Question about Hoover 24 in. DT999 Free-Standing Dishwasher
Leak from salt reservoir on the DT999
Hello, our dish washer is leaking quite badly. I have removed the side panel (right hand side) and there is a plastic part, that runs on the outside from the side of the machine, into the top right hand side of the salt reservoir via 3 outlets. Each outlet has an O ring to connect up to the reservior on the bottom. It was leaking heavily, so I cleaned the connectors and the O rings and have put petrolium jelly on the rings. When you turn the machine on, it still leaks. There seems to be tremendous back pressure and water flies out past the O rings. I can't see any blockage in the salt reservoir, is there a pump or something a little bit past this that might have failed? I can't find a schematic to work out the flow through the system. I wonder if you can help. Cheers.
  • sploid Mar 05, 2011
    Thank you both, you were spot on.
    Problem Solver:
  • 4 Answers
Replace water softner seals (Hoover spares reference: 91941698) as stated previously. Harraps were doing them for £6 each. The softner is accessed by removing the R/H panel and unscrewing the air break ring nut from inside the machine. They are not a standard size so oem o rings are recommended.
Posted on Sep 08, 2009
Where is the fuse for the samsung dmr77 dishwasher
Hello Margaret;
My name is Peter. I am a retired field service appliance technician.
Unfortunately, Samsung does not design their appliances to be maintenance friendly. You have a inline fuse that is in the wiring harness, inside on the on the bottom right hand side.
Substitution: Part Number 3601-001197 Cost: $4.00
You have to remove the right lower side panel to access the harness. The side panel is held on with one screw. Then pull toward you to remove.
There are several reasons your dish washer will not run.
You could have a bad door contact switch:
Remember to turn the power off first.
You could have a bad door contact switch, or one of many other sensor.
Tell me what the problem is. Is your control panel lit up?
Dec 24, 2014 | Samsung Dishwashers
Our water is soft and does not require salt. how do we stop the red light
I think it might depend on the model # and it should be in your manual.
Example for a G858 SCVI plus instructions (without pictures) are;
Bypassing the salt indicator
If your water is soft (below 8 gr/gal) the
salt reservoir should not be filled with
salt. The indicator will remain lit and
should be disregarded or bypassed.
Remove the salt reservoir cap.
Looking into the salt reservoir, you will
see the top of the float chamber on the
right hand side, a.
Using a screwdriver, carefully pivot
the float chamber towards the center
of the reservoir.
Using needle nose pliers, pull the
cap, b, off of the float chamber, and
remove the float, c.
Replace the float chamber cap, push
the chamber back into its upright position,
and replace the salt reservoir cap.
The "Salt" indicator should no longer be
lit.
Feb 17, 2013 | Miele Premier-Plus Built-in Dishwasher
Landrover Discovery 300tdi 1997 Windscreen Washer Diagram
Hello! The rear washer tubing runs from the reservoir up thru the front corner support column, thru the roof and over to the door. The tubing run from the reservoir to rear door washer jet differs between left and right hand drive vehicles. On right hand vehicles the tubing run is on the left hand side of the roof. On left hand drive vehicles, the right side.
Normally, there is always fluid present in the tubing, thus no priming is necessary and it prevents any clogging... The rear washer jet is is more than likely plugged... Guru...saailer
May 06, 2012 | Cars & Trucks
Dishlex dx303 error message 50
Our Electrolux DX303 had an i50 error. It was due to a water leak causing earth leakage current. So it's good it stops working if it detects a leak.
Our leak was from where the water goes to the upper arm (the pipe is made of plastic and has a plastic thread which isn't strong ie cheap). The pipe is located on the back right hand side once you take off the panels.
Apr 15, 2012 | Dishwashers
Deloghi dw67s dishwasher, drain pump on continuously, showing E4 and no water in washer. What is used to detect the overflow?
Hello
There is a slight leak somewhere or the machine keeps overfilling causing the drain pan to activate via the flood switch.
remove all dish trays from washer, unscrew and remove lid off salt softener, almost and thoroughly remove as much excess water as you can, it could be the vacuum switch/water level float.. do the tip over again, and be sure you get it all,
replace all trays and softner lid and machine should work again.
Aug 09, 2011 | Dishwashers
Washer fluid is leaking from somewhere. How can we tell if its the reservoir or a hose leak? How do we remove reservoir to check?
best way is to remove the wheel arch cover on the side of the bottel and ispect where leak is coming from
May 18, 2011 | 2000 Volkswagen Cabrio
Windshield washer fluid reservoir - MB ML 350
right where the lines connect to reservoir, has little black seals that leak. I recommend removing reservoir, empty it out, then use RTV silicone and place it between seals and reservoir. Let it dry for FULL day. than reinstall.
Jun 23, 2009 | Mercedes-Benz ML350 Cars & Trucks
Neff dishwasher sticks on 1 minute
We had this problem with our machine.
