Question about Sharper Image (SI714SL2) Compact Refrigerator
Fridge door handle is broken - Sharper Image (SI714SL2) Compact Refrigerator
  • hilbie22 Nov 15, 2008
    side by side refrigerator door handle broke on the bottom; small screw came out, how do your repair this?
Door handle broken, wondering if i can get a replacement somewhere.thank you
Posted on Oct 29, 2008
Freezer drawer on Kitichen aid french door stuck shut. Been of for 24 hours still won't budge.
tough question
by the look of the picture it should not have that problem
something jammed or fallen on both openings
that stop doors from opening
call a fridge repairer first
those doors cost a lot to replace
maybe the fridge guy can you undo the top hinge of the french doors
if the freezer draw handle is broken you might need his help with that anyway
Sep 26, 2016 | Refrigerators
My freezer door handle has come away at the top how can i fix it mysel
If handle is broken get a new one and by removing inner door panel install the new one. Parts available at attached link Search Over 2 1 Million Appliance Parts
Mar 02, 2016 | Samsung RSA1SHPN American Platinum Inox...
My fridge part the door handle keeps coming loose
Most of time just a stripped screw or fitting on door handle so you have to replace whatever part is missing or broken. Rich
Apr 13, 2015 | Refrigerators
Broken door handle on fisher & paykel e388
look for the model number at the front, bottom of the fridge where the door meets the fridge body (eg 22021-D). Go to shop.onlineappliancespares.com.au and either buy the whole handle ($150) or just the broken lugs ($15)
Nov 17, 2012 | Refrigerators
The door handle strip on my Bosch logixx fridge has two broken fixings. I have bought a new handle strip but the 2 remaining fixing points are OK so I can't get the old strip off! Any ideas on how to...
I have a Logixx with the same problem. Brute force was the answer. You cant lever the tongues out of the way and so cant release the handle gently. Use a piece of wood and lever the handle forward in the same direction as you open the door and it should come off. The new handle then snaps back in. You may need to remove the residue of the old broken part of the clips.
Sep 23, 2010 | Bosch Logixx KTR18420 Compact Refrigerator
I want to remove door handle to replace broken fixture.
I think you may have to remove the door gasket, if you look behind the gasket you will see the screws holding it and the inner door liner in place, both should be removed and you will then have access to the handle screws from within the door.
May 27, 2009 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Neff fridge freezer K4664 broken door handle
Go and find your frig paper work there are areas with parts and how to order them
May 13, 2009 | Neff K4664 Top Freezer Refrigerator
Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Nov 07, 2008 | Refrigerators
Sharper Image (SI714SL2) Compact Refrigerator Logo
313 people viewed this question
Top Sharper Image Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Sharper Image Refrigerator Expert? Answer questions, earn points and help others
