Question about iRiver H10 MP3 Player
My iriver plus3 software does not detect my iriver h10 player
My computer recognizes the device when I plug it in with the USB cable but the iriver software doesn't. I just ripped some music using the iriver program but cannot transfer it. When I click on "device info," the message "no portable device inserted" appears. When I click on "tools," "portable device connected" and "disconnect portable device" are disabled. The device is clearly connected, as the computer recongizes it. I've tried turning on and off the the device, plugging and unplugging it, and restarting the iriver program on my computer several times. So the problem must be with the software. When I clicked on Help, "check for iriver plus 3 update," I got the message that the most recent version has been installed. I would appreciate your help. Thanks.
  • 1 more comment
  • Anonymous Dec 05, 2008
    iRiver Plus 3 does not recognize my H10 5gb for syncing. Vista sees it as another HD, but Plus 3 tells me "No portable device connected" even so it is listed in the library tree as H10 and I can play all the MP3 files from it.
    What's going on here??
    Thanks for any info.
  • carmen_a_r Dec 18, 2008
    I have the same problem. I can download music from Windows Media Player, but the iriver plus 3 program doesn't detect the device. I don't see how to delete items on my mp3 player.
  • Anonymous May 18, 2009
    Exact same problem!
GUYS ALL YOU HAVE TO DO IS PUSH THE USB CABLE HARDER INTO THE DEVICE. IM A GENIUS!!
Posted on Sep 21, 2009
I had the same problem with my Lplayer, and fixed it by changing the 'connection type' in the settings menu of my player.  Now plus3 recognizes the player.
Posted on Mar 14, 2010
DEAR SIR, I HAVE ONE IRIVER E150 MP4 PLAYER. BUT MY LAPTOP IS WINDOWS 7, MY IRIVE E150 DRIVER CD NOT WORKING IN MY LAPTOP NOW WHAT WILL DO? PLS REPLY ME SIR. THANK YOU
Posted on Apr 09, 2010
IRIVER WONT WORK AAAAHHH HELP!!!!!? my iriver wont work when i try to turn it on it comes up and says system files missing to restore the system files, connect to iriver plus wat dose that mean i have...
When system files are missing on the player, you will need to reinstall the FIRMWARE.
When looking online for the connection type for the H10 / H10JR, I can see 2 CONNECTION TYPES for the H10 / H10JR:
1. MTP, when using Windows Media Player 11 ( WMP11 ), for the H10.
2. iRiver Plus, when using iRiver PLUS, for the H10JR.
The connection type determines what software on the computer will be used for transferring media.
Each software on the computer needs corresponding firmware on the player to be installed.
When the player itself comes up with the information to connect to iRiver PLUS, this is the correct software for this device probably. Then the device is a H10JR.
When not having the program iRiver PLUS, go to the iRiver support site, for the download:
http://www.iriver.com/flash/index.asp?code=0302
In the left column click Plus3 and go for the download.
Run iriver plus 3 and then select [Tools > Portable Device > Firmware Upgrade] from the menu.
Need more help ? Just post a comment.
In case you have the other model player, the H10, let me know if you need assistance for its recovery.
Dec 15, 2009 | iRiver H10 MP3 Player
My PC does not have a program that will let me add more music to my iRiver ifp-190tc. ... How to get music onto your USB MP3 player without OEM software. ..
River iFP-190T is an iFP-100 series player. The device has UMS connection type. UMS = Universal Mass Storage seeing the device as a flash drive (also called removable disk).
For music transfers and firmware upgrades iriver PLUS3 must be used. Download iriver PLUS3 going to this site:
http://www.iriver.com/index.asp
Click Support on the left side.
Select Download in the second column.
Select "Download iriver PLUS3" in the page: allow download (when blocked / sometimes download has to be repeated).
The size of the iriver PLUS3 download is 59.3 MB.
Computer / Windows requirements:
  • Windows 2000 Service Pack 4 or later, Windows XP
  • 233 MHz Pentium class processor or better
  • 64MB of RAM, 256MB recommended
  • 30GB of available disk space
Manual for iFP-190TC with this link:
http://www.portablegear.nl/download.htm?Merk=iRiver&Product=iFP-190TC&PID=571&Bestandsnaam=iriver-ifp-190tc
Oct 02, 2009 | iRiver iFP-190T MP3 Player
I can not delete unreadable/corrupt music(MP3) files
When your iriver H10 has corrupt files you may want to solve the issue by formatting the player's hard drive.
This is how I did it with my H10 5GB (so called 'MTP device' thats recognized by Windows as a portable device i.e. "Windows Portable devices".
To do so follow 2 steps: step 1: Format the hard drive of your H10. step 2: Re-install the player's firmware.
step 1: Format the hard drive of your H10: --------- 1. Make sure your H10 is turned off and disconnected from the computer. 2. Take out the battery, wait a second, and put the battery back in. 3. Turn on the hold switch (so that you don't accidentally turn the H10 on all the way). 4. Plug the H10 into your computer. 5. Turn on the H10 while holding the "O" button. On your H10 screen You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button. 6. On your computer, start Windows Explorer, navigate to the drive, right click and select 'Format'.
step 2: Re-install the player's firmware. --------- 1. Download and install iriver Firmware Updater v2.4.0.0. I found a downloadable copy on this website: http://www.opendrivers.com/driver/237145/iriver-firmware-updater-v2.4.0.0-for-mtp-devices-windows-free-download.html 2. Start the newly installed software and follow the Wizard. I clicked the 'USA' button when asked where I bought the device. This should install the MTP firmware. 3. Wait for the software to complete and disconnect your device from the computer. 4. Wait for your device to install the new Firmware.
Oct 01, 2009 | iRiver H10 MP3 Player
I replaced the battery in my iriver h10 20g. System file missing
was your player set to ums mode before running updater? to put it in ums mode you have to reset player by removing battery then reinstall battery then connect it to your computer turn on player and at the same time hold the button down with the o on it then run the updatera program again
Mar 23, 2009 | iRiver H10 MP3 Player
Pc doesnt recognize iriver ipod
first of all iriver is not an ipod
try to download the driver named iriverplus that shuld work
Jan 29, 2009 | iRiver H10 MP3 Player
Vista will not recognize iRiver H10 MP3 player
Try plugging in usb with the H10 turned off. Now, press the select button (with the round symbol on it) while turning the H10 on. This starts the player in 'emergency mode' and should be recognized by XP
Jan 08, 2009 | iRiver H10 MP3 Player
Lost h10 iriver installation disk
You can download the software from this site;
http://www.iriver.com.au/iriver/index.cfm?pageID=10001
Probably also from worldwide site. www.iriver.com
As a work-around you can copy files with Explorer to the Music folder and use the Browser on H10 to play them.
Feb 14, 2008 | iRiver H10 MP3 Player
Delete music H10 iriver
Sorry, but the built-in firmware only allows you to do that by plugging it into your computer as a removable device. Pull the battery of the player (or press the reset button), plug it into your computer, and press and hold the OK button as you turn it on. This will cause the computer to recognize it as an external drive, and you can therefore delete music from it by accessing it through My Computer.
Dec 21, 2007 | iRiver H10 MP3 Player
Charger
The h10 uses a charger that plugs into the USB cable. It's a combination deal. You need both the USB cable and the charger cable.
You should be able to find them on E-Bay for about $20.
Dec 03, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
1,929 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
