Question about Hotpoint Aquarius WF000 Front Load Washer
Noisey washing machine
Hi
I have a hotpoint aquaris wf000 1000 spin and it's making a very loud noise when in use.If i turn the drum by hand it feels rough and noisey i think the drum bearing has gone.What sort of job is it to change the bearing.
I had the same problem check the holes inside the drum for a bra wire stuck in one of them which was my problem we also thought the bearings had gone but they were not hope this helps
Posted on Nov 08, 2008
  • daveyjones8 Jan 05, 2011
    Hole-in-one, many thanks. keep up the good work.
    Dave Jones
SOURCE:
Hotpoint aquarious making loud gring noises and sometimes does't start
sounds like motor brushes. physically check your motor for black power, that's a sure sign of brush wear. could be seized bearings, try spin the barrel of the washer by hand, if it's stuck/very hard to turn, thats a sure sign of bearing seizure.
Nov 10, 2013 | Hotpoint Washing Machines
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 15, 2012 | Hotpoint Washing Machines
Hotpoint aquaries wf321 is making a loud clicking/knocking noise when its in the spin cycle, to me sounds like a poss bearing gone or maybe something is caught up?
From the front of the washer, spin the drum by hand, if it feels rough or is noisy or rumbling, then the drum bearings have failed.
It is possible that there is something caught between the inner and outer drum.
Nov 30, 2010 | Hotpoint Washing Machines
Washing machine makes a loud vibrating noise when spinning and sprays grease onto washing
It sounds like the main bearings have failed, try turning the drum by hand, if it feels rough or is niosy, then the bearings have failed.
Oct 25, 2010 | Hotpoint Washing Machines
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarious 1200 IE When spinning the drum ocsillates violently and is very noisy.
Remove drive belt, and spin drum by hand, if noisy or rough, then bearings have failed, if no noise, then could be suspensioon leg problem.
Please rate my solution.
Tghanks.
Sep 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
WMT01 washing machine makes a very loud noise on the spin cycle, is this a bearing?
Remove belt, and spin drum by hand, if it is noisy,or feels rough, then it is the main drum bearings that have failed.
Thanks.
Aug 16, 2009 | Hotpoint Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
400 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
