One of the phones on our system has the lite next to the "SPKR" button on all the time. It goes off for a few seconds if you hit any button but comes back on in a few seconds. Otherwise the phone still works fine.
You MUST do it at the Main Extension handset - usually 101. With the handset on the cradle: Press Program button Enter *# Enter the system password - system default is 1234 Enter 000 Press the Auto Dial/Store button Enter date using the Scroll button (the round one used for spkr volume) to move to right and left to next field Press Auto Dial/Store button to accept setting Press Redial button to move to time Enter time using Scroll button (the round one used for spkr volume) to move to right and left to next field Press Auto Dial/Store button to accept setting Press Auto Ans/Mute to exit Date & Time Press Program Button to complete
go into settings, look for wireless controls or bluetooth, should ask you to pair with the name of your bluetooth if it wont, turn off the bluetooth in the phone and turn off the bluetooth itself by holding down the button for about 6 secs till the light blinks a few times then goes out. turn the bluetooth function on on the phone FIRST, wait till it says its on, then turn on the bluetooth itself by holding the button down until the light blinks a few times then you get a solid light, it wont stay solid, it will blink a few times then go out blinking from time to time. go back to your phone and find the bluetooth menu and it should ask you if you want to pair, hit yes or whatever option you have and it should start pairing and then connect or you may have to hit the connect option if you have one they dont all connect automatically sometimes so you have to go through all this when you charge the bluetooth or turn it off. good luck.
Press the PROGRAM button, then press * * 1 2 3 4 The display should now read: USR-PGM NO?
Step 2. Enter: 0 0 0 Display: Day/Time Set
Step 3. Press NEXT (or the SPKR PHN button) Display: shows date (if you need to change the date, see steps 5 thru. 10 below)
Step 4. Press NEXT (or the SPKR PHN button) again Display: shows time example: 12:00 AM Step 5. Enter the hour to change current entry, press CLEAR (or the TRANSFER button) Step 6. Press --> (or FWD/DND button) Step 7. Enter the minutes Step 8. Press --> (or FWD/DND button) Step 9. Press SEL (or AUTO ANSWER/MUTE button) to change AM or PM Step 10. Press STORE (or AUTO DIAL/STORE) - Don’t forget this step! Step 11. Press END (or HOLD button) Step 12. Press SPKR PHN button or pick up and hang up the phone to leave programming mode.
Your phone system time may be off in general. Have you checked that?
You can usually reset the phone time display form the main console
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
From Front Desk Phone
1.Push Spkr button
2.Enter #652
3. Enter Correct time in HHMMSS
4.Push Redial button
5.Push Spkr button
OK, model on bottom of phone is DKT2010-SD, but I found a little cheat card in a file for a STRATA DK8 & DK16 so I used a combination of things. First pick up handset and then hit intercom button, # 652 (for time or #651 for date) and enter time in HHMMSS (hour, minute, second) format, once complete hit the redial button.
ok, the link isn't working properly, so I'll try to explain:
step 1 press "program" button, then **1234
step 2 enter 000
press next (or spkr phn button) for date
press next (or spkr phn button) for time
press fwd/dnd button
press fwd/dnd button again
press sel (or auto answer/mute button) to change am/pm
press store (or auto dial/store)
press end (or hold button)
press spkr phn button or pick up hand set and hang up to leave programming mode.
step 2 enter 000
Thanks for your suggestion. I tried it but did not work. We do not have music connected to the system.