There turned out to be a few things that caused it:
- Firstly, the float assembly (an orange looking float in a little chamber, visible if you take off the left-hand panel of the machine) was clogged - we cleaned this and it seemed to help.
- The heat exchanger matrix was full of debris - we tried to clean this but ended up damaging it and bought a new one.
.. these two things seemed to improve the cleaning and the machine worked for a while.
The real problem though (which caused it to pump out continuously) turned out to be a failed seal on the circulation pump.
If you look on page 4 of the following link:
https://www.neff-eshop.com/eshop/neff/gb/prodp.htm?eShopType=S&prod=S5456X3GB%2f22
.. you will see a diagram of the bottom of the machine - the part that failed was 171598, which you can see on the bottom middle-to-right hand side of the picture..
The rubber had perished very badly, and it was causing water to leak into the bottom of the machine, which triggers 'flood mode' whereby it pumps continuously and doesn't actually wash the dishes.
The part costs about £5 - fitting it is not straightforward though, as you need to strip the machine down which is a pretty involved job.
If you think you're up to it, the steps I followed were:
- Remove both side panels
- On the left hand side, remove heat exchanger matrix and float assembly
- Remove kick-panel under the front door
- On the right hand side, remove all wiring from the door to the machine (including an earthing wire which is screwed to the side of the machine) - note that there are two wires which go to push-on connectors which have to be removed separately - all the others go to connector blocks.
- Inside the machine, remove the wire baskets, spray arm and bottom filter.
- Remove the lid from the salt dispenser - and now the tricky part, you need to find something that will allow you to remove the large plastic 'nut' that holds the salt dispenser to the machine.
- Remove the two screws in the bottom of the machine (167241 in the diagram mentioned above)
- Now, shut the door and then disconnect the door spring mechanism from the left and right side of the door.
- Disconnect the string from the door closing mechanism from the springs at the left and right back corners, under the machine.
- Remove the two screws at the back of the machine which connect the top of the machine to the base.
- Remove the two screws at the front of the machine which connect the top of the machine to the base (these are quite low down, near the door hinges).
Now, you should be able to lift the top of the machine off the base, and will have access to the pump etc.
... re-assembly is the reverse of disassembly ;-)
This took me a couple of hours - it might be better to find somebody who will do it for you for fixed cost as it's a pig of a job.
For what it's worth, there seemed to be very few places where the machine could leak - and this looked to be the major one - and there are a few push-fit pipes which are worth checking out too.
Hope this helps somebody.
Oct 22, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Water leak
Remove the lower panel under the washer door and inspect the interior. The panel is removed by loosening and removing the screws under the bottom front edge. With the screws removed the panel will drop down, then off. Inspect the following areas:
- Check all hoses for leaks, cracks, holes and loose connections. Check the seal where the drain hose from the bottom of the wash tub connects to the intake of the drain pump. Make sure the drain hose from the pump to the standpipe is connected snug to the pump and is not leaking.
- Check the drain pump to ensure it is not leaking. The clean out reservoir cap (if not fitted properly) can leak around the seal.
- Check the door bellow (gray rubber boot) to ensure it is not leaking. HINT: A tale-tell sign of bellow leakage is wetness showing up on the front washer counterweight. This is a concrete block mounted to the front of the wash tub. It is not supposed to be wet.
- Check the pressure switch air hose to ensure it is connected to the air dome on the side of the wash tub. This is a small rubber hose that runs from the pressure switch in the top left rear of the washer (viewed from the back, with the washer top panel removed) to the bottom right hand side of the wash tub. However, if this hose were to come off the air dome fitting, the wash tub would continously try to fill and water would begin to pour from the bottom of the wash tub. If this does not sound like your symptoms, disregard this step.
- Check the seam where the wash tub shells meet. There is a rubber tub gasket that seals the two tub halves together. If the seal is bad, water will begin to collect and drip along this seam.
- Check the tub for cracks. This is NOT common, but it can happen.
The following link explains the step-by-step process of checking and cleaning the drain pump:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I mention this link, because it gives you some guidance on how to access the pump and how avoid the possible mess involved with water pouring out of the pump.
If you discover the door bellow as the the cause for your leak, please refer to this link:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I hope this leads you in the right direction and helps you resolve your problem. Please post back if you have any further questions.
Aug 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG Dishwasher - drain hose replacement
Hello, I have just installed a similar model, and took the side panel off to see how it was put together ;)
The drain hose goes in the back of the dishwasher, then loops up the right side (as you are looking at the front)(this is to act as a "trap" to keep sewer gases from coming back into your washer, I assume), and then connects to the drain pump under the washer.
In order the change the hose, you will need to remove the left side panel, and the bottom panel, and this will give you access to the entire hose....
Hope this helps!
Nov 26, 2007 | LG LDF8812 Stainless Steel Built-in...
Hoover 24 in. DT999 Free-Standing Dishwasher Logo
407 people viewed this question
Top Hoover Dishwashers Experts
Owen Barnes
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
