Question about Frigidaire FWSB5700DS Top Load Washer
Frigidaire - model - FWS747RFS1
My washer won't spin any more.any help is appreciated. I have taken off the front cover, and nothing looks broke. Help
  • Anonymous Dec 20, 2008
    changed belt still wont spin
I'm having the same problem with a Frigidaire Crown Washer.
It is the start capacitor which is out on mine.
This is how I confirmed that:
Be careful with your fingers and turn on your washing machine, unplug it, and remove the belt from the motor. Plug the washing machine back in and turn it on. When it gets to a spin cycle, turn the washing machine motor by hand (WATCH YOUR FINGERS!!) and if it starts spinning on its own, then your motor is good and it is likely the start capacitor.
For further testing of the start capacitor, go here:
http://www.wikihow.com/Check-a-Start-Capacitor
My start capacitor has a resistance of 1 ohms and never makes it all the way to 0 on my multi-meter when doing a resistance test.
Posted on Oct 21, 2008
MY FRIGIDAIRE FRONT LOAD WASHER WONT FILL WITH WATER OR SPIN . HAVE TRIED CLEANING THE DOOR LOCK & UNPLUGGING IT FOR EXTENDED PERIODS OF TIME.
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire fws747rfs1
The washer tub bearing may be defective, but that is the only thing that I can think of. Are you noticing this on all loads or just heavy items like bath towels and jeans? Are you redistributing the clothes before the final spin, try that. Also do not overload the washer, wash to medium loads instead of one full to the top load. Wastes water but saves on repairs.
Apr 12, 2017 | Washing Machines
My front loading washer will not give a high speed spin out. It shuts off at the 7 minute mark
There are two things you can look at that are common problems for this type of model. One is on older Frigidaire front loaders the shock absorbers tended to break, you can remove the front panel and view both shocks, look for a end of the shock broke off. Second is check the trap for the water pump, have a towel for the water. The replacement shocks are better........and most front loaders will not spin if the pressure switch is not open(water pumped out) The remaining problems are electrical, reconnect your connectors on the electrical harness and board or timer, figure out tech sheet or call the service company......(unplug when doing any service)
hope this help
Feb 23, 2010 | Frigidaire Washing Machines
Drum/frigidaire washer
wow thats a long hard job ,,overhaul....the part your looking for is the spin tube surport,,you have to take the hold drum out than seperate the front tub from the back bearing tub,,and pull wash basket out though front..,,also if you had a leak or surport broke and is making noise.. change back bearing tub too.i recommend a professional technician...but if you want to do it your self ..post question how to change wash basket,,glad to help
Dec 27, 2008 | Frigidaire ATF6000ES Front Load Washer
WASHER WILL NOT SPIN DRAIN
You will have to get carbon brushes very cheap on line and easy to fix,
Oct 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Front Load not spinning
The back of washer has a access panel with screws that you can remove,once removed you can check if tghe belt broke or not.
May 23, 2008 | Frigidaire ATF6000ES Front Load Washer
Same as many - Washer does not spin or agitate but everything else works fine
your brushes are gone you will have to wright down you model number and look on ebay there really cheap
Jan 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Main Drum Bearing
Rear Main Bearing is bad, Believe you have replace whole back of the drum, about 200$
May 16, 2007 | Frigidaire GLTF1670A Front Load Washer
Frigidaire FWSB5700DS Top Load Washer Logo
802 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
