Question about Splendide 2000S Vented Washer/Dryer
Erratic Drum Operation
Sometimes the drum does not go back and fore during the wash and rinse cycles. It seems to work ok during the last spin cycle.
So far, it has worked OK in the drying cycle..
  • RAMAR535 Oct 28, 2008
    The water all ways enters the drum normally. Sometimes the washer cycles through all cycles normally, however, other times the drum does not do anything in the wash and/or rinse cycles. The last spin cycle operates normallly. Only once the drum did not spin during the drying cycle.
  • 13,433 Answers
Can you clarify the problem, I don't fully understand what the actual problem is?
Posted on Oct 24, 2008
  • Ekse Oct 29, 2008
    please see this webpage
    you can also try emailing the repair guru on that webpage.
    I'm not sure what is wrong with your washer but he should
    be able to help you more, that service is free.
    Also you may also repost your problem, my help in your
    problem hasn't been the best available. I'm sure someone
    among the experts knows more of your problem on this
    website than me.
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
Limited agitation during wash cycle Load Sense OK
Possible that the program selected is an easy wash as this is meant for daily wash , less soiled clothes.
If however the same situation is present in all the cycles then the capacitor to the motor must be checked as it can reduce the speed of the motor.
Also check the belt , check for friction on the drum spindle and the motor.
Jul 22, 2011 | LG WT5001CW Washer
The washing mashine goes through the complete cycle but only starts the drun rotation every time the wash cycle comes and than after the apropiate time continiues through the full cycle without the timer?...
I hope you can explain once again the fault that is noticed as I am not able to judge what you have experienced.
If the DRUM is not rotating or is erratic in the cycle then it is possible that the program controller unit is a prime suspect.
The power to the drum motor seems to be erratic from the controller and so is making the drum turn out of turn. I thin when the controller is activated the drum rotates without a problem.
So please check your program controller unit.
Jan 18, 2011 | Zanussi Washing Machines
Our washer dryer model GLEH1642FSO will not
sounds like the motor needs new bushes, same thing happened to me last yr, regards paul
Feb 13, 2010 | Frigidaire ATF6000ES Front Load Washer
My LG TROM wash googd but dosn't want to spin
Check and see what type detergent you are using. I bought regular liquid detergent and the machine began making noise during the spin cycle and the drum would not spin. I was informed that you have to use detergent that is labeled HE (High Efficiency). The regular liquid detergent will suds up during the wash cycle which then causes the drum to slip and not spin during the spin cycle. What you are hearing during the spin cycle is the drum slipping. Unplug your washer for 30 minutes and let it reset. This lets the suds dry out. Run a cycle with no spin to rinse out the drum. This should eliminate your problem. If you have clothes in the machine, run a cycle with no spin, just don’t add any more detergent. Then run the normal cycle with spin a second time with no detergent. I hope this cures your problem.
Apr 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
High speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Mar 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Noise during wash and rinse cycles
Got a response from another site - the noise was due to the recirculation pump (situated low down at the back on the other side from the drain hose) which was working, but clogged with a nasty grey 'porridge' of limescale and powder residue in the pipes either side of it. Dismantled, cleaned out pipes and ran a wash cycle to clear any remaining crud out. Seems ok now and wash jet working, noise gone.
Mar 28, 2008 | Zanussi WJD1457W Front Load Washer / Dryer
Splendide 2000S Vented Washer/Dryer Logo
139 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
