Question about Lexmark X3550 All-In-One Printer
This device may contain an RF Module
Just need to know what this means. Thanks.
    Scholar:
  • 74 Answers
If this has an RF (Radio Frequency) module installed, it most likely means that it is capable of communicating with another wireless device such as a computer. It is an option in some models and it may not exist in yours.
Posted on Oct 15, 2008
Turn signals do not work, have replaced module, still do not work
Find a wiring diagram an get a DVOM - digital volt ohm meter an do some electrical testing . Videos on you tube on basic automotive electrical testing , how to read a wiring diagram . Then go http://bbbind.com/free_tsb.html free wiring diagrams . What component controls windows an door locks , I know what does , what to see what you think does . The speedometer not working is probably the step motor inside the instrument cluster . New instrument cluster ! Replace the turn signal switch.
The vehicle is equipped with power door locks. Each lock actuator is powered and controlled by the door module mounted in the individual door. The driver door module (DDM) is the master control for the door lock system but the rear integration module (RIM) contains the program that determines when the lock functions are permitted.
The vehicle is equipped with power windows controlled by the door modules. The DDM receives a window switch request, over the SBI serial data, from either the passenger door module wired to the window switch pressed or from the driver door switch assembly. The DDM checks the Class 2 serial data to see if the status information is correct (i.e. ignition switch position) to permit window operation.
If the status information to permit window operation is correct, the DDM sends the command to the door module controlling the window to move the window as requested.
Windows Power and Ground
The windows are powered by discreet power and ground circuits. These circuits are in the same dedicated connector as the window motor drive circuits.
These systems are very complex and are able to set DTC'S in the controlling module .Your best bet is to take your vehicle to a qualified repair shop .
DTC B3142 LF Unlock Switch Circuit Low DTC B3147 Passenger Unlock Switch Circuit Low DTC B3152 LF Lock Switch Circuit Low DTC B3157 Passenger Lock Switch Circuit Low DTC B3172 RF Window Up Switch Circuit Low DTC B3177 RF Window Down Switch Circuit Low DTC B3182 LR Window Up Switch Circuit Low DTC B3187 LR Window Down Switch Circuit Low DTC B3192 RR Window Up Switch Circuit Low DTC B3197 RR Window Down Switch Circuit Low DTC B3377 LF Window Up Switch Circuit Low DTC B3382 LF Window Down Switch Circuit Low DTC B3387 RF Window Up Switch Circuit Low DTC B3392 RF Window Down Switch Circuit Low DTC B3397 LR Window Up Switch Circuit Low DTC B3452 LR Window Down Switch Circuit Low DTC B3457 RR Window Up Switch Circuit Low DTC B3462 RR Window Down Switch Circuit Low DTC B3467 LF Window Express Down Circuit Low DTC B3472 RF Window Express Down Circuit Low DTC B3527 Window Lockout Switch Circuit Low
DTC'S are intended to point the qualified technician in the correct diagnostic path. You may have a communication or network problem . Are you familiar with class two serial data bus communication network . The simple bus provides a means for information exchange among the vehicle door modules. Door module information on inputs and commanded outputs are converted to serial bus interface data for exchange among the door modules. The DDM can also take information from modules connected to the class 2 serial data circuit and relay the command to the simple bus interface. The vehicle power mode message (ignition switch position) from the DIM is an example. The DDM periodically addresses each module on the simple bus interface. When a module does not respond to the DDM, the DTC for that module is set. You can't just replace these modules , some need to be programmed . Dealer only ! First check codes , power an grounds etc....
Jun 29, 2016 | 2000 Buick LeSabre Custom
What does RF out mean and spdif mean. Plz
RF out means Radio Frequency output. That will send out video and usually audio to a compatible device like a TV. For example connecting a VCR or older games console was done with the RF out on the VCR or console sending the picture and sound to the TV.
S/PDIF is a Sony /Philips Digital Interface Format.
