Question about Canon PowerShot S500 IXUS 500 Digital Camera
Powershot S500 screen display
With the switch mode in either setting, the screen shows no image. It shows the icons.The camera will take a picture, flash will work, then when switched into play back mode, the propere icons show up but no image. I have pulled the battery, card out and changed them both, but to no advantage. Thanks for your help. Duane zmdwarren@aol.com
  • 2,039 Answers
See this link.
Posted on Oct 15, 2008
Why can I not get my Canon PowerShot S3 IS to switch to the PLAY mode?
Search Results
    [PDF]Manual
    gdlp01.c-wss.com/gds/3/0900001323/01/PSS3ISCUGba-EN.pdf
    Avoid dropping or subjecting the camera to severe impacts. Do not ... 2006 CANONINC. ... When switching between shooting and ... The camera switches to Playbackmode, but the lens does not retract ..... Play/Print/Set up/ My Camera Menus.
    Canon S3 IS Review: Full Review - Operation
    www.imaging-resource.com/PRODS/S3IS/S3ISA3.HTM
    Record Mode LCD Display: In Record mode, the PowerShot S3 IS's LCD reports ...Unlike its behavior in Record mode, the Display button will not let you view ... switchwith the red camera icon, this mode sets up the Canon PowerShot S3 IS ... exposure setting you've chosen if the camera can't get a good exposure with it.
    [PDF]Download
    galeria-zdjec.pl/ksiazki/instrukcje/Canon/canon_pss3_eng.pdf
    Shoot movies in any mode by pressing the movie button ... with My Colors ... caused by the malfunction of non-genuine Canon accessories (e.g., ... warranty does not apply to repairs arising out of the malfunction of .... Switching between Metering Modes . .....Do not get the camera caught on other objects or subject it to.
    How to give your low-end Canon digital camera RAW support
    archive09.linux.com/feature/118946
    Linux.com
Jan 24, 2016 | Canon PowerShot S3 IS Digital Camera
The lcd screen distorts & my pictures show up pink on the display screen on my ixus 500
If the menus and icons look normal, but images are distorted or discolored, you may have an image sensor (CCD) problem. See Canon's service notice regarding this issue here. Canon will repair your camera at no cost regardless of warranty. Contact them at your regional Canon service agency.
Mar 26, 2010 | Canon PowerShot S500 IXUS 500 Digital...
Unable to take photos
See this link. The symptoms you describe indicate your CCD sensor is bad.
Aug 18, 2009 | Canon PowerShot S500 IXUS 500 Digital...
Mode switch has broken off and the camera screen says no image
it probably remained locked on the viewer and there are no images capture stored into the camera ..that's why it says that ....and it must be a way to restore the function of that button cause no matter if you lock it permanently into the the shooting mode its still a issue of getting pics out of it ....most cameras have to be on viewing mode when are plugged on the data cable ...but ..if you can open it and switch it on the mode that allow you to take pictures...you can always get the pictures from the SD card directly via an card reader ...adapter ( USB) that cost only a few dollars...
Aug 07, 2009 | Canon PowerShot S500 IXUS 500 Digital...
Display screen is black only when in picture mode. Display shows pictures already taken. Batteries and memory card are fine.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Aug 03, 2009 | Canon PowerShot A80 Digital Camera
If camera playback is fine on previously taken picture (when it was good) then camera has problem with CCD Imager Sensor and this part need to be replaced.
Canon will repair it free of cost. For details, please click on Canon CCD Advisory.
Thank you.
Oct 06, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Blank LCD Screen when in shoot mode
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Mar 23, 2008 | Canon PowerShot SD100 / IXUS II Digital...
No image
No image in shooting mode on Canon S500. Flash operates and shutter clicks. Whats wrong?
Nov 12, 2007 | Canon PowerShot S500 IXUS 500 Digital...
It doesn't take pictures...
Sounds like a defective CCD imager. You may be in luck. Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
Nov 02, 2007 | Canon PowerShot A80 Digital Camera
Turn on camera but the lcd sceen is black
Have you checked the display mode you're in? If you have the display set to off (to save power) and also the picture review time set to off, then you'll just see a black screen. Try pressing the 'Disp.' button below the screen when the camera is on - it should cycle through different settings with each press: Off, On, On with picture info. Similarly, in the playback mode this will show you more or less info about the picture you are viewing.
Even if the display is switched off, if you have your 'review' option in the menu set to anything other than Off (i.e. 2 seconds), then you should see the picture you've taken appear on the screen straight after taking it.
If it's not that, then I don't know the answer....
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Canon PowerShot S500 IXUS 500 Digital Camera Logo
49 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
