Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Not Grinding My maker makes a sound like it is out of beans but its not and it won't grind the ones that are in there. Why not? I really need my coffee.
    Problem Solver:
This FixaYa site is the biggest scam ever, nobody ever answer to any questions, the existing questions are posted and answered by the same idiot logged in under a different name. i'm sorry to say I paid $14.99 for live chat and nobody ever answered, after one hour of waiting like a fool my live chat session expired so I e-mailed FixYa support about it but nobody ever answered. There is no refund also since you can't get nobody to talk to you. So don't pay here or you’ll get scammed.
Here is all i got from this idiots for my $15 and this was automated mail!!
Thank you for purchasing a FixYa Premium Live Chat Session!
We hope that the assistance provided by our Expert will be helpful and courteous.
If you haven't done so already, we encourage you to review the Expert that assisted you. Please post a review now!
As always, our Premium Support Team is happy to assist you with any questions regarding the Premium Assistance service.
Feel free to contact us at premium.support@fixya.com
Payment: 14.99 USD
Your invoice number is: 76013
Regards,
The FixYa Team
Posted on Nov 08, 2008
  • 515 Answers
Make sure you not get any damp into the grinder.
Best regards
/Mirran
Posted on Oct 27, 2008
  • jimcarrol55 Feb 10, 2011
    OK, what if you did get moisture into the grinder? What can be done?
3 Suggested Answers
drumbanger
  • 1199 Answers
SOURCE: No grinding of the beans nor not making coffe
Yes! and I hope it helps you. There is a small metal shaft that you can see when you take off the bean grinding unit alot of times with repeated use the shaft will stick from small coffee dust particals and condensation buildup which forms a sticky substance on the inner shaft! get a small pair of pliers and grip the shaft and Turn clockwise 1 full turn, this may unstick it! unplug unit for five min then try again You may want to oil the shaft with some good high grade oil! if this does not work the grinding motor may be burnt out and needs replaced! also check your settings! please rate
THANK YOU!
Posted on Jan 15, 2009
SOURCE: grinding coffee but water not making coffee
Check to make sure the quantity button has not been reprogrammed. To do so, push and hold the coffee button until coffee flows through. Also be sure to check the brew-unit. In some cases if the b-unit is plugged, it will not allow water to flow through. Also check to be sure you are not grinding too fine, if coffee is too fine it too will plug the chamber...........Hope it helps.
Steven,
info@northwestkitchenware.com
Posted on Jun 30, 2009
I have a saeco royal my machine is grinding beans but will not stop
Your question is not right.
Grinder stops on its own in 16 to 18 seconds (times out).
It may not be grinding beans an spinning free because the beans are not feeding.
You may have used oily beans or set the grind fineness at very fine powder like. This powder like fineness also clogs the grinder..
You need to clean the grinding chamber and the ground coffee outlet.
Dec 19, 2016 | Saeco Coffee Makers & Espresso Machines
HOW DO I CHANGE THE GRINDING MECHANISM ON MY SPIDEM TREVI EXCLUSSIVE ESPRESSO MACHINE. I HEAR THE MACHINE GRINDING BUT IT'S REALLY NOT DOING ANYTHING. ANY SUGGESTIONS
When the grinder spins free and fast it only means that fresh beans are not feeding into the burrs. This happens when:
1- Grind setting is too fine and beans cannot enter the grinder mechanism.
2- Use of oily dark roast beans can clog the ground coffee chamber and preven the fresh beans entering the grinder.
3- The ground coffee chamber outlet is clogged due to oily beans or too fine coffee setting.
When you cleaned the grinder you may not have cleaned the coffee outlet to the doser on the left. You can clean the outlet to open the passage of coffee grounds to collect in the dosing device..
After cleaning the outlet, you should next make sure that coffee grounds are not packed in the doser. The doser is inside the door right above the brew group.
To access the doser:
1- Remove water tank.
2- Remove the brew group.
3- Lay the machine on its back for full view of the doser.
4- Pull the doser door open (it is like an Attic door.
5- Keep the doser door open and clean the inside with a brush. The outlet from the grinder is on the right side with a wire wiper cleaner that moves across the grinder outlet fills from the grinder. This opening.
Use a brush to clean the doser.
