Question about Tower ACCUTOWER CD "Music" 5 Writer Duplicator (E78265) Burner
I lost my manuel to my tarrget drive 40x12x48 cd-rw source drive 52xcd-rom I have not even used it, it's not even hooked up.
Sir i am using acer 4736z i got problem with my dvd driver when i am inserting blank dvd for writing operation it shwos 0 bytes used free sapce 0 bytes not able to write data so what to do pls help me...
you have to make sure you are using the correct format for your drive i.e (+/-)
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 8X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM, 4X BD-ROM, 4X BD-R, 2X BD-RE, 4X BD-ROM DL (double-layer), 4X BD-R DL (double-layer), 2X BD-RE DL (double-layer)
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM, 4X DVD+R DL (double-layer), 4X DVD-R DL (double-layer)
8X DVD-Super Multi double-layer drive:
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 24X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
Apr 09, 2011 | Acer Computers & Internet
My Dell Inspiron 530 CD-RW will not open and is not even listed in the device manager or on the drive
Sounds like the power cable isn't in the drive properly or the cable from your power source to the CD-ROM is defective.
Thanks,
Pat
Aug 15, 2010 | Dell Inspiron 530 Desktop Computer
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
TROUBLESHOOTING
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Computer CD-RW
here is your problem - im a expert in cd roms ... put the computer back like you had it
2 download this small file i wrote
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
open the file run it and reboot the computer BINGO it works - this file reset you upper and lower filters in the registry now the cd rom works - let me know
Dec 30, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
I have a disc stuck in my CDRW Que! 40x12x48. Any suggestion? I have tried a paper clip
A paperclip should eject the tray, what happens when you use the paperclip? Have you been able to successfully use a paperclip in the past on this exact drive?
Jun 26, 2009 | QPS Que! CD-Rewriter CD-RW Burner
To burn dvd-r on ASUS CB-5216A CD-RW/DVD-ROM.doest it supports the burninig of DVD-R
have the same same problem unsolved yet. it's not on the software actually, it's in the installation of the drive...
May 29, 2009 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
Cant instal as have no installaltion cd
for all i know cd/dvd rom are automatically detected by windows, so there's no way it wont be recognize by the windows unless you are using win95.
May 15, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
CD-RW/DVD-ROM wont write to 8x disks
My combo drive is unable to read any files in DVD. Please let me know what should be done.
Combo Drive SM-352F
May 12, 2008 | Samsung SM-352F CD-RW/DVD-ROM (Combo)...
Works fine, except won't recognise DVDs
do you have the software that recognise DVD? never show you a dvd?
Sep 15, 2007 | Lite On LTC-48161H CD-RW/DVD-ROM Burner
Computers & Internet Logo
20 people viewed this question
Top Tower Computers & Internet Experts
Falling star
tootsie mason
Are you a Tower Computer and Internet Expert? Answer questions, earn points and help others
