Question about Boating
Raytheon --Apelco 365--fishfinder
I have a broken power pin on my Apleco 365. I can't seem to find Raytheon or Apelco repair service. Any help would be appreciated.
My Zip Code is 32735
  • Anonymous Apr 09, 2009
    I ran into the same issue with my Raytheon L365.
    I couldn't find pins to replace and, even if I had, not sure how well I could have made the plastic case accept a new one and still be rigid enough to take the female connector. Maybe with epoxy...?
    Anyway, being out of options and seeing absurd prices on eBay for used replacement units, I jury-rigged it.
    I opened it, gently disconnected the two wires (black/w AND red/w) from the pins, twisted about four inches of new wire onto each of those two (to get some length). I, then, drilled two tiny holes through the case to get the new wires through to the outside of the case (patched with 5200 for watertightness) and I just make an ugly-but-functional direct connection of the bare wire into the connector and tape it up.
    It's served me well for a year now.
    Just this past Friday, though, I decided I would make it a better/cleaner connection by cutting the power, female connector to expose the wires and come up with a nice connection. After looking over everything (measure twice, cut once), I cut the TRANSDUCER/DATA cable instead of the power cable?!?!?! Darwin award!! Ugh!
    Anyway, I'm planning on doing some soldering here soon. I hope that helps you, though.
    Walmart sells a $90 Garmin I'll probably get when this one croaks for good. I am just postponing running the cables and drilling a new transducer in my beloved hull...
  • 13,975 Answers
For the information of future searchers, I add an OEM type repair that has just worked for me.
Go to the dollar store and pick up any audio lead that has a single narrow pin in the centre. Cut the plastic where the cable enters the plug to expose the end of the pin and wire connection. unsolder the plug and at the same time using the heat from the soldering iron, withdraw the pin from the plastic that is holding it in place. Now you have an unsoldered pin all on its own.
Remove the back from the Apelco 365 and unsolder the wire on the broken pin, (mine was just a push fit). Touch the broken pin with the soldering iron and withdraw it. Insert the new pin, heating it a little with the soldering iron. From the outside of the back case, check the alignment of the pin, making small alterations using a bit of heat. Once satisfied, apply a little dab of crazy glue to fill any gaps around the pin.
Job done. In future use a little Vaseline Petrolem Jelly on the female plug and make sure the plug is square to the back when you insert it, and lined up with the notch at the top.
Posted on Nov 14, 2009
I need the operation manual, please help.
Posted on Feb 20, 2010
I have the L365 head , lost to someone that touht he needed more than me.my phone is (616) 821-0607. The head is in fine working order.so if you would like to replace your broken head .give me a call or e-mail me at frodorc1@sbc global.net
Posted on May 30, 2009
The fishfinder has no power whatsoever when I go to turn it on. I bought it with the boat and they never said it had a problem but when we go to turn it on we get no luck. Any ideas???? It looks brand new!
it could be a power issue. check to make sure that there is voltage at the breaker, then make sure that there is voltage at the plug that plugs into the back of the unit. the big problem with this plug in the needle pins inside the units plug area get bent or broken very easy,, so look at the back of the unit and in the plug area and see if all the pins look good. also check for a inline fuse and make sure it is not blown,, there could also be a circuit board issue going on like a bad resistor or diode. if you live in a big city you can most likely find a Raymarine dealer around your area that can take a look at the unit and do a quick trouble shoot to tell you if it is worth fixing. could also be just a circuit board fuse. or just a bad power cord.
c...
Feb 11, 2011 | Raymarine Ds500x Color Fishfinder: Ds500x...
Have power to my Ray53 DSC VHF on my boat but no sound
Sounds like a bad speaker. Try plugging in an external one and see if that works if so replace the bad speaker.
Jul 29, 2010 | Raytheon VHF 53 CB Radio
Is Garmin Fishfinder 90 working?
possibly.most ive owned will flash random numbers when out of the water.the fact its flashing or reading numbers at all,means its working.youll have put it in water to see how accurate,obviously
Jul 08, 2010 | Garmin Fishfinder 90
Hi I have an Apelco 530 fishfinder/gps and need a through hull transducer kit. Apelco were taken out by Raymarine who advised me to contact Airmar who made the transducers. So far no answer but their...
Embedded
I was looking to see if I could find a replacement for the display and was able to confirm that the transducer is a single beam 120khz unit so I doubt that you've find a replacement for it ..as is .
The Airmar C-49 is the proper number for the connection line but like me I think your going to have to think about a whole new unit and or system . Been there already.
Best of luck.
Sir Isaac
Jun 22, 2009 | Raymarine Boating
Need older Raytheon v720/ v820 sounder transducer pinout
Did you find it? i´m triying to get a wiring pinout diagram for a V8010 transducer. Thanks, regards from Spain
Apr 21, 2009 | Televison & Video
Cant find pictures of an Apelco 365 fishfinder? any body have an idea on where to look
Here is one on the cover from a VHS instructional tape showing the 265 and 365. Might be able to blow it up a bit and crop the 365 out....
http://ecx.images-amazon.com/images/I/51EAJS27Z5L._SL500_AA280_.jpg
And, you can go here:
http://www.raymarine.com/SubmittedFiles/Handbooks/Fishfinders/G627296www.pdf
for the 365 handbook to get some pretty fair drawings on the unit. I ran through the pages pretty fast and didn't see any photos but did run across a few drawings and illustrations.
Hope these help. If you can locate a former dealer for them, they might have some clip art from their coop advertising info.
Good Luck....
Apr 14, 2009 | Boating
I require a Manual for a Apelco 365 fish Finder
Check out this site, on here they have a download for the manual you require,
www.retrevo.com/s/Raymarine-465-review-manual/id/556ci073/t/1-2/ - 52k - or go direct to www.raymarine.com
Regards
Alan Hood
ami-man
UK
Mar 12, 2009 | Boating
Apelco 365 fishfinder. Broken pin on power connector
i did the same damn thing and am amazed this question is on the net. i bought a new system but plan on taking it back. the 365 was a pretty nice model and i'm just going to splice it straight to the power supply. but i was lucky, the two pin connector is the damaged one so drilling it out and splicing it SHOULD be easy. well see. at this point i have nothing to lose.
hope this helps.
Jul 27, 2008 | Raymarine A65 Combo GPS...
Searching for wiring diagram
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=420817e4b66b5093026515350edf12d2&q=Raymarine+Apelco+6760
heres the link to download manual it will have wireing diagram in it for you also i will be uploading the manual to fixya
May 20, 2008 | Computers & Internet
Boating Logo
2,041 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
