Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
My 3 year old
Worked great then. cloudy residue on dishes, detergent door opens, however detergent is drooping down the door, now it runs continuously if not manually turned offf
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
There is a new product out that actually filters the water going into your dishwasher. My dishes came out amazing after the first load. No more cloudy glasses. I was very impressed. Who knows whats in the water cleaning your dishes so i thought this filter was great. It is very affordable and you can get it at www.dishwasherfilter.com. Hope this helps some people.
Posted on Dec 18, 2008
Try a different detergent such as the electrosol tablets. Also might add vinegar to an empty cycle to clean dishwasher, or with dishes.
Posted on Oct 23, 2008
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
Cloudy dishes , not running cycle completely. soapy residue.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 05, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
I've had my dishwasher (GU2455XTSB3) for almost 2 years. The first year and half were great. I always use the same cycle (with options) and it took approximately 1.5 hours to complete. Now it takes over 3...
heatman101
Oct 23, 2010 | Whirlpool GU2455XTS Built-in Dishwasher
In the last month I have noticed that my dishes aren't getting clean. My dishwasher is less than a year old and has done a great job so far. I tried adjusting the amount of rinse aid and the amount of...
First I would run the hot water until hot. Then start the dishwasher on the longest setting with the dispenser door closed( no detergent). Then after about 10-15 minutes open the door and check to see if the dispenser door opened, it should have. Then pour in about 1 cup of white vinegar and let the dishwasher finish. When the dishwasher reaches the end of the cycle open the door and it should be hot and steamy. If not check the heating element. If it is hot this should have cleaned it out, now try it with a load of dishes.
Dishwasher heating element replacement
Sep 28, 2010 | LG Dishwashers
Dishes have filmy finish
hello. this will help a great deal.
First of all empty out your dishwasher, toss in two cups of plain white or cider vinegar and run it on the highest and longest cycle.
Always run the hot water in the sink first and start the dishwasher only when the water is as hot as it will get.
This wash will clean out your dishwasher thoroughly.
Then always do your dishes after you have rinsed any residue off of them before placing them in the dishwasher and I always recommend the pot scrubber cycle if you have one.
Jul 07, 2009 | Dishwashers
Cloudy residue on dishes after washing dishwasher is only a year and a half old what can i do ?
you need to check out this new product designed especially for this problem. it is guaranteed to work! it filters the water going into your dishwasher removing the hard minerals that cause these spots. get it at www.dishwasherfilter.com
May 10, 2009 | Dishwashers
After running a full cycle dishes are covered in detergent residu
www.dishwasherfilter.com has a great product specifically for this problem. it filters the water going into your dishwasher removing the hard minerals that cause this problem. after the first load my dishes looked amazing. it is very affordable and fits right under your sink.
Apr 01, 2009 | Asko D3251HDSS Stainless Steel Built-in...
White residue on dishes after wash
check if the residue are soap or not. residue could be from water tank or water itself.
Nov 01, 2008 | Kenmore 24 in. 15173 Stainless Steel...
Dishwasher does not clean. soap door does not open every time.
Well the 2nd part of your question is probably the the reason it doesn't clean. If the soap door doesn't open then the dishes will probably not be cleaned. So.. I would focus on why the door doesn't open first.. is it sticking from old soap residue? If so, clean the dispenser with white vinegar and cycle it a few times without detergent and use the hottest/sanitary setting.. Then make sure you are using an approved dishwashing detergent for yuour wash cycle. Add some detergent to the dispenser and try cycling it without any dishes .. does the door open? If no, then you need to resolve that first.. If it does open, try running a cycle with about 1/2 the normal dish load and see if the door opened and the dishes came out clean.. Routinely, check and clean the drain filter so you aren't redistributing the food sediment from the previous load all over the next load of dishes.. Hope that helps..
Sep 06, 2008 | Kenmore 24 in. 16009 Built-in Dishwasher
When the dishwasher cycle is complete there is a thick, cloudy film
jcb...It may be that your detergent is not the right one for the job, you're using an amount that is too much or too little or your water isn't hot enough. Water should be at least 125 degrees. If you don't have an turkey/candy thermometer, run the hot water and put your hand under it...carefully. If you can hold it there...not hot enough.
You might also see if there are filter screens in your unit. Clean them.
Dec 09, 2007 | Bosch SHU3306UC Built-in Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
221 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
