Phone bt freestyle 3200 phone i have a twin set and both handsets are displaying register no matter what i try they are not responding it says no base everything i try it says not possible how do i reset the base and handset back to the manufactures settings help please
Have acquired an additional handset with charger. The screen flahes a 'Please register' message. How do I do this?
Assuming you do not have 5 handsets already, make sure that the new handset is fully charged. Carry it over to the base and press Find on the base unit. (This sends out a signal to the handset.) On the handset, press Menu and use the Up arrow to go to the line marked Settings. Press Menu to access this sub-menu. The line H/Settings should be highlighted. If it isn't highlighted, use the Up/Down arrows to navigate to this line. Press Menu to access this menu. Use the Up/Down arrows to navigate to the line Register. Press Menu again. Use the Up/Down arrows to select the base to which you want the handset to be registered. Press Menu again to confirm that base registration. Enter the system PIN for this base; the initial PIN is mentioned in the manual on page 35 and on page 54. Wait for the handset to indicate that it has been registered; it will say Registering until the process is finished. If you take too long to do the steps at the handset, the signal will stop and you will need to start over.
If you already have 5 handsets, you will need to de-register one of them. If the registration process does not properly occur and the issue wasn't taking too long, either the base or the handset is not communicating properly. If other handsets work, I'd suspect that the new handset is faulty.
BT Systems has the manual on the Freestyle 750 product site: . The direct link to the manual is . The procedure to register the handset is on pages 53-54 of the manual.
I hope this helps.
Nov 02, 2015 | BT Freestyle 750 Digital Cordless Handsets
How do I rescue my BT Freestyle 750 from being stuck "Searching" and remedies that are "Not Possible"?
Have you tried removing the batteries and letting the internal power decay for an hour or so - in other words try to get them to forget what they were. Then replace batteries and try again. I guess you've consulted the user manual, is there a reset button hole anywhere on the base unit? The sort you stick a pin into.
Hanged batteries in handset but phone will not ring
Check to see if ringer is set to hi. make sure ringer is turned on. Check to see if the base and the phone are syncronized.
BT Freestyle 2200 do dial tone
I have this model of handset but as a triple. I get three beeps from the handsets if the batteries are low or flat.
Are your phones getting charged?
Try putting the base station into a different phone line/ socket if you have one.
if not - Try putting a corded phone on your phone line. Maybe there is something faulty with the socket, maybe there is no dial tone due to faulty wires?
Mar 07, 2008 | British Telecom Freestyle 2200 Trio...
Bt freestyle 210
I have found a free link to the user guide for you on the BT site, it is a very comprehensive guide and there is a BT helpline number if you are still having problems
Dec 21, 2007 | British Telecom Synergy 2110 Cordless...
BT Freestyle 2200 I am having problems obtaining a dialing tone on both of my handsets. When I press the green button for a line out it just beeps 3 times and cuts off. There is charge in both the...
hi just want to help others as desciption aint complete above
Registering a BT Freestyle 2200 handset
1. If there is a handset in the base remove it whilst you are registering the new handset.
2. Press and hold the PAGE button on the base for about 10 seconds until you hear a beep and the In Use light starts flashing.
3. On the handset to be registered, press and hold redial & CALLSd buttons together until display shows 65-.
4. Enter the base number. If this is a new handset then the base number is 1, the display shows 65-1 then PIN. which is normally 0000
5. Enter and registration starts. When the handset beeps and returns to standby registration is complete.
Nov 08, 2006 | British Telecom Freestyle 2200 Trio...
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
