Question about Rancilio S24 Espresso Machine
No hot water
Hello- I have a Rancilio S24 that I have owned for the past 5 years.
When I turn the power switch to the ON position, the light in the switch comes on. However, the pump does not activate,and the boiler tank does not heat up. Do I have a heating element problem? Is there a reset switch to try before I have it serviced?
  • 3 Answers
Yes there is a small red breaker switch on the left side of the boiler tank. Unplug the unit first then remove the left side cover and just push down on the red breaker switch to reset it.
Posted on Apr 21, 2010
  • Craig Friend Mar 05, 2013
    what if there is no red breaker there
Descaling rancilio
Use Citric Acid.
  1. Dissolve about one tablespoon of citric acid in the water reservoir.
  2. Fill the boiler completely. Open the steam valve and start a hot water cycle until water comes out the steam vent. Stop the hot water cycle, close the vent.
  3. Let the boiler heat up about 5 minutes. Then turn off the power.
  4. Let the acid solution work for about 1/2 hour.
  5. Pull a 30 second shot to change the water in the boiler.
  6. Repeat flushing cycles (steps 3, 4, & 5) until the water looks clear. Refill the reservoir with water and acid as needed.
  7. Wash out the water reservoir.
  8. Pull 5 or shots to get the acidic water out of the boiler. Run a hot water cycle to clean the acidic water out of the steam vent.
  9. Let the unit come to temperature and look for leaks.
  10. Make some coffee and look for leaks.
  11. Froth some milk and look for leaks.
Jan 18, 2014 | Rancilio Audrey
Rancilio s24 stopped heating. AlreADY RESET BREAKER???
If breaker on the element has been reset then the breaker is damaged or the element is damaged. Check them with a ohms meter to find out which one is damaged.
Oct 30, 2010 | Rancilio S24 Espresso Machine
When pressing the hot water button there is only a limited amount of water coming out
Try reprogramming the button for a longer cycle. Hold stop button down for 5-8 secs and that should put you in program mode.
Apr 05, 2010 | Rancilio S24 Espresso Machine
Wont build presure
Unplug power and remove left side cover. Press down on red breaker switch to reset it.
Apr 02, 2010 | Rancilio S24 Espresso Machine
Rancilio S24 Pressure adjustment
Rectangular box on the back of the machine, it is easy to reach it from the top, there will a + and - sign on the slotted screw to show which direction to adjust.
Jan 07, 2010 | Rancilio S24 Espresso Machine
The low water level light comes on in my S24, it is full of water and the unit will not operate. Thanks.
There is a low water sensor tube in the water tank. Pull it out and leave it out for 30 seconds, then lower the bell back into the water tank. If the bell gets water inside the it looses the aire pressure to activate the sensor. There should be only air in the bell and hose.
5 year old Rancilio Silva with no heating of water
Hi
Do an ohms check on the element. With an ohms meter check the reading between the elements. The reading should be between 12 and 16 ohms for a 110v machine and 50 to 60 for a 220v machine. If you have no reading or a higher reading you have a bad element.
Replace the boiler
Jul 24, 2009 | Rancilio Silvia Espresso Machine
No pressure duild up
I am not sure if you have a plumbed model or the one with the tank, however, I will give advice for both.
If machine is plumbed, make sure water is turned on then remove the top panel on the boiler is a reset switch (it is on the side of some models), its a red push in switch.
If using a tank, fill then press reset and turn machine on.
Jul 22, 2009 | Rancilio S24 Espresso Machine
Pressure is not going up on machine
Unplug machine and remove left panel. Press down on red breaker switch to reset breaker.
Jul 07, 2009 | Rancilio S24 Espresso Machine
Open Questions:
See all Rancilio S24 Espresso Machine Questions
Rancilio S24 Espresso Machine Logo
259 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
