Question about GE GSS25JEMWW Side by Side
Refridgerator My freezer is working fine however the refridgerator is sitting at a warm 50+ degrees. My refridgerator is just 2 years old, there is a liitle ice buildup in the bottom left. I could hear the compressor blow cold air in the freezer 'sside and the fan at the bottom is not running.
    Problem Solver:
  • 18 Answers
Does freezer back wall have ice build up ? if so a defective heater is the most likely problem
Posted on Nov 15, 2008
The freezer compartment is working fine, holding at -18 degrees but the fridge section will not chill and has been holding at about 14-15 degrees for over a week but does not get any cooler than...
It sounds like one or more of your cooling tubes is blocked. Either you have a ice or frost buildup on your freezer side or something else is blocking it.
I would suggest you take a look behind the panel in your freezer and use a hair dryer or heat gun to blow warm air down the cooling tubes.
Jun 26, 2011 | Refrigerators
Refridgerator is warm, freezer is freezing
Defrost problem. Most likely the defrost heater or defrost thermostat.
Jul 02, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refridgerator does not get cool enough
Buttom freezer Sub Zero. Replacing evaporator for fresh food section.
Mar 31, 2010 | Sub-Zero Bottom Freezer Refrigerator
Our GE artica, 6 years old has freezer temp at 35 degrees , and refrigerator at 50 degrees. Water is flowing from dispenser, as normal but there is no ice. Ice/frozen things in freezer melted and water...
Check the back wall of the freezer for a ice buildup.
If ice is there you have a defrost parts issue.
That will cause the temps you report.
Also, check the freezer fan motor.
Is it running?
Also check the condenser fan motor at the compressor. Is it running?
Mar 03, 2009 | GE Refrigerators
GE Side by Side Not Cooling
Hi , the refrigerator having problem with enfeller fan stuck it needed to defrost manually to drain all ice buildup inlet of refridgerator hole after 3 hour try start refrigerator.
Feb 05, 2008 | GE GSS25JEMWW Side by Side
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Warm fridge, cold freezer...
Listen for a fan running when you open the freezer door. May have to hold the light switch closed for it to come on. If you don't hear it then the fan is most likely bad. The evavorator fan motor is the most common repair on the trio's
Oct 06, 2007 | Maytag MFD2560HES Bottom Freezer French...
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Fridge not staying cold
Solo, firt make sure you do not have a build up of frost on the freezer inside panel. This would indicate a defrost problem. Your post states that the cooling problem is intermitant which leads me to believe that the automatic damper is at fault. It could have a build up of ice on it which is causing it to bind, or it could just be going bad. Your model does have the manual defrost timer which could be sticking at times, that is why I suggest checking the back freezer panel for frost buildup. Catriver..post back.
Dec 01, 2006 | Maytag MSD2732GR Side by Side Refrigerator
GE GSS25JEMWW Side by Side Logo
341 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
