Why does my washing machine have 2 drain outlets?
I just got this used washer and dryer set, both Maytag, the washer model is LAW9406AAE. Why does this washer have 2 drain outlets in the back? I am sure they both need connected but why 2? Is one the main drain and the other something else? The thing is the outlet hoses are different with one being longer reaching into the sink. Thanks folks.
  • plbrown01 Oct 15, 2008
    Thanks for the info, exactly what I needed! Now I can connect the longer more secure hose to the bottom main drain outlet. You are certainly a guru.
  • 1,543 Answers
This is a water saver or previously known as a suds saver model. The bottom one is the drain. The top one would go to a suds tub. If you set the machine on save, the wash water is pumped out of the top hose into the holding sink next to the washer. The rinse water goes out the bottom hose to the drain. The next cycle you could set the washer to the very beginning of the main wash cycle and the washer would pump the water from the tub back into the washer to be used as wash water for the second load of laundry. Yea, used water. But the first load would be lightly soiled stuff, and the next load would be old barn clothes or play clothes. It was designed to save water (about 65 gallons used for 2 loads vs. 90 gallons) and soap. (now, front load machines with larger tubs would use as little as 25 gallons for two loads.) Just hook up the bottom hose to the drain. Leave the save / drain switch set to drain and you'll be fine. To be extra safe (in case the switch was accidentally set to save) disconnect the wires at the solenoid where the drain hose splits into two at the back bottom of the washer. (right where the hoses exit the machine.)
Posted on Oct 15, 2008
MHWE200XW00 Accidentally unplugged unit while in cycle. Have technical sheet, ran diagnostic test, F1 E1 shows and 3 beeps. Released door manually. Clicking noise = power to CCU. Reset the computer?
Troubleshooting - Maytag MHWE200XW Use And Care ... > ... > MHWE200XW > Use and care manual
Maytag MHWE200XW Manual Online: Troubleshooting. of a service call... In U.S.A. In Canada ? Did you empty pockets.
Maytag 3.5 cu. ft. Front Load Washer (MHWE200XW) > Washers & Dryers > Washers
Shop for a Maytag 3.5 cu. ft. Front Load Washer (MHWE200XW) (MHWE200X) at Sears Outlet today! We offer low prices and great service.
Maytag , Whirlpool Washer Repair - Drain pump error, no ...
? 4:29
Jul 2, 2013 - Uploaded by
Service a Maytag Washer suffering from this following dilemmas: Drain pump error f9e1 At: http://www ...
Jan 24, 2016 | Washing Machines
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ... > ... > Home Improvement
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Why does my Maytag washer fills all the way to the top no matter what setting it's on?
Pressure switch or a restriction in the hose from the pressure switch to tub. You may just have to disconnect from pressure switch and blow through it.
May 13, 2014 | Maytag Washing Machines
Maytag centennial washer - not draining on some settings
Check outlet hose for kinks or restrictions. Make sure the outlet hose is free to expel water at full volume. Make sure the outlet hose is not mounted to high. Check pump impellor has all it's vanes intact. Check for coins in all hoses & pump.
Dec 21, 2013 | Maytag Centennial 3.2 cu. ft. SuperSize...
Model #MDE8057AYW I need to know how to get the lid off so I can see if I need a new belt
1.Unplug the electrical cord of the Maytag electric dryer from the electrical outlet.
2.Open the dryer door and locate the four screws on the inside,unfastening the screws with a screwdriver.
3.Pull on the corners of the top front panel,rolling the corners forward to release the clips.
4.Tip the front panel straight out and slide it up until the panel comes loose of the clips.
5.Set the front panel aside and slide the top of the dryer forward.
6.Lift the top of the Maytag electric dryer up,tilting it back and resting it against the wall.
Aug 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My washer is not draining. I used to be able to reset it and it would work but now it wont start on any setting and is full of water. Is there anything i can try.
If your Maytag washer is not draining, follow these procedures to find out what is the problem.Set the timer in the spin cycle and pull the knob to turn the washer on. If the washer motor doesn't run, check the following parts.
The wall outlet: Make sure that there are about 120 volts present at the wall outlet. Connect a good working hair dryer to see if it works.If the hair dryer works ok, then the problem has to be in the washer. If the hair dryer doesn't work, then look for a blown fuse or tripped circuit breaker.
The lid or door switch : The lid switch is a safety device use to stop the motor from running if the washer door is opened during the agitation or spin cycles. A bad lid switch could be the reason for your washer not draining.
The pump : Check for obstructions inside of the pump and inside of the tub.
Check the pump impeller, the pump belt, check the drain hose for any kinks. Any problems in these parts could be the cause for the Maytag washer not draining.
Lower the drain hose to a bucket to see if the water drains out. If the water won’t drain or just trickles out, most likely there is an obstruction on the pump or inside of the tub and that could cause the washer not draining.
To check the pump, remove the front panel, lean the washer against the wall and bail the water out with a plastic container.
To check the pump, remove the pump belt and turn the pump pulley to make sure that the pulley is turning freely.
Put a couple towels near the pump to catch any water from the pump. Remove the tub to pump hose at and check inside of the pump for any obstruction. If you find an obstruction remove it.
If you don’t find anything, reinstall the hose and remove the hose at the tub, and check for obstructions.
A Maytag washer not draining could be cause simply by a kink drain hose.
You need to make sure that when you replace the pump, you adjust the belts properly.
Jan 29, 2010 | Maytag Washing Machines
Maytag HAV2360AWW will not start
Check the back of the lid their is a litel plastic button to make sure the lid is closed see if not broken or stack
or see if drain pomp V belt is out of place or broken
this is the simple way
Dec 19, 2008 | Maytag HAV3460AWW Top Load Washer
Washing Machines Logo
1,421 people viewed this question
Top Washing Machines Experts
