually about 30 minutes). (if there is lots of build up on the freezer, it will most likely take longer than 30 minutes of defrost heater operation to melt it all. You can help it with your hair blower, if you think you need to. ) All this will help to eliminate the defrost heater itself as the problem. A larger parts store may have a defrost control timer left in inventory, or be able to suggest a generic defrost control which you can use. In the mean time, you can defrost your refrig manually this way once a week or so for 45 minutes, then manually advance the timer again to the run position. (If the defrost control timer is bad, it usually will not advance itself back into run) Send a comment with how things turned out or if you have any other questions. Please don't rate this, as anything but a Fix-Ya lowers my score.
Posted on Feb 05, 2009
  • 190 Answers
SOURCE: Frigidaire Side-by-side not cooling or freezing
Dear customer,
We suggest u to do the follwoing checks,
  1. Hissing and popping is normal on frost free refrigerators, it is the defrost heater
  2. Check that the refrigerator is level
  3. Check the drain pan
  4. Check the condensor fan
  5. Check the evaporator fan
  6. Inspect the compressor mounts
As for th freezer's problem checkout the,
  1. Check the temperature setting
  2. Assure that there is enough room for air flow in the freezer or freezer
  3. Check for air flow restrictions in vents
  4. Test the temperature control
  5. Clean the condensor coils
  6. Check the door seals
  7. Test the door switch
  8. Test defrost heater
  9. Test defrost timer
  10. Test evaporator fan
  11. Check for a clogged drain tube
  12. Check for refrigerant leak.
Thank you. Plz rate the solution..
Posted on Apr 08, 2009
  • 25 Answers
SOURCE: Freezer not freezing
your defrost timer or defrost heater could be bad,
Posted on May 21, 2009
woodchuck789
  • 4070 Answers
SOURCE: Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Posted on Jul 01, 2009
Freezer does not defrost automaticly, its full of ice??
This is intended as a guide to defrosting a refrigerator that has the freezer on the top. Side by sides and bottom freezers may be similar but will require some different procedures to remove covers to get at the defrost coils.
If your refrigerator is not cooling but your freezer is still working then you most likely have a problem with Ice buildup. Sometimes the ice will start to form inside the refrigerator on the bottom of the freezer compartment, even though the refrigerator section is not staying cool.
1. Empty out the freezer section so that you can remove the bottom panel that covers the evaporator coils. Side by side refrigerators often have the access panel in the back of the freezer.
2. Use a hair dryer or fan to speed up the melting of the ice. Towels will be needed to soak up the water. A wet/dry shop vac and a hair dryer work the best. Melt with one and collect the water with the other.
3. Take the couple of screws that hold the defrost coil loose and remove the heater. With an Ohm meter check the resistance of the coil. If the coil is bad you will get either and open or shorted circuit. If you get a good consistent resistance then it is okay.
4. If your heater coil is good and the fan/blower is working then you probably need to replace the defrost timer or advanced defrost control board, whichever is in your unit.
Replace all pieces and wires to their original positions and then restart the refrigerator. It may take a bit for everything to cool back down, especially in warm weather. Now with everything working properly you should be trouble free again.
Take care in solving the problem....
Sep 16, 2011 | Whirlpool GB2SHDXP Bottom Freezer...
My refridgerator/freezer isn't as cold as its been. We cleaned coils, grate, everything. What next?
if freezer is okay...and its just affecting the fresh food..pull the freezer rear panel and see if its frosted on the coils..if so, use a hair dryer to melt the ice..it will work now, but you have a defrost problem and need to check the heater,defrost thermostat, and timer or electronic defrost control....
Jan 12, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I need to defrost my sub-zero 650. Can you give directions?
This is intended as a guide to defrosting a refrigerator. Side by sides and bottom freezers may be similar but will require some different procedures to remove covers to get at the defrost coils.
Good luck
Aug 08, 2010 | Sub-Zero 650 / O Bottom Freezer...
I have a Frigidaire PLHS67EEsb7 side by side. Every couple of months, something happens that causes the coils in the freezer to freeze over and the fridge and freezer stop cooling altogether. I have to...
clean out all the vents,syringe the drain holes with clorine bleach,check the door seals for air tightness all round...after a full defrost(do not help it with a hairdryer as this only defrost the ice you can see....try to defrost it when you can leave it for 24/36 hours....with the doors open and switched off....then dry thoroughly.
Jul 20, 2010 | Frigidaire PLHS67EESB Side by Side...
Side by side refrig. side not working;freezer freezing up
The unit is not defrosting. Either the defrost clock is defective or the defrost heater is not working. Defrost clock is normally located behind the bottom kick panel. Use a large standard screwdriver and turn the center screw clockwise very slowly until the compressor stops. Wait 20 to30 minutes the compressor should restart, if not the defrost clock is defective. Checking rhe heater you'll need a vom meter or amp meter.
Sep 12, 2009 | Frigidaire FRS26R4A Side by Side...
Frezzer side stop freezing but frigde side seemto work now freezer working again
Many, many times the reason a freezer stops working is because it's been open or ajar too long. The coils all freeze over and it will take a long time of being unplugged and open to defrost them. I generally take the back panel of the freezer off and use a hair dryer to warm things up. After defrosting, all moisture must be dried up before plugging back in. Now you have air flow over the dry coils and all the future foods will be happy.
Jun 24, 2009 | Frigidaire FRS266ZDSB Side by Side...
FRIGIDAIRE SIDE BY SIDE
Hi thanks for the question. your fridge isn't going in defrost cycle. locate the defrost timer, advance the timer to the defrost cycle . check to see if the defrost heaters are coming on. if not remove the back freezer panel. defrost with a hair blower, find a small disc on the coils .with 2 wires replace this part . its a defrost thermostat it stops the defrost cycle from coming on. thanks the appliance doc. please rate my answer.
Jul 28, 2008 | Frigidaire GLRS264ZA Side by Side...
Coil freeze up.
sounds like you have a problem with the defrost timer. usually they are at the back on the bottom of the fridge and have a little nob that is supposed to turn as a clock.
mark it and come back later to see if the timer moves, if not then there is your problem
Apr 10, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Dec 09, 2007 | Frigidaire Refrigerators
Frigidaire FRS26R4A Side by Side Refrigerator Logo
56 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