It is a means of sending sound from one device to another. For example from a Blu-Ray player to a surround sound system. This is usually done with a Toslink lead that uses light to send the information but apparently it can use RCA leads, I've never seen that.
May 06, 2016 | Computers & Internet
Connecting to base
read the user manual as the handsets have to be registered by the base unit to be connected
the main base is the operational unit
the other bases are just cradles to hold the phone while it is being charged
May 03, 2017 | GE / Rca Visys 25424re1 4- Line Corded...
What does QUAD BRI stand for?
It means that there are four ISDN BRI S/T interfaces on the device. Each BRI line contains two phone numbers at 64Kbps of bandwidth each so the Quad BRI would supply 128Kbps x 4 or 512Kbps of bandwidth.
Feb 09, 2011 | Polycom Quad Bri Module for VSX7000S & Vsx...
Power light just flashing
A very common problem for a Philips projection TV. You will most likely need to have the convergence board reworked. This convergence board is also know as the small signal module. You will see it as the board with all the RCA jacks and RF connectors! Thanks for asking and show all hands of support.
Dec 01, 2010 | Philips Televison & Video
Screen is foggy and out of focus,blurry..
You may have one of two possible problems here. First..you may have a contaminated tube. This means one of the projection tubes may have fluid that has become cloudy and must be replaced with clean fluid. This would take a bit of patience to do so. It is not easy. The second problem may be that the small signal module may need replaced. Do not confuse this board with the small signal board, which is a tiny board that sits on top of the signal board and easily snaps in and out. You want to repair or replace the signalboard that is located on the floor next to the power supply board [has the flyback on it]. It is the board that contains all the RCA jacks and RF connections, that you are concerned about. Please check the first answer. You will have to disassemble a bit to look inside the projection tubes as they are lit. Thanks for asking!
Aug 08, 2010 | Philips 60PP9202 60" Rear Projection...
Does the coaxial output equivalent to a standard yellow cord video cord? Trying to transmit Direct TV signal to another TV via a RF Link.
Typically the coax is an rf signal. The "yellow cord " is a video signal and never the twain shall meet without an rf modulator. rf contains all video, audio, and sync signal. Video contains just video, no audio. If you use the yellow, and the white and the red you will have video and both audio channels.
Oct 16, 2009 | Olevia LT27HVX 27 in. LCD Television
Working principle of super heterodying receiver
you can find it easy with google, but here is how it works...the incomeing rf signal is mixed with a signal of another frequency from the local oscillator and then passes through a non linear device (semiconductor). after passing through the nonlinear device the output will contain the original frequency,the local oscillator frequency, and frequencies equal to those added together and subtracted from each other,these signals are then passed through filters to obtain only one which will be either the rf frequency plus the local oscillator frequency or the rf frequency minus the local oscillator frequency. This new frequency is then coupled to the intermediate frequency amplifier stages where most of the amplification takes place before the audio is removed and passed to the audio stages.
Jan 13, 2009 | Computers & Internet
Error code 9 - 358
Hi,that means ,cleaning auger is stopped.Probably toner waste container is full.Try to remove and replace waste toner container(or vacuum toner from container).
BR
Feb 20, 2008 | Xerox DocuColor 12 Printer
Rear Projection and PlayStation 2
Hi, If your PS2 has an RF module, it is possible that the PlayStation 2's RF unit is interfering with your reception. Even if you are using the Audio/Video OUTput of the PS2, the RF module is also working and throwing out an output to either Chs 3 or 4. By switching off the PS2, the RF module would likewise be off. If by switching off the PS2 does not solve the problem, it is also possible that the Video input board of your TV has been slightly damaged. I doubt if it is a major repair and offhand would probably involved minor components or simply re-soldering. Hope this be of some help/idea. Post back how things turn up or should you need further information.
Sep 16, 2007 | RCA P52926 52" Rear Projection Television
Lexmark X3550 All-In-One Printer Logo
63 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
