Question about Texas Instruments TI-83 Plus Calculator
Light/Dark Screen I can't get the screen to get darker. It's so light I can't even see it.
Turn on the TI 83 enter 1234
1. press the <2nd> once; press and hold the <up-arrow> until you get the numbers as dark as you want. If you let up and press the arrow key again you have turned the function off. You must start over by pressing the <2nd> key then the <up-arrow> key and hold.
2. If the numbers are too dark; press <2nd> once and hold the <down-arrow> to get it corrected.
3. If this does not correct the light/dark screen condition you need to buy new batteries!
Hope you can follow my explination.
R. Meidell
Posted on Oct 15, 2008
Why is sony bravia dark screen
If your TV seems to be darker than you think it should be, it is possible that the problem is with the light sensor. The light sensor will automatically adjust the picture brightness based on the ambient light that is in the room, (i.e. if the room is bright the picture will also be bright, if it is dark the picture will also be dark).
To turn this feature off go to Settings > General Setup > Light Sensor.
Feb 27, 2015 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Black screen
Check its back-light inverter and back-light CCFL lamps.
Jul 12, 2013 | Sceptre X32BV-Naga 32 in. LCD TV
Dark Screen
It sounds like a back-light problem. Check all the CCFL back-lights.
May 08, 2013 | Samsung LN52a750R1FXZA
I accently made my text light black. How do I restore my text to normal?
To alter the contrast (light/dark) of your screen, press "2nd", then press your up and down arrows to make the screen darker or lighter, respectively.
Nov 12, 2009 | Texas Instruments TI-83 Plus Calculator
Pantech Matrix screen is almost always black so I can't read it
Many users of the Pantech phones have been experiencing the same thing. There are a lot of default in this phone. I would suggest you to return it to Pantech and try to get a software upgrade (if there is!). Although, I would recommend you NOT to use it. Even if the Pantech exchange it for a new one, the same problem will happened in a day or two.
Sep 25, 2009 | Motorola Mobility RAZR V3
The brigthness in the screen is became darker
Hello Jaffeds,
Sorry to answer u by this news :
this problem u have happening by 2 cases ..
1st Case :::: that's maybe ur screen lamps is broken ..so u can see the data but very dark or no Back-light .. so u will need to replace the screen..or advanced option but with expret person to change the lamps from another broken sceen,,
2nd Case ::::: The high-voltage board..it's small board built below the screen to give the screen the right voltage to light on .. so u will need to replace it also ..or Advanced option also but with expert electronic person to check it ..
best luck.
Dec 02, 2008 | Compaq Presario 700 470024-192 Notebook
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
Solid Line Across Screen
Suspect the Light Engine part # 939P977010
Feb 21, 2008 | Mitsubishi WD-52327 52" Rear Projection...
My LG 37LC55 LCD TV has one half of the screen darker than the other
Is the XD Demo on. This shows half of the screen with the XD picture engine on and the other with it off. Check your picture settings in the menu.
Good Luck
Jan 05, 2008 | Televison & Video
Lg 1919s flatron monitor slowly gets dark
This problem is showing when the main PCB of the monitor failed. Contact the LG service provider in your area. They will change the full package assembly or PCB. check this link to get the service center info
http://www.lgservice.com/
Dec 13, 2007 | LG L1915S 19" LCD Monitor
Texas Instruments TI-83 Plus Calculator Logo
469 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
