Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Occasional leak at the bottom of the freezer side kenmore 25354703400 side by side
The fridge works well except every few days there is a puddle on the floor. HELP!
    President:
  • Kenmore Master
  • 2,651 Answers
Sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Oct 26, 2008
Fridge leaking intermittently from the bottom
Sounds like your gasket may be going out. Consider replacing the gasket on the doors. Look for signs like small lines of frozen water that lead to the door or unexplainable excess ice in the bottom of the freezer.
I would also check for excess water in the condensation catcher tray, which may very well be located in the same spot under the ice maker. Depending on where you live (southeast, coastal, etc...) can have a strong contributing factor of having excess condensation, which will cause the tray to overflow.
Apr 25, 2017 | Kenmore Refrigerators
My Kenmore side by side is fine, except for freezing everything in the crisper drawers.
The coldest place in your fridge is in the crisper drawers, manufactures know this and they even put heaters under the floor of your fridge to try to heat it up a bit in there, if you set your freezer temperture to low there will be less cold air current that flows into your fridge but it will flow in over a longer period of time, that air is about -22C so it will be blowing on your items in your crisper for a long time and it will probably freeze them, all very confusing and complicated but it may help to turn your controles for your freezer to a warmer setting, on the other hand if you only open your fridge a few times a day the cold air being denser will settle in the bottom of the fridge and freeze the crisper area, not much you can do about this, except eat more food... :-)
Aug 26, 2011 | Kenmore Side by Side Refrigerator
Water leaking from bottom of fridge (freezer) onto floor
This is a very common problem and has several reasons that may cause the problem. I have a lot of information that covers the different ways that this takes place and hot to to resolve the problem all on one page. So read the complete page and choose the part that most fits your refrigerators condensate overflow. Thanks, Sea Breeze
Click on link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 16, 2009 | Kenmore Refrigerators
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
The icemaker leaks water from the fill tube into the fridge
my suggestion is to start from the beginning! shut down the fridge for a couple of days store food somewhere else (obviously and see if you get much water at bottom. have mos and bucket nearby. blow into any hoses that are accessible. unplug fridge of course.
Mar 18, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Water leakage
It is possible that your refrigerator is not defrosting properly. If it has a timer defrost try to turn it slowly clockwise until you hear a click and about one minute you should hear a crackling noise indicating the freezer is in defrost. If the timer does not turn and defrost about every 8 hours I suggest you change the defrost timer. Let me Know, Thanks, Sea Breeze
Feb 26, 2009 | Kenmore Refrigerators
Water leaking out bottom of refrig/freezer
Sounds like maybe two things. Your freezer isn't closing correctly and condensation is forming, bad seal maybe. Other option is you need to clean the pan on the bottom of the fridge. Condensation gathers there and it is normal, but if you alot of crud down there it will cause water to gather. Hope this helps...
May 25, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore sidebyside
you are probably getting an ice build up on the evaporator and the drain also blocked with ice. take back cover off freezer and melt any ice off with careful use of a hairdryer. make sure the drain at the bottom of evaporator if free by pouring a little water down it. if blocked with ice, free with hot water and parience. if fault reoccurs, you have a fault on defrost system
Apr 17, 2007 | Kenmore 52673 Side by Side Refrigerator
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
157 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