On the left of the doser space there is a plastic flap that is pushed to the left when coffee grounds fill the doser.
At certain distance push back (1/4") the notch on top of the flap pushes the doser micro switch pin to stop the grinder. Push the flap gently to the left to make sure that it is moving well. With each push back of the flap, one can hear the feeble click sound from the micro switch.
When the above cleaning is done, try the grinding.
If the conical burrs have not been replaced for over 2500 grinds, it is time to do so.
The above grinder and grinder doser cleaning instructions are available as download files on the following page link:
One can find many useful maintenance guides on one page.
Good luck.
http://www.partsguru.com/MaintenanceofEspressomachines.htm
Feb 10, 2015 | Spidem Coffee Makers & Espresso Machines
Our Saeco Vienna Superautomatica sounds like it's grinding beans but keeps running until the red 'bean' light comes on and we have to shut the machine off. Any suggestions?
The grinder is timing out and stops if the beans do not enter the grinder. This happens because:
1- The grinder outlet is clogged and fresh beans cannot pass through the burrs.
2- The grind setting is too fine and helping clogging in the grinding chamber or the ground coffee outlet.
3- Operator may have been using dark roast oily beans. Like it or not, the dark roast oily beans do not make stronger espresso. Please stop using such beans in fully automatic espresso machines.
4- The grinder has already made over 2000 grinds and the burrs are blunted and not grinding beans as needed.
To solve this malfunction, clean the grinder. Make sure the grinder outlet to the doser is cleaned. This outlet passage is about 2 inches or more. To clean it, lay the machine on its back (water tank side) to allow better view of cleaning the doser and the passage of coffee from the grinder to the doser. Use the link below to find instructions for cleaning the grinder and replace the burrs.
Gaggia Titanium and Plus Espresso machines parts and repairs Saeco...
Oct 18, 2014 | Coffee Makers & Espresso Machines
Its telling me that coffee beans are empty...but they are not..it makes grinding noise but the message keeps popping up beans are empty
You have one of 2 problems either the grinds chute to the brew unit is blocked, or the grind is too fine.
Sep 18, 2010 | Gaggia Syncrony Compact Coffee...
DGB-900bc will not grind; It also does not pull the beans into the hopper to grind them. It used to make a loud grinding sound when it ground the beans, but now it makes just a dull sound, like the grinder...
I experienced the same problem after many uses. You need to pull the hopper off and clean out the path the grounds take to the filter basket. It is no doubt clogged up. I used compressed air to really clean it out good.
Good Luck
Mar 21, 2010 | Cuisinart Coffee Makers & Espresso...
Coffee Grinder on the EAM3500
We just went through the same situation. We opened the top the Magnifica to get to the grinder and removed the four screws to seperate the grinding pieces. Inside we discovered two black fosilized beans/stones! We removed those, cleaned out all the bean dust and it is working like new! Took about an hour.
Aug 31, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Saeco magic de luxe grinder problem
Hi Cindy,
Make sure you not get any water in the grinder, if you get water in the grinder then it bean smeary and will not grind the beans.
You have to clean the grinder if you get any moisten in it.
/Mirran
Aug 17, 2008 | Saeco Magic De Luxe Espresso Machine
Solis Palazzo Bean Grinding
That one with number on is finer or coarser grinding beans, the other one is for how much gram it would grind. + means more gram.
I hope this will help you.
Apr 28, 2008 | Solis Palazzo Espresso Machine
Bean hopper is full, grinder is grinding...but NO COFFEE!
Sometimes the chamber between the grinder and brewer will clog up. Try: Open the grind all the way up to the highest number. Push the grind button and while grinding move the dose knob (the one with the + - sign toward minus. If it does not kick in and dose try it again. If it does take off then leave it on the high number for 3 coffees. Then while the grinder is turning move the two knobs back to whre they were. If this does not work you can reomve the brew unit and right above where it sits in the machine there is a trap door that you can open. Open it and shove someting like a straw up toward the grinder and you should get a bunch of grounds droppiing down. Then try the above procedure a couple more times. If this does not work you may need to google "Saeco repair" and send it to an authorized repair center.
Aug 15, 2007 | Saeco Vienna Digital Coffee Maker,...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
132 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
