Question about D-Link Air DWL 520 802.11b (DWL-520) Wireless Adapter
Trouble getting a connection
Im running vista for my computer
first im not sure if D-Link Air DWL 520 802.11b is the exact product that i have, but mine looks very similar.
My d-link air worked fine for awhile but now it gets almost no signal from router not enough to connect to internet. I was connecting direct for a while and when i was doing this I disabled the wireless device, but i had the option of enabling it. I haven't used wireless for awhile, now i am trying to use it again, when i go into the computer and device's I don't even see the device there anymore, like its been removed somehow. i do not have installation cd anymore but that cd never worked in the first place due to having vista. I took it in where a guy choose the run program to activate the wireless device maybe something like this need to be done again. if you have any idea's that would be great
  • D-Link Master
  • 4,338 Answers
This adapter's driver is pre-installed in Vista. That means that Vista should automatically see it and install it.
Power down your computer.
take out the D-link adapter.
Power on the PC. Once you get to the desktop, check in the control panel > device manager. It should not be there.
Then power off the PC again.
insert the adapter but in a different PCI slot.
Power on the PC and Vista should see it ans set it up.
The cd would not help you because the D-link Utility does not work in Vista.
I have read the the XP drivers alone would work, But try this first.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 15, 2008
I NEED THE DRIVER FOR MY DEL LAP TOP COMPUTER TO MAKE THE D-LINK DWL 650 WORK
Go to the manufacturer's website:
http://www.dlink.com/products/?pid=DWL-650&tab=1
Scroll through the box on the right hand side to select your EXACT model.
Click on the model number.
Click drivers.
Select your operating system and click Download Now.
Jun 16, 2009 | D-Link Air DWL 650 802.11b Wireless...
I need to boost the sending signal from my D-Link wireless router so my secondary computer can access the net - presently the router works for one extra computer but keeps losing the signal intermittently...
goto start - run - .cmd - enter..type ipconfig..you`ll get ip address,subnet mask,default gateway.copy it.goto start- control panel - network connections now right click wireless network connection and click on properties and double click on internet protocol(TCP/IP) or if you are using vista goto network and sharing center - view status - properties - double click on IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
this will fix your problem...
Jun 12, 2009 | D-Link 802.11g Wireless Router WBR-1310...
How do we get a D link air plus G-630 to connect to a linksys wireless router? Comcast cable modem, linksys router, Dell inspiron 1100 running XP.
Install the driver of the Dlink Airplus and adapter to the computer, after that connect to the wireless network to the name was made to router.
Note: When connecting to the wireless network find the exact wireless network name of your router.
Mar 10, 2009 | D-Link DI-524/DWL-G630 (di524dwlg630kit)...
HAVE COMPAQ 2200 CAN NOT CONNECT TO D-LINK AIR
http://support.dlink.com/products/view.asp?productid=DWL-650L1#
Follow the instructs there...
Basically - install the drivers first, reboot and then insert the card...
Jan 18, 2009 | D-Link Air DWL 650 802.11b Wireless...
Xbox live wireless network failure
did you go into your computer settings? i think you have to take your firewall off maybe. im not totally sure on this one. good luck though! if you call microsoft they might have better answers sorry!
Dec 27, 2008 | Microsoft Xbox 360 Console
Airplus G DWL-G510 Vista Driver
revision B of this model has a driver for vista 32. go to http://support.dlink.com/products/revision.asp if you don't know where to check the revision of your device. if it's revision B, just click on the link for revision B and it'll give you the option to download the vista driver. make sure also that your vista computer is running 32-bit. if not, there's no available driver for vista 64
May 23, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
DWL-G710 and DWL-700AP compatibily problem
when using the AP you have to make sure you set the SSID, channel & wireless key in the AP the exact same as the router and make sure when configuring the Ap that you set the default gateway as the IP address of the router.
Nov 03, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
D-Link DWL-G122 Wireless USB Adaptor
This happens all the time first make sure you download the right drivers for your model for ex: d-link is have D-Link DWL-G122 vs1 or D-Link DWL-G122 vs2 make sure you download tthe right one. If you have Vista make sure you download (VistaBETA) if not download (WinXP, WinME, Win2K) also this product does not work on Mac os! links to look at http://www.dlink.com/products/support.asp?pid=334
Sep 02, 2007 | D-Link AirPlus G DWL-G122 802.11g/b...
D-Link Air DWL 520 802.11b (DWL-520) Wireless Adapter Logo
99 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
