Wireless card not recoqnised - Computers & Internet
  • 1 more comment
  • valeterman Oct 16, 2008
    Its an HP DV2000 laptop and broadcom wireless card,it seems from other forums its a costly repair (the motherboard needs replacing) and its a common fault
    Many thanks for your comments and suggestions Joed911 you have been very helpful. I must admit i did think about using an external pc card but after some more investigating on the net and reading many forums it seems HP have recalled these laptops and fixed them for nothing or at a reduced cost so i will continue with my corrispondence with HP at the moment and will keep you posted , thanks again
  • JDTec
    JDTec May 11, 2010
    Which wireless card?
  • 4,338 Answers
You can purchase a wireless adapter that plugs into the Expres card slot for about $40 . These can be purchased at your local computer store . Less expensive than a new motherboard, and they work quite well. As a matter of fact, I have my on-board wireless turned off and I use a Wireless Belkin adapter.
You can see the adapters here, but you should be able to find them locally:
http://www.google.com/products?q=Laptop+Wireless+adapters&hl=en&show=dd
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 16, 2008
  • JDTec
    JDTec Oct 16, 2008
    Very good,glad to help.
    Thanks, Joe
Dell NetworkDell Wireless 1350 WLAN MiniPC
The Dell Wireless WLAN Card Utility locates, manages and provides information about wireless networks in your area.
The Dell Wireless WLAN Card Utility allows you to create network profiles, connect to an available network, and diagnose connection problems.
Enable the utility through an icon in the notification area of your desktop, or locate it in the programs list depending on which Dell computer you have.
Turn on the Dell laptop and make sure the wireless switch is in the "On" position.
Right-click the utility icon in the notification area of your desktop.
The icon appears as a set of four green, yellow, red or white bars, depending on the signal strength in your area.
Click "Enable Radio."
Right-click the icon and click "Open Utility" to open the Dell Wireless WLAN Card Utility.
Control Panel
Click "Start" and select "Dell Wireless WLAN Card Utility."
Click the box next to "Enable Radio" and click "Apply."
Click "OK."
http://support.dell.com/support/edocs/network/p70008/en/utility.htm
http://support.dell.com/support/edocs/network/p70008/en/wizard.htm
Jul 05, 2013 | Dell NetworkDell Wireless 1350 WLAN...
I have a new notepad bought in UK. I cant connect to wireless only local connections
The problem could be -
You do not have a wireless card installed.
or
The wireless card drive was not installed.
Check Control Panel - Syatem - Hardware - Device Manager - Network Adapters. If you do not see a wireless card then your laptop does not have a wireless card installed. If you see a yellow ? against the wireless card then the wireless card driver was not installed.
Sep 14, 2010 | D-Link Computers & Internet
Is this printer compatible with Windows 7 insalled in a computer
HP PSC 2210 Printer is compatible with windows 7 operating system. You need to install the windows 7 compatible drivers from this link selecting your operating system.
Hope this helps.
Best wishes.
Aug 07, 2010 | HP PSC 2210 All-In-One InkJet Printer
Wireless connection wont work
To check if the wireless card is bad or OK.
Go to Control Panel - Network Connections - Is the wireless network connection listed and if so is there a red X on this connection?
If so, right click on the wireless and click Repair - this may fix your problem, it forces the wireless router to issue the wireless card with a new IP address.
If it doesn't fix the problem then go to Control Panel - System - Hardware tab - Device Manager - scroll down to Network Adapters and expand and check your wireless card, is it Working and Enabled?
If has a yellow ? against it or not working then reinstall the wireless card driver.
If the wireless card is built-in check the BIOS to see if the wireless card is enabled, if not enable the wireless card and repeat the above steps.
If this doesn't fix your problem then the wireless card is faulty and you need a new wireless card. You can get a PCMCIA wireless card to replace the faulty wireless card. If the wireless card is built-in then disable the faulty wireless card in the BIOS before you install the new wireless card.
Oct 11, 2009 | HP Compaq Presario 2200 Notebook
Laptop states wireless adapter not installed and configured? worked before.
Oct 11, 2009 | Gateway (802.11usb) Wireless Adapter
Wireless button
The T30 laptops do not have a on/off button that turns the wireless card on.
Once the wireless card driver is installed the wireless card will detect any wireless router and access point within its range. You need to configure the wireless card to connect into the wireless router or access point eg. the encryption, SSID etc.
The Thinkpad laptops have different wireless LAN cards installed, when you install a wireless card driver and it doesn't work, then install a different model wireless card driver. Also make sure the XP or Vista version of the wireless driver matches the Windows version that is installed on the laptop.
Jul 12, 2009 | IBM ThinkPad T30 2366 Notebook
Printer will not recognize new blk ink cartridge.
I think either the printer's scanner(or film as some call it) and/or the carriage is faulty. The signal cable that connects the carriage to the logic board could also be a suspect. Try replacing these items one after another and the culprit will be isolated. Good luck.
Jun 03, 2009 | HP PhotoSmart C4280 Laser Printer
Dell Inspiron 1520
it'll not fit since your laptop needs an expresscard.
here are the list of the wireless cards that you can get:
Dell Wireless 1390 802.11g Mini Card Wireless Dell Wireless 1490 802.11a/g Mini Card Wireless Dell Wireless 1505 Wireless-N Mini Card Intel Pro/Wireless 3945 802.11 a/b/g Mini Card Wireless Intel 4965AGN Wireless-N Mini Card Dell Wireless 5510 HSDPA ExpressCard34 Dell Wireless 5520 HSDPA Dell Wireless 5720 EVDO or a Linksys Wec600n Wireless-N Expresscard Adapter
Jun 04, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Think pad wireless card
You may try the following:
1) Plug the wireless card on another slot
2) Update the drivers of the wireless card
If those does not work, you may try to install the wireless card on another computer just to isolate if the problem is on the wireless card or on the slot of the computer
Jan 13, 2008 | IBM - 19K5544 Network Adapter
Computers & Internet Logo
David Payne
David Payne
