Question about Frigidaire FEF366 Electric Kitchen Range
Frigadaire glass top range- keeps beeping than staying on
Yes we cook with the oven, than shut it down/off.
a few hours later we hear beeping, and check to find the oven is on. This is an electric range by the way. Any ideas? Finally unpluged it hoping maybe it resets or something.
  • 750 Answers
Hello sg22,
You said, Yes we cook with the oven, than shut it down/off. a few hours later we hear beeping, and check to find the oven is on. This is an electric range by the way. Any ideas? Finally unpluged it hoping maybe it resets or something.
You only need to unplug it for 5 minutes an if it resets that will do it!
What happened after the unplugging?
Posted on Oct 17, 2008
Oven won't stay on
I would say a fuse in cuircit board or something in the mother board
Dec 19, 2011 | Bertazzoni X30 4 GGV X Gas Kitchen Range
Hello... range reaches desired temp, food in oven, Beeps F-1, shuts down oven, food not cooked... huge problem kitchen aid supra electric range
You may need to see the secondary error code (F1-E?). The chart below is for a KitchenAid Range. Most likely is a control board issue. We rebuild control boards if you want to save some money compared to new.
Nov 02, 2010 | KitchenAid Kitchen Ranges
Oven and coil burners work one time then the next time neither one warms up, try again later and it works again. started last week when the oven preheated put in food to cook and half hour later noticed...
If this is an electric range, it sounds like you are not geting 220v all the time. check were your cord or house power hooks up to range. You may find one side of the 220 line burnt. Shut off power and repair conections. or call a qulified tech.
Nov 22, 2009 | Ovens
Oven shuts off; display blinking
If you're inclined to fix this yourself and can't find a replacement control board (no doubt that's what you need), try They will repair your board and return it to you with a 1 year warranty.
May 06, 2017 | Amana ACS3350AS Gas Kitchen Range
Oven and broiler will not stay on.lights blink
I performed this exact same repair of a Thermador Model P366CS/03 on Thanksgiving Day 2017.
It seems a bit of grease had dripped down onto the microswitch with the sail on it. The grease was enough to prevent the switch from actuating. The thing is held down with two 4-40 screws and loose nuts. Be careful not to drop the screws into the range.
Now the problem I had was getting into the top of the stove. If the burner venturies are the least bit corroded, it's very difficult to get into the top level to gain access to the switch.
Nov 03, 2009 | Thermador PG486GEBS Stainless Steel...
Trying to set oven temp. F-7 and F-1 keep appearing and sounding an alarm. oven does heat up but will not stay heated without the above code and alarm. PLEASE HELP!!
F7 usually means a stuck key on the keypad. I've also seen it caused by a greasey buildup on the keypad connector into the control board. Try pressing each button on the keypad followed by cancel. See if the buttons are registering with the control - should get a beep or some function (execpt up/down buttons need a cook or time function enabled first). If one of the buttons seems inoperative it may be stuck, in which case you probably need a new keypad.
F1 is usually caused by a failure in the control board and is a common problem that we repair on these boards. If you shut the power off for a few minutes, turn it back on and enter a cooking mode before F1 appears (after reset is finished) then you can cook. This doesn't fix F1, just allows you to work around it in an emergency.
We'd be happy to repair your oven controller for you.
Oct 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
When we cook in the oven it says F2 every 10 mins.
This means that your oven temp sensor has failed. There is no way to fix the sensor. You have to replace. The f2 means that your oven has reached its heaeting limit and it shuts down for safety. Replace oven temp sensor and it wil fix it.
Nov 18, 2008 | Hotpoint RGB745 Gas Kitchen Range
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Stove beeping
You have a fault in the range electrical system
Range/Stove/Oven Fault Codes Version 3 Failure
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
Frigidaire FEF366 Electric Kitchen Range Logo
217 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
